2013 plug n play back up camera
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Deano1842, Apr 30, 2019.
  1. May 5, 2019 at 11:36 AM
    Deano1842
    Deano1842 [OP] Member
    Jeff
    2013 Toyaota Tacoma
    Fog lights
    No rush
  2. May 5, 2019 at 11:40 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Is this connector a 20 or 24 pin (the one I circled in red)?
    Does the radio have navigation?
    The picture of the connectors that I posted earlier (post #14), are there both sides (male/female) or just what I show?
  3. May 5, 2019 at 2:37 PM
    Deano1842
    Jeff
    2013 Toyaota Tacoma
    Fog lights
    I will have to take the radio back out to check the pin number. The radio does not have navigation.
  4. May 5, 2019 at 2:42 PM
    Deano1842
    Jeff
    2013 Toyaota Tacoma
    Fog lights
    The connectors that you had in your pic are just like mine but I have male leads coming out of mine that run toward radio.
  5. May 7, 2019 at 2:15 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    So you have 4 connectors for these?
    Two going to the rear of the truck and two going to the radio? The one with 4 wires is the camera.
  6. May 7, 2019 at 2:16 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    What camera did you buy?
  7. May 7, 2019 at 3:22 AM
    sju350
    sju350 Well-Known Member
    Joe
    TN
    18 Tacoma TRD Smokin Edition
    If you do have something plugged into these connections EDE92D6D-4C50-459C-9803-86D804B66B4D.jpgthey are going to your rear view mirror. But since you said earlier that you have a plain jane mirror the wires are tucked up above headliner where mirror is. You will have to either buy a mirror that has the back screen on it or from your earlier pics it looks like you have this radioE64F04E6-A38A-4699-9DD9-FDCC363D1DA3.jpg if so you will need this wire harness. DD112852-554A-4718-9521-F754EB71B6E6.jpgWhich will plug into radio where havoc showed a pic asking if it was a 20 or 24 pin. Here with red circle0D553546-4757-4269-B1A4-712A3B42E086.jpgthe other end of wire harness plugs into the wire harness of first pic. You will have to unplug what is there and plug new harness in. Right now as you show you have a good camera but it’s not plugged into anything since you show radio not having anything plugged into plug marked red and also not having a mirror with backup screen. It’s needs one or the other. Putting in another radio won’t help much cause it still wouldn’t have any kind of wire plugged into it from camera.
  8. May 7, 2019 at 3:30 AM
    sju350
    Joe
    TN
    Also, before buying a mirror or anything if something is actually plugged into these0601E629-A225-40B0-9F4D-9681FCA03313.jpgtry to put your hand between headliner and ceiling on truck right above your mirror and see if you feel the wire harness placed up there somewhere. The truck I had was extended cab so it had a console with map lights there and when I removed console I could see the wire harness
  9. Mar 22, 2021 at 2:13 PM
    sju350
    Joe
    TN
    I believe they are for the reverse trigger wires, for the back of the radio and the other for the actual reverse signal from tail lights. I’m not 100% certain though. It’s been a few years since I installed that and have upgraded truck so I don’t have it to go look at. Maybe someone else on here can chime in and say.
  10. Mar 24, 2021 at 11:56 AM
    rtoms
    rtoms Member
    tom
    2013 tacoma reg cab
    just ordered the harness for my rc 2013 also... random question is the camera unit itself different on a 2013 and 2014 ( my neighbor has a 2014 and is going to let me try that camera) once I install the mirror to radio harness. ( yes I checked wires under truck and at fuse block I am prewired ) although there is no wiring from headliner to mirror (its just a base mirror not the video one)
  11. Mar 24, 2021 at 12:20 PM
    captaintofuburger
    captaintofuburger Well-Known Member
    2011 Base 4wd 4banger
    My 11 is on the mirror
  12. Aug 9, 2021 at 10:07 AM
    Enzo6803
    Enzo6803 New Member
    Enzo
    2013 double cap Red Tacoma 4x4
    none
    Hello All,
    Is there an update?
    I would like to know as well
    thank you.
  13. Aug 9, 2021 at 10:29 AM
    rtoms
    rtoms Member
    tom
    2013 tacoma reg cab
    Camera plug IS different on a 2014.. I tried my neighbors did not plug in.
