2013 secondary air-valve delete
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dvst8r1K, Feb 2, 2017.
  1. Feb 2, 2017 at 3:36 PM
    Dvst8r1K
    Dvst8r1K [OP] Night-Taco
    Greg
    2nd gen Black Tacoma SS 4.0l 4-dr 4x4
    1" Toytec body-lift, K&N filter, coolant by-pass, mesh cotton screen delete, TTBS, WeatherTech in channel visors, 2.5" Rancho full suspension kit, Oil Catch Can, Toyo 285/70 A/T-2's, 21.5" light bar in grill, blacked-out grill, de-badged entire truck; and again, more to come.....
    Did you bring enough to share?? Lol!!!
  2. Feb 2, 2017 at 3:41 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The reason why you can do it on your motorcycle so easy (did the same mod on my 04 honda 919) is SMOG / CARB / EPA restrictions on motos is FAR less.... thus programming on ecu's dont have to have checks to see if the equipment is still there.
    Also the PAIR system on the hondas is FAR more rudimentary using a simple solenoid and some reed valves to suck air into the exhaust on negative pulses. Not like the tacoma where air is forceably fed into the exhaust during startup.
    The 2012's had issues due to not having a shutdown purge that helped remove moisture from the valves themselves. 2013+ got a shutdown purge, which helped reduce failures drastically. Also like stated above remove the foam filter that deteriorates and use a 1in uni breather and call it good.
    Also outside of emissions the startup running of this pump also has the benefit of extending catalytic converter life as the super rich fuel environment during cold startup wears the cats out faster, introducing clean air helps push the excessivly rich exhaust through the cat.
    Sidenote: always loved the guys that showed off their blinged out sport bike claiming 190+mph yet have 2in wide chicken strips.....
  3. Feb 2, 2017 at 3:46 PM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Should this be done on a 2.7L or is the V6 the only one that has the issue?
  4. Feb 2, 2017 at 3:51 PM
    spilser
    spilser Well-Known Member
    2013 DCSB TRD OR 4x4 Mag. Gr.
    Not sure, you'd have to ask some other 4 cylinder guys. I know for sure on 2012+ 4.0's
  5. Feb 2, 2017 at 4:35 PM
    nd4spdbh
    SoCal
    FYI 2.7L has had the pump since day one.
  6. Feb 2, 2017 at 4:40 PM
    Dvst8r1K
    Greg
    Yeah, that's new rubber, and I've not been out for some fun riding yet... Besides, you should know better the claims of speed are straight line.. I don't even take curbs at 190. Be it as it may, you sound like you've been there so I won't argue with a guru.. They usually know it all, and I know I won't win that one...
    Wait, you have a 919 w/out chicken strips??? Cool!!!
    TheFang likes this.
  7. Feb 2, 2017 at 4:54 PM
    Dvst8r1K
    Greg
    Back to Yota's....
    So have any 2.7's ever had the problems the 4.0's have... Where all the 2.7's at... Info please; as there needs to be an end to this madness air injection BS!!! Or at least a favorable MOD.... Lol...
  8. Feb 2, 2017 at 9:00 PM
    Dvst8r1K
    Greg
    ARB1977: You're probably tight?? As of now, only time will tell when the 2ND-gens will start misbehaving, clogging, and going into limp mode. I would hope not, but we shall see. Thanks for your time....
  9. Mar 2, 2018 at 8:14 AM
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    I haven’t had any problems but just because there have been problems I’d love to delete this CA influenced bullshit.
