2013 T.A.Co. Gathering - Official Thread
Discussion in 'Moab' started by NYCO, Oct 10, 2012.
  1. Apr 11, 2013 at 10:40 AM
    #3401
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    mine hasn't moved in a while :(
    luckily it's a bunch of small shit..
    before moab:
    -reverse lights and rock light additions
    -jerry can setup
    -tires clearancing/trim flares?
    -TC spindle gussets
    maintenance before moab:
    -fluids, all
    -grease everything
    -rear brake pads
    -cabin air filter
    -sand and paint sliders
    -touch up skids and bumpers
    -grille touchup
    -re-seal doors
    -waterproofing
  2. Apr 11, 2013 at 10:42 AM
    #3402
    BradyT88
    BradyT88 Well-Known Member
    That was kind of funny actually. They were just cruising along and then bam! Then they were super cautious after that. I get the idea that they thought it was going to be a cake walk up it until that happened. I still don't think that obstacle is all that hard, but I imagine our longer wheelbase makes it much easier for us.
  3. Apr 11, 2013 at 11:08 AM
    #3403
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Fuuuuuuuuuuuuuuuuuck. Writing it down makes it seem horrible.
    Drop front diff
    Install ARB
    Plum air line
    Revalve rebound shims on bypass
    Revalve rebound shims on coilover
    Swap shaft spacers in bypasses with 1/4" spacers
    Cut off upper tabs on bypass hoop
    Cycle front suspension
    Weld on new upper shock tabs
    Measure cv plunge and axle angle at bump/droop
    Shorten bump stops and lengthen straps accordingly
    Recharge coilovers, front bypasses, rear bypasses, and bumps
    Install 18" coils and flat spring plates
    Fix rear rock light
    Fix front bumper mount
    Install bellypan
    Mount/balance two new tires
    Fix/rebuild battery mount
    Rear brake shoes
    Mount Yakima basket
    Fill CO2 tank
    And do everything with my right arm like t-rex
  4. Apr 11, 2013 at 11:57 AM
    #3404
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    What meats are you getting Ben?
  5. Apr 11, 2013 at 11:59 AM
    #3405
    NYCO
    bOb
    Colorado
    dents & scratches
  6. Apr 11, 2013 at 12:02 PM
    #3406
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    list to be done
    re complete OBA
    fill C02
    install new rear third and front diff
    install crawl box
    install and clearance 37's
    install BL
    install rear bumper
    paint skids
    paint sliders
    get an alignment
    diff service after break in
    im sure there is more somewhere
  7. Apr 11, 2013 at 12:05 PM
    #3407
    rockgecko03
    rockgecko03 Well-Known Member
    Ben
    Rockwall, TX
    1999 Tacoma - Perpetual Project
    treadwright guard dogs 315/70/17 load range D
  8. Apr 11, 2013 at 12:31 PM
    #3408
    BradyT88
    Call me crazy but I would install the BL before the 37's:p haha
  9. Apr 11, 2013 at 12:48 PM
    #3409
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    List of things to be done before Moab:
    Bolt on MTR's.
    Install spool into my Emaxx.
    Pack the truck.
  10. Apr 11, 2013 at 1:01 PM
    #3410
    99yodataco
    99yodataco Little Taco that could
    Chad
    New Mexico, it's just a little bit fresher.
    MGM 21 TRD OR 6sp MT
    Soon...
    List of things:
    Regear
    Tires
    Weld together front driveshaft.
  11. Apr 11, 2013 at 1:10 PM
    #3411
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    List?
    Diff drop (should be tonight)
    Fix/new cb radio
    Build headlight hoops
    Mount hi lift
    Maybe put in the bed box I was planning on putting in last year
    Dynamat sub box
    Tons of maintence
    And of course pack
  12. Apr 11, 2013 at 1:11 PM
    #3412
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Hmmm
    Kick tires
    Drink a beer
    Worry about what needs to be done starting next week. :D
  13. Apr 11, 2013 at 1:41 PM
    #3413
    rctoy
    konstantenos
    Pocatello Idaho
    I dont kick my tires i hump them :jerkoff:every morning when i get to work (thats where they are stored at the moment).
    As far as that beer goes well im down for a couple of those:cheers:
  14. Apr 11, 2013 at 2:09 PM
    #3414
    NYCO
    bOb
    Colorado
    dents & scratches
  15. Apr 11, 2013 at 2:16 PM
    #3415
    Slikk
    Slikk Well-Known Member
    Kevin
    Nashville, TN
    2013 4X4 Off Road
    whats the ratio of stock trucks to modded trucks going to this event? i am completely stock with no plans of offroad mods anytime soon.
  16. Apr 11, 2013 at 2:17 PM
    #3416
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Mine is mostly stock interior :cookiemonster:
  17. Apr 11, 2013 at 2:25 PM
    #3417
    NYCO
    bOb
    Colorado
    dents & scratches
    81% mod'd just by quick count of who i know is mod'd :cookiemonster:
    but i don't know all the trucks just by name...
    might be closer to 90+% though
    but not all are highly modified...mainly lift and tires
  18. Apr 11, 2013 at 4:27 PM
    #3418
    Slikk
    Kevin
    Nashville, TN
    2013 4X4 Off Road
    So I will be in the low percentile with a straight off the showroom that will be breaking isht and holding errbody up... :sly:
  19. Apr 11, 2013 at 4:32 PM
    #3419
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Man i wish my list was that short :(
  20. Apr 11, 2013 at 4:45 PM
    #3420
    NYCO
    bOb
    Colorado
    dents & scratches
    low percentile...
    breaking shit and holding up people...most likely not
    you don't have to hit the hardest trails in moab...
    go out, explore, have a good time...you'd be amazed at what these things can do right off the showroom floor
