2013 T.A.Co. Gathering - Official Thread
Discussion in 'Moab' started by NYCO, Oct 10, 2012.
  1. Feb 24, 2013 at 8:57 PM
    #1841
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    :thumbsup: Oh I know man, but as I am sure you are, I absolutely don't like to concede to a challenge, so I was just seeing if there was any decent methods but clearly from the last 2 pages there isn't really. Not at all saying it would ruin anyone's day, just would love to be able to conquer it.
  2. Feb 24, 2013 at 9:20 PM
    #1842
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    One trick for all you open diff guys is when youre in the crack and in first gear just keep the tires turning slow as you can and use your brakes. it will force torque to transfer through the diff to the wheels with traction.. it's not full proof but ive cheated a few obsticals like that when i went down open front diff.
    yeah if it's all easy like 40% of the middle section it gets really lame.
  3. Feb 24, 2013 at 9:26 PM
    #1843
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Tried that to no avail, only I just did the e brake, never tried using the pedal.
  4. Feb 24, 2013 at 9:29 PM
    #1844
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    go on konsta...I thought that only worked with an LSD. So if you 4lo and L and ride the brakes or on/off the brakes it can transfer to the wheel with traction?
  5. Feb 24, 2013 at 9:42 PM
    #1845
    BradyT88
    BradyT88 Well-Known Member
    Lots of open guys were setting their e-brakes in Moab last year, especially on Kane's Creek. Where were you? haha
    Texas guy blew up one of his wheel cylinders on the trail though, although I can't figure out if that could be related to riding his e-brake or not. haha
  6. Feb 24, 2013 at 10:30 PM
    #1846
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    not sure if you're talking to me but I left the morning you guys did kane creek, I had to go to work :laugh:
  7. Feb 24, 2013 at 10:39 PM
    #1847
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    apparently i was NOT setting my e brake....i seriously think I was told that only works on LSDs. I mean even if it works a little bit for a second just to get some movement out of that tire on the ground that would be cool haha. Apparently I never got the message over my messed up CB:rolleyes:
    also jerry found the go pro vids from kane creek...so as soon as he gets them to me Ill work on a vid and spread the stoke:spy:
  8. Feb 25, 2013 at 7:05 AM
    #1848
    BradyT88
    Well the only guys I know that were using it were LSD, although it was E-LSD guys so maybe it is just LSD that it works for.
  9. Feb 25, 2013 at 7:11 AM
    #1849
    rockgecko03
    rockgecko03 Well-Known Member
    Ben
    Rockwall, TX
    1999 Tacoma - Perpetual Project
    setting the e-brake a couple clicks or using the actual brake pedal helps simulate a LSD diff. It's also referred to by some as the po' mans locker. Doesn't matter what diff setup you have, it'll work. It works by adding just a bit of resistance to the wheel lifted in the air so that at least some power will go to the wheel still on the ground.
    edit: yes, the texas guys blew up a rear brake cylinder because he was using this method. However, it happened because he set his ebrake and left it that way for the entire hill and that little hill after the little creek crossing after the big hill. Only apply it when needed and not pre-emptively.
  10. Feb 25, 2013 at 7:53 AM
    #1850
    BradyT88
    I didn't want to just say that it did it, cuz I wasn't sure. I had a wheel cylinder start leaking with my Taco sitting in my driveway. haha So I didn't want to rule out that it might just be poor quality wheel cylinders or something.
  11. Feb 25, 2013 at 8:07 AM
    #1851
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    I did all MOAB in 4Hi and open diff with no problem on any single trail, except when I almost fell off the cliff on Kane's but that had nothing to do with obstacles haha!
  12. Feb 25, 2013 at 8:15 AM
    #1852
    mh.meier
    The Doctor
    Commiefornia
  13. Feb 25, 2013 at 8:20 AM
    #1853
    BradyT88
    That one kind of doesn't work cuz usually the switch turns it off:p haha
  14. Feb 25, 2013 at 8:38 AM
    #1854
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    What trails were you on?
  15. Feb 25, 2013 at 8:40 AM
    #1855
    mh.meier
    The Doctor
    Commiefornia
    Kane's, Behind the Rocks, Strike Ravine and some other random areas. And yeah Brady, I dont know much about that shit since I am an 08 with none of that fancy jazz.
  16. Feb 25, 2013 at 8:57 AM
    #1856
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Your poor transmission! Do you have a cooler?
  17. Feb 25, 2013 at 9:05 AM
    #1857
    mh.meier
    The Doctor
    Commiefornia
    Why yes I do! I didnt even really feel I pushed the transmission too hard. But I know better now. This year will be 4Lo haha!
  18. Feb 25, 2013 at 9:07 AM
    #1858
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Cool. Yeah it's like trying it in 4hi in a manual. the clutch would be on fire within about 5 minutes.
  19. Feb 25, 2013 at 9:10 AM
    #1859
    mh.meier
    The Doctor
    Commiefornia
    Well I dunno, it handled like a champ.
  20. Feb 25, 2013 at 9:11 AM
    #1860
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Yeah in that sense, automatic FTW.
