2013 Stock (nonNav or nonJBL) head unit with Sirius XM satellite radio
Discussion in 'Audio & Video' started by FawkQ, Jun 27, 2013.
  1. Jun 27, 2013 at 6:30 AM
    FawkQ
    FawkQ [OP] Well-Known Member
    Alberta, Canada
    2013 TRD Sport DCSB V6 4.0 6M "The Sequel"
    After searching TW for basically an entire day, wondering if it is possible for the 2012 and 2013 folks without the Nav / JBL option to keep their stock HU but still have Sirius / XM radio... But without getting that lame little second receiver thingy for sat radio, I finally got the answer!
    So to all the newer Taco owners who like the stock look that want satellite radio, go here: http://www.tacomaworld.com/forum/2n...stalling-sirius-stock-touch-screen-radio.html
    Offered by: http://www.vaistech.com/site/sl3sat.php
    I found lots of other make shift / very creative ways, but this seems the most efficient / fool proof!
  2. Jul 2, 2013 at 5:55 AM
    andyt11
    andyt11 Tiny Member
    Central Canada
    '13 TRD 6spd Dbl cab Leather
    Tekonsha P3
  3. Jul 2, 2013 at 8:14 AM
    FawkQ
    Alberta, Canada
  4. Jul 3, 2013 at 6:54 AM
    andyt11
    andyt11 Tiny Member
    Central Canada
    Tekonsha P3
  5. Jul 3, 2013 at 4:34 PM
    FawkQ
    Alberta, Canada
    Since you've confirmed the antenna is included, I honestly couldn't tell you the difference...
  6. Aug 20, 2013 at 11:12 PM
    Rojgonz
    Rojgonz Well-Known Member
    Las Vegas, Nevada
    '13 Nautical Blue 6 speed Manual TRD Off Road
    Has anybody installed the unit from ebay successfully?
  7. Aug 21, 2013 at 5:03 PM
    Sparky295
    Sparky295 New Member
    Lebanon,ohio
    Installed XM
    I have found a XM kit from Toyota of McDonough. On there web site they have a kit and direction. The kit only took 1/2 hr to install
  8. Aug 21, 2013 at 8:35 PM
    Gerrrr
    Gerrrr Well-Known Member
    Jeremy
    Ottawa, Canada
    2017 Blazing Blue Metallic (Limited 2013 Silver Streak DC Auto - Retired)
    Starting over.......
    Hey, did you order the McDonough kit? I was here to see if anyone had tried it. Did you put the antenna under the moulding as the instructions say or leave it under the dash?
    Thanks
  9. Aug 22, 2013 at 4:33 AM
    Sparky295
    Lebanon,ohio
    Installed XM
    Yes,
    I had to take the top of the glove box out .It only has 2 10mm srews and then wire tied it the round support bar. I also went Auto zone and bought a set the plastic pry bars to get the dash apart.
    You also need to make sure as it says to have the - battery unhooked you are working around the dash air bag sensor.
    Once installed XM come for week before the unit needed to be set up through XM
  10. Aug 22, 2013 at 5:47 AM
    OldChuck
    OldChuck Member
    Chuck
    Upstate SC
    Just got the VAIS installed for Sirius and installed two JL C2 690TX speakers in the front doors. Wanted a starting place and the sound of the JL's are a 100% better then stock. The stock speakers are pathetic looking. About like most factory base speakers. So far, I like it. The VAIS is is a plug and play and interfaces flawlessly with the factory touch screen. The Sirius comes up just like it was made from the factory. Had some help and ran the included antennae up through the factory middle break light on the roof and it looks factory. Don't know if I will stay with just the front speaker upgrade but will live with it for awhile till I decide what to do next. Anyway, for a little over $500 got Sirius and great sound...
  11. Aug 23, 2013 at 4:51 AM
    andyt11
    andyt11 Tiny Member
    Central Canada
    Tekonsha P3
    Sparky can you post info on the kit you bought?
  12. Aug 24, 2013 at 4:27 AM
    Sparky295
    Lebanon,ohio
    Installed XM
  13. Aug 26, 2013 at 6:58 PM
    sr5va
    sr5va Member
    I literally just ordered this ebay kit without thinking, I really hope it works. I should be getting it tomorrow, I'll let you guys know what happens!
    The only thing I'm scared about, is it says AM+SAT button online, but I have the touch screen sr5 without jb/entune, so hopefully it works either way.
  14. Aug 27, 2013 at 11:40 AM
    OutRider
    OutRider Somebody
    RJ
    Tennessee
    2013 4X4
    Chrome Step Rails, Spotter mirrors, H-D window clings, Blue 2D Cell LED Maglite, UWS Low Profile toolbox.
    Yes, let us know if the ebay kit works. I have an XM Onyx installed but do not like all the wires. I looked at the XM SkyDock - kind of cool...
  15. Aug 27, 2013 at 1:32 PM
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    will this work if the truck has a factory "shark fin" ? or do we have to install the kit supplied antenna?
  16. Aug 28, 2013 at 3:09 PM
    sr5va
    sr5va Member
    I don't think it works. I installed the the isimplegate, and it shows the SAT in the touch screen, and when I plug in the tuner absolutely nothing happens.
    It only displays channels 1-10 and just displays CH UNAVAILABLE. It doesn't do anything.
  17. Aug 30, 2013 at 6:41 AM
    OldChuck
    OldChuck Member
    Chuck
    Upstate SC
    I know that cost is important however, the Vais unit interfaces flawlessly with the touch screen. It is a plug and play interface with no unsightly wires or need to remove anything to get to it. There may be others' out there that do as well but I don't know of any at the moment. The custom audio shop that I went to for information said that the Vais is the best out there for plug and play interface. It was recommended on several forums and I could not be happier. Around $300 but works like factory....
  18. Aug 30, 2013 at 8:19 AM
    sr5va
    sr5va Member
    Assuming the correct isimple gateway and a sxv200i tuner works, which is also a simple plug and play, and has the exact same antenna as the vaistech, why not pay $130 versus $300
  19. Aug 31, 2013 at 4:11 AM
    OldChuck
    OldChuck Member
    Chuck
    Upstate SC
    SR5, I agree if that unit will work as well as the Vais then I would say buy it. When I started checking out a hassle free way to continue the Sirius contract I had in my 2012 Mustang, the only plug and play that I heard great things about was the Vais. I am very happy with is and it is a flawless, OEM like interface but if there is something as good and cheaper then I would look closely at it...
  20. Sep 1, 2013 at 10:27 AM
    sr5va
    sr5va Member
    I received the correct isimple, as well as the SXV200i tuner, but unfortunately I also had to order a specialty convertor plug to adapt the two for an extra $29 shipped.
    I'm away for this upcoming week, but after this week I'll take some pics of the install, assuming it all goes well as well as a little mini guide on the installation. I have very high hopes of it working, as the old isimple I had displayed the SAT menu etc, it's just it couldn't pull correctly from the SCC1 Tuner.
    All in all my cost for all parts were $157.00 shipped.
