2013 T.A.Co. Gathering - Official Thread
Discussion in 'Moab' started by NYCO, Oct 10, 2012.
  1. Apr 19, 2013 at 10:17 AM
    #3621
    NativeTaco
    NativeTaco Mountain Man
    Travis
    Fort Collins, CO
    '08 DCLB
    ARB, OME, BAMF, ATO, Rigid, more... Mountain Man Limousine
    I think when I make it up there this summer I will be taking the same line you did... That looks gnarly!
  2. Apr 19, 2013 at 10:33 AM
    #3622
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    That looks awesome!
  3. Apr 19, 2013 at 10:36 AM
    #3623
    rockgecko03
    rockgecko03 Well-Known Member
    Ben
    Rockwall, TX
    1999 Tacoma - Perpetual Project
    I wonder if there is enough room to slide it on top of the legs from the slider to the frame. That way it would be semi-protected as well. If for some reason it came loose, you'd have some sort of warning from the knocking noises before you lose it on the freeway/trail.
  4. Apr 19, 2013 at 11:36 AM
    #3624
    BradyT88
    BradyT88 Well-Known Member
    I was trying to find the pic of the rig with the 3" body lift that strapped the hi-lift to the outside of his now exposed frame. haha
    What do you weigh? I am about 5200lbs now.
    I worry about the clearance of a 1 piece. I have killed one 2 piece shaft already, almost two of them... If I had had a 1 piece I would have utterly destroyed both of them unless they were significantly stronger than than our OEM driveshafts.
    That's a good idea, I may look into that. My bodylift just might give me enough room.
  5. Apr 19, 2013 at 11:47 AM
    #3625
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    just looked under mine...there could be enough, but the issue would be fitting the carrier bearing in there as well..the shaft should fit but the size of the carrier bearing would be the killer for me
  6. Apr 19, 2013 at 3:40 PM
    #3626
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    Replacing CV's, upper and lower ball joints, inner and outer tie rod ends,.wheel bearings, servicing both diffs and the rear axles, and installing some lights.
  7. Apr 19, 2013 at 3:46 PM
    #3627
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    Preemptive repairs? That stuff can't all be broken
  8. Apr 19, 2013 at 3:56 PM
    #3628
    mh.meier
    The Doctor
    Commiefornia
    Well the lights are new. None of them are broken entirely but they all need to be replaced.
  9. Apr 19, 2013 at 4:17 PM
    #3629
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    i would love to convoy theres gonna be two of us leaving pocy the 25th and 4 of us meeting up the 26th to wheel. We wanna start early maybe do some of the trails twice.
    Like v this guy said two piece drive shafts are way more forgiving on the rocks.
    I weigh 5300lbs with no gear or gas in the truck lol i have you beat empty.
  10. Apr 19, 2013 at 4:21 PM
    #3630
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    5300lb 1st gen?! I wonder what my truck is at right now?!
  11. Apr 19, 2013 at 4:24 PM
    #3631
    BradyT88
    How the fuck?! I have a toolbox, I have a 10gauge front bumper, 1/4" rear, 3 1/4" skids, 1 3/16" skid and sliders and I am heavier than you right out of the gate! I don't get it. You have 35's on me and the tire gate. I have several skids over you.
  12. Apr 19, 2013 at 4:27 PM
    #3632
    mh.meier
    The Doctor
    Commiefornia
    Come on Brady. Don't you know the first gens are always heavier!?
  13. Apr 19, 2013 at 5:09 PM
    #3633
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Change of plans I am now going down on the 26th.
  14. Apr 19, 2013 at 5:47 PM
    #3634
    TROKITA
    TROKITA Well-Known Member
    Arty
    Utah, the valley
    98 tacoma TRD supercharged
    Supercharged, Custom sunroof, 6 inch lift, wheel spacers, over the rail tire carrier
    wait.... 1st gens are heavier then 2nd gens ????????
  15. Apr 19, 2013 at 5:51 PM
    #3635
    BradyT88
    Old man Mike (digiratus) weighed his last year on the way to Moab. Front and rear bumpers, fully skidded front to rear and fully loaded for his trip to Moab and it weighed 4700-4800lbs.
  16. Apr 19, 2013 at 5:54 PM
    #3636
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    cuz they r made of metal and not plastic:crapstorm:
  17. Apr 19, 2013 at 5:58 PM
    #3637
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
  18. Apr 19, 2013 at 5:59 PM
    #3638
    lotsoftoys
    Jace
    Denver
    bunch of crap
    lol
  19. Apr 19, 2013 at 6:03 PM
    #3639
    TROKITA
    Arty
    Utah, the valley
    true... :rolleyes:
  20. Apr 19, 2013 at 6:10 PM
    #3640
    BradyT88
    :rofl: model for model 2nd gens have a few hundred lbs on 1st gens. And plastic doesn't rust! Haha.
