2013 T.A.Co. Gathering - Official Thread
Discussion in 'Moab' started by NYCO, Oct 10, 2012.
  1. May 15, 2013 at 9:52 AM
    #4721
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Moab is more sidewall safe than mountain trails. Not a lot of sharp pointy rocks/sticks to puncture sidewalls.
    WishboneRunner. If I had your truck I would run the Duratracs at 15 psi. I don't know what your schedule is but if the Trifecta on Thursday is your first run, I'll keep an eye on it with you. You can always start higher if you're not comfortable going lower and then only drop the pressure if you're not getting the traction you need.
  2. May 15, 2013 at 9:59 AM
    #4722
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Cool. :cheers:
    Yeah, that will be my first run, and the first time running them offroad, so not really sure where to start. I was more worried about pinching them than sharp rocks actually slicing the sidewall.
  3. May 15, 2013 at 9:59 AM
    #4723
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    i would also say 15psi on a E rated duratrac would be a good starting point.
    jace has E rated duratracs and the sidewall is definitely stiffer than my D's were
    i may have to play with my pressure more this trip.
  4. May 15, 2013 at 10:11 AM
    #4724
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Thanks, good info.
  5. May 15, 2013 at 10:12 AM
    #4725
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    I ran 15psi last year on E rated Duratracs and did just fine. By the end of the trip they were down to 12psi and 1 at 10psi. :eek:
  6. May 15, 2013 at 10:57 AM
    #4726
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    :eek: indeed!
  7. May 15, 2013 at 11:43 AM
    #4727
    TROKITA
    TROKITA Well-Known Member
    Arty
    Utah, the valley
    98 tacoma TRD supercharged
    Supercharged, Custom sunroof, 6 inch lift, wheel spacers, over the rail tire carrier
    Ill have a co2 bottle on the trails. Another question. Does anybody know if Moab has a place where they. Can refill co2's ???
  8. May 15, 2013 at 11:47 AM
    #4728
    Box Rocket
    Adam
    Syracuse, Utah
    No CO2 place that I know of. But moab is an easy place to fill tires. CO2 can be handy on the trail if there is a flat or something but not necessary otherwise. All the trails are pretty close to town so there is no need to fill up the tires at the end of a run before heading back to town. It's a short drive, and you can fill up at a number a gas stations. Walker's on main street has a free air hook up outside.
  9. May 15, 2013 at 12:15 PM
    #4729
    TROKITA
    Arty
    Utah, the valley
    true well for everybody that will be trailing with me if your not comfortable with the tire being too low you can ask me, ill be more then happy to put air on the tires when we're on the trails. :) for the peeps that dont have on board air :D
  10. May 15, 2013 at 12:36 PM
    #4730
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    is that the maverik? I know the maverik on the road out from the exit of hells has free air as well.
  11. May 15, 2013 at 12:37 PM
    #4731
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    Yes sir they do
  12. May 15, 2013 at 12:56 PM
    #4732
    NYCO
    bOb
    Colorado
    dents & scratches
    the maverick on the south side of town no longer has free air... $.75 and the air didn't make it through 2 tires when we tried. FYI
  13. May 15, 2013 at 1:09 PM
    #4733
    2scars
    2scars Swollen Member
    Brandon
    RVA
    2003 TRD 4x4 Doublecab
    All-pro, T-G, Budbuilt, Warn, Tepui, Homefab rear bumper
    That is available at one of the big 4x4 repair shops in Moab, however they charge an arm and a leg for it. But, if you need it you need it.
  14. May 15, 2013 at 1:11 PM
    #4734
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    I ran my 33 10.50r15's at 12 just cuz they were skinny.
    I have Viair 480C duals with a 2.3 gallon tank so i can help people fill up on trails that are with me or make a distress call.
    Trail tip:
    if you have a airl line to eaqualize tires you can use your spare tire as a storage tank and keep like 60 psi in it..
  15. May 15, 2013 at 1:13 PM
    #4735
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Just gotta install new OTREs and get an alignment and I am ready :)
  16. May 15, 2013 at 1:27 PM
    #4736
    TROKITA
    Arty
    Utah, the valley
    or just swap the whole tire at once ;)
  17. May 15, 2013 at 1:28 PM
    #4737
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Are you installing b/c they are bad, or preventative?
  18. May 15, 2013 at 1:56 PM
    #4738
    rctoy
    konstantenos
    Pocatello Idaho
    they arent bad he just wants a new front end and is saving all his spair stuff for trail spares though i have so much taco stuff if he breaks we may end up swaping him over on the trail just to pack more common parts.
  19. May 15, 2013 at 2:07 PM
    #4739
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    I think the Chevron on the south side of town has free air too. Can't quite remember but we always seem to use that one, so I'm thinking it was free haha
  20. May 15, 2013 at 2:13 PM
    #4740
    mh.meier
    The Doctor
    Commiefornia
    I am getting giddy like a God damn school girl. Can't wait to give away some stuff in the raffle. Probably won't be as awesome as ARB or SExpeditions but It's still something. And I can't wait to wheel with those of you I know and to meet those of you I don't!
    :goingcrazy::goingcrazy::goingcrazy:
