2013 T.A.Co. Gathering - Official Thread
Discussion in 'Moab' started by NYCO, Oct 10, 2012.
  1. Mar 22, 2013 at 9:11 PM
    #2861
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I know, he always says that haha the farthest I'll probably ever go with mine is mid-travel.
  2. Mar 22, 2013 at 9:16 PM
    #2862
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    LT!!!!
    Possibly with a 2nd gen kit and diff....:spy:
  3. Mar 22, 2013 at 9:16 PM
    #2863
    PcBuilder14
    Brent
    Nor Cal
    Haha good luck on the 2nd gen diff. Saw your thread on that, could be interesting...
  4. Mar 22, 2013 at 9:21 PM
    #2864
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea who knows. Haha
  5. Mar 22, 2013 at 9:24 PM
    #2865
    PcBuilder14
    Brent
    Nor Cal
    I actually hope you get it figured out. I like seeing new ideas!
  6. Mar 22, 2013 at 9:28 PM
    #2866
    Blackdawg
    Monte
    Wyoming/St. Louis
    Take a ton of custom fab work..but I think it's do able.
  7. Mar 22, 2013 at 9:29 PM
    #2867
    PcBuilder14
    Brent
    Nor Cal
    What's the advantage again? I can't remember... :eek:
  8. Mar 22, 2013 at 9:33 PM
    #2868
    Blackdawg
    Monte
    Wyoming/St. Louis
    Stronger diff and CV axles.
  9. Mar 22, 2013 at 9:39 PM
    #2869
    PcBuilder14
    Brent
    Nor Cal
    Oh, okay. Gotcha!
    Which reminds me, I need to to the boot slide mod.... Dang it! Haha
  10. Mar 23, 2013 at 8:12 AM
    #2870
    mh3kgt
    mh3kgt -TACOMBO-
    Elko, NV
    07 TRD Sport
    OME 885's, OME Nitros front, Billy 5100's rear, 1.5"AAL, Satoshi'd Billet Grille, 18" Moto Metal 955's Plastidipped, more to come
    Tentatively may be in for this. Gotta probably look at new tires and pick up a CB tho
  11. Mar 23, 2013 at 8:47 AM
    #2871
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    do it up!
    looks like you'd have a nice drive down the 93 on your journey
  12. Mar 23, 2013 at 10:37 AM
    #2872
    mh3kgt
    mh3kgt -TACOMBO-
    Elko, NV
    07 TRD Sport
    is Just A Cheapo 510 Series Cb Ok For Something Like This? I Will Probably Only Do Trails Like Gemini Bridge Or Similar Since My Wife Will Be About 6Mo Pregnant By That Time, Plus I Dont Have A Whole Lot Of Offroad Experience Yet.
  13. Mar 23, 2013 at 11:54 AM
    #2873
    NYCO
    bOb
    Colorado
    dents & scratches
    one step closer to moab ready!
    305/70/17 MT/R Kevlar
  14. Mar 23, 2013 at 11:56 AM
    #2874
    NYCO
    bOb
    Colorado
    dents & scratches
    yea you don't need anything fancy...it's a safety and convenience factor with events like this when you'll be with so many trucks.
    many of us could chime in and go through the benefits of having a cb, but either way, we'd like all attendees to have a cb.
    handhelds can work, but if you get separated from the group, your range is not as far as if you had a box and antennae.
  15. Mar 23, 2013 at 12:12 PM
    #2875
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Just finally fixed my antenna... :anonymous:
    Still needs a tune. :rolleyes:
  16. Mar 23, 2013 at 4:34 PM
    #2876
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    well everyone who commented about my tire fitment issues..... the deed is done.
    silas, i got the bfh out....
    I tried to keep it as nice looking as possible, but it is difficult. i must have cut and flexed and cut and flexed like 30 times.... im convinced its as good as its gonna get without tubing the firewall.... the pinch weld is virtually gone, fender flare got nicked a little and fender liner got loped off pretty good too. i also made a slight amount of clearance on my spindle gussets. plenty of room i think now:D
    I also tried my skills with making steering stops. keep in mind my welds arent as nice as Silas's but its not going anywhere... i angled mine towards the lower ball joint for a nice flat surface contact. Took a long time to dial it in at exactly the right length. I found that the tire gets closer to the frame when stuffed, which makes it very easy to grind the steering stop too low when just checking unloaded.... but i am no longer rubbing frame at all flexing or not:D. when flexing its about half inch away, im comfortable with that. no for pics!
    oh... and since my fener liner had to get trimmed past the pinch weld it allows, water and snow to get into the fender and on the front of the door... i dont like that because water will rust out the bottom of the fender. so i got the idea of expanding foam to fill that void. im gonna try it later today, when the ice melts off the truck. i plan to spray the foam from the door gap side in towards the fender liner.... im thinkin it will easily seal all my gaps. then i got some undercoating for the wheel well for where i beat on it:D
  17. Mar 23, 2013 at 5:49 PM
    #2877
    Slodgetto
    Slodgetto Über Posre
    Silas
    :woot: :drool:
    haha Nice! How big did your steering stops end up at? Kinda looks like you increased your turning radius more than me. :eek:
  18. Mar 23, 2013 at 6:10 PM
    #2878
    lotsoftoys
    Jace
    Denver
    bunch of crap
    what do u mean more? they ended up right under half inch.... hard to really measure tho cuz i angled them. worked perfectly tho no more frame rub:D
  19. Mar 23, 2013 at 6:57 PM
    #2879
    Slodgetto
    Silas
    Like a bigger circle... Bigger turning radius meaning not tight. But I guess I was wrong, they just look bigger than mine in the pic for some reason... :notsure: Glad it solved the rubbing!!
  20. Mar 23, 2013 at 7:14 PM
    #2880
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Wait, what size in inches are your new tires?
