2013 T.A.Co. Gathering - Official Thread
Discussion in 'Moab' started by NYCO, Oct 10, 2012.
  1. Jan 8, 2013 at 9:30 AM
    #1081
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    ARB.
  2. Jan 8, 2013 at 9:33 AM
    #1082
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    i have one in my front diff personaly i love it. but expect to break more often when using it. if you have the money do it now.
  3. Jan 8, 2013 at 10:00 AM
    #1083
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    My bushmaster is going to be at my local freight yard Friday :woot:
    Swing out with spare tire holder, 2 rotopax gas cans, rigid industries srm2 led reverse lights. Can't fucking wait to see it/install it
    This^
    if you're going to regear, do it since you already have to drop the front diff. If you aren't going to regear but can afford a front locker, do it. Worst case scenario is you won't need it real often and maybe you break a cv if you're being aggressive. From what I've seen, if you can keep the front wheels straight, your cvs should be fine. Most of the time they seem to snap when the wheels are turned.
  4. Jan 8, 2013 at 10:02 AM
    #1084
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    ECGs is great as they also offer good warrenty and will help you replace anything that breaks for a good price.
    the Puma compressor is the one i was looking at getting as well till i decided CO2 was a better way to go. Im going to run my lockers off it as well.
    This is what i was going to buy and retro fit
    http://www.ebay.com/itm/280790586347?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
  5. Jan 8, 2013 at 10:07 AM
    #1085
    JLink
    Josh
    Ocean, NJ
    Lockers running off co2? That's interesting.. Do you have a way to keep the pressure in the lines and fill your tires at the same time? Not that you would need too.. Just wondering about the plumbing.
  6. Jan 8, 2013 at 10:11 AM
    #1086
    Blackdawg
    Monte
    Wyoming/St. Louis
    ARB makes a CO2 manifold for the solenoids.
    you have to have an adjustable regulator on the CO2 tank. Then i just plan on having a T fitting post the regulator. The tire hose connector will be right there then ill probably do a hard lines to the manifold under the truck with a shut off valve right there post regulator.
    I need the valve as you would leave the regulator at 80psi for the lockers. but for tires you want 150-200psi. or air tools at 120. The valve will allow me to isolate the lockers so i can safely increase the pressure to 150 or whatever i want.
    20lb tank equals like 10s of thousands or articulations of the lockers too.
    I'll probably pick up a 5lb back up/portable tank though at some point.
  7. Jan 8, 2013 at 10:16 AM
    #1087
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    I'll just leave this here. I've run Helldorado in my FJ40 and that final climb is gnarly when dry.
    But I can't even imagine trying it in these conditions with a literal waterfall flowing down it. Crazy :eek:
  8. Jan 8, 2013 at 10:18 AM
    #1088
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    :eek:
    first photo i've seen of that exit with water like that!
  9. Jan 8, 2013 at 10:18 AM
    #1089
    Blackdawg
    Monte
    Wyoming/St. Louis
    :eek:
    i remember that shot in 4wd driver magazine of your rig Adam.
    but damn! that is crazy with the water..
  10. Jan 8, 2013 at 10:52 AM
    #1090
    BradyT88
    BradyT88 Well-Known Member
    He has a 2nd gen. As farbas I know there currently aren't any manual hubs kits anymore and I know of a few guys running 36's and 37's on here that haven't had any cv troubles with a front locker.
    I say do it! I love my front locker! Allows you to do so much more! It's surprising how effective they are!
  11. Jan 8, 2013 at 10:59 AM
    #1091
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    Finger is hovering over the order button on my cart at ECGS..
    Blackdawg, I was thinking about doing that same exact setup... Might still do it. I have a feeling that by the time I get that Puma setup the way I want it, I'll be in for about as much if not more than one of the ARB twin tanks. I just like the idea of doing it DIY style, though.
    Money's not an issue... It's just the mental barrier of justifyin dumping this much into the rig at one time. Got the winch line GB and selling a few other things to try to finance this without dipping into savings.
    I know this was raised before... But is OP alright with me talking so much tech in here??
  12. Jan 8, 2013 at 11:03 AM
    #1092
    BradyT88
    You are fine with all the talk in here. They wanted to keep the BS out while the details of the trip.were being planned out, but now.that the dates are set we opened ot up to.mod bs.
  13. Jan 8, 2013 at 11:32 AM
    #1093
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    Definitely take pics during install and the cutting process. I'm kinda curious what I will be getting myself into.
  14. Jan 8, 2013 at 12:52 PM
    #1094
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    in my opinion. it all depends on what u want out of ur truck. if ur gonna go balls deep and lock the front ifs and crawl the shit out of it. just sas the damn thing. if u want the most capable ifs rig possible, lock the front... but expect to break shit. i will never loc my ifs, ill just sas it and do it then:)
    me too! thatd be an intense trail with wet tires and the ground moving out from underneith u!
  15. Jan 8, 2013 at 1:30 PM
    #1095
    NYCO
    bOb
    Colorado
    dents & scratches
    as long as the BS is moab related, i see no problem...
    mod talk is second hand conversation when you're talking about plans for moab
  16. Jan 8, 2013 at 1:34 PM
    #1096
    rctoy
    konstantenos
    Pocatello Idaho
    more moab pics.
  17. Jan 8, 2013 at 1:42 PM
    #1097
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
  18. Jan 8, 2013 at 1:47 PM
    #1098
    NYCO
    bOb
    Colorado
    dents & scratches
    reason for aftermarket bumpers
    dunes action
    fun optional climb on fins
    kanes
    fisher towers hike
    cliffhanger
    and all about meeting new friends :D
  19. Jan 8, 2013 at 1:47 PM
    #1099
    NYCO
    bOb
    Colorado
    dents & scratches
  20. Jan 8, 2013 at 1:49 PM
    #1100
    NYCO
    bOb
    Colorado
    dents & scratches
    campfire
    the "superman"... :laugh:
