2013 Squeaky Leafs are driving me crazy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by senojeelnodnarb, Apr 17, 2013.
  1. Apr 18, 2013 at 2:26 PM
    slowmachine
    slowmachine Well-Known Member
    Alton, NH
    Teflon spring liners?
  2. Apr 18, 2013 at 2:38 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    i did the fix that was on the link and it works for about a year using the inner tube from an old tractor tire. it wore out i guess and this time i took 1/2" x 3" sections of sidewall from an old car tire and got that in between the 1st and 2nd and 2nd and 3rd leaf on both sides front and back (like in front of axle and behind axle not front and back of truck). I imagine it will be some time before they were out, and i prolly got a a 1/2" lift for the back of my truck out of the deal for free.
  3. Apr 18, 2013 at 2:47 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    If it is the front , bet you it's not the bushings
  4. Apr 18, 2013 at 2:50 PM
    OZ-T
    Peter North
    British Columbia
  5. Apr 18, 2013 at 4:37 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    TSB leaf bushings. About 20 bucks from the dealer. Replaced my worn out crappy ones with the new thicker rubber ones. Issue solved.
  6. Apr 18, 2013 at 5:32 PM
    beaver_scott
    beaver_scott Well-Known Member
    scott
    renton, wa
    2015 inferno trd pro
    vent shades, tinted windows, clear bra, pop n lock tail gate lock, anytime fog light mod.
    my truck did that when I first bought it. I used to spray wd40 all the time to quiet it down...then I got tired of spraying and stopped. amazingly they stopped squeaking on their own. in the meantime get a magnaflow.
  7. Aug 25, 2014 at 11:38 AM
    Ben550
    Ben550 Well-Known Member
    2012 TRD OFF ROAD
    My springs didnt start leaking till i did some off roading in wet sand. once the sand got in the springs it never came out. I power washed it, greased it, put rubber inbetween the springs, but nothing worked except monthly grease projects.
    the TSB fix should have been standard out of the factory.
    It was embarrassing driving around in a truck that squeaks its way down the road... haha
  8. Aug 25, 2014 at 11:46 AM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Every time I go to the dealer they're like it's out of warranty tfb, I just turn up the tunes, I find afterror a day or two of non muddy wheeling flexing the hell out of the springs they stop squeaking for a bit, it's not anything as bad as my work truck so it's never really bothered me
  9. Aug 26, 2014 at 3:10 PM
    smith945
    smith945 Member
    South East Massachusetts
    2012 Off Road Dbl. cab
    OME at the corners Dakars at the back, Total Chaos UCA's, Leer cap, Pelfreybilt battery cage
    Fluid Film has quieted my Dakars down for at least a month now with many trips out on the beach, down some hunting trails, and the wash downs that go along with those trips.
    Also it's good for stopping the rust, my local autozone is carrying it now.
  10. Aug 26, 2014 at 3:51 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    You're in SE Mass? Which Auto Zone? It'll stop my annual trips to Grainger if they have the spray can and the gallon spray.
    Mine are awful...I should do something, but they'll likely tell me what they told me when I complained about the standard vibes..."oh, you have very aggressive tires" or my personal favorite "operating as designed."
    Maybe my next oil change I'll mention it.
  11. Aug 26, 2014 at 4:37 PM
    smith945
    smith945 Member
    No gallon jugs as of yet but they have the aerosol cans. Kingston is where I found it. I was told if it sells well then they will expand the line.
