2013 prodigy2 install question
Discussion in 'Towing' started by Ali, May 25, 2013.
  1. May 25, 2013 at 10:34 AM
    Ali
    Ali [OP] New Member
    Albuquerque
    2013 4WD Dbl Cab SR 5
    Greetings,
    I am installing a prodigy 2 in my 2013 tacoma 4wd, db cab, with tow pkg. I have the connector provided with the truck which has 5 wires and the prodigy 2 connector which has 4. The extra wire from Toyota is marked headlamp switch to vehicle trail lamps. The prodigy connector has 4 which match to the battery, stop light, ground, and brake on the Toyota connector. What to do with the extra wire?
    Have a call into prodigy, but they aren't open weekends.
    Thanks
