2013 Taco 4x4 TRD Sport - LSD to E-Locker Doable?
Discussion in 'Technical Chat' started by david stoneburner, Jun 2, 2013.
  1. Jun 2, 2013 at 11:40 PM
    david stoneburner
    david stoneburner [OP] New Member
    Has anyone heard of, attempted, or performed an E-Locker rear diff swap/install on a Sport Package (LSD equipped)? :confused: Salesman said 'not available'...guessing he's not a mechanic.:rolleyes: Any pointers or shop references appreciated. :D
  2. Jun 3, 2013 at 11:19 AM
    Ryanv
    Ryanv Toyota Technician
    15 4Runner
    On a 13 you don't have a true LSD it is done thru ABS, if you want to goto a elocker why didn't you get a TRD Off-Road. I personally have never seen it done, you would need a complete rear axle, wire harness, switch and ECU. Better off putting an air locker in.
  3. Jun 4, 2013 at 9:40 AM
    david stoneburner
    Thanks Ryanv. It's silly perhaps, but I suppose I've got mixed priorities. I want the ABS/LSD effect for snow & ice, and I want the locker option for the sand, hills, and pull-out assists...probably should have gotten the TRD OR, but I didn't, so now I have a project on my hands. I've been looking into the ARB for the AL option. Any advice on that front (front vs rear, other makers)?
  4. Jun 4, 2013 at 5:24 PM
    Ryanv
    15 4Runner
    The OR has the electronic LSD and abs, works exactly the same as the sport. In 2009 Toyota stopped making mechanical LSD. As for the arb I don't have one in my truck but have seen some where the air line freezes in the winter making the locker unusable. The arb is also a lot stronger then the Toyota e-locker.
  5. Jun 4, 2013 at 5:27 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Its doable with alot of fabrication. The axle housings are different. Just save up for a ARB locker.
  6. Sep 1, 2013 at 6:39 PM
    Subtoy
    Subtoy New Member
    RI
    SR5 V6 4x4
    Has any one tried putting an early 2nd gen mechanical LDS in a 2013 with the electronic LDS? Is this possible?
  7. Sep 1, 2013 at 6:44 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    i make things cook Marshmallows
    its doable, its just a carrier swap
    you could just swap diff to diff
  8. Sep 1, 2013 at 6:48 PM
    wildcats
    wildcats Well-Known Member
    13 DCSB Sport
    Just put an arb air locker in it. Stronger than the e-locker and would be easier in the long run.
  9. Sep 1, 2013 at 6:49 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Pick-em-up-truck
    Ultimate Tailgate Machine
    This
  10. Sep 2, 2013 at 5:20 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    I've seen install videos that included a moisture trap in the air line to prevent freezing. It might be neglected often for installs where the compressor powers just the diffs.
  11. Sep 5, 2013 at 4:08 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    I did some checking on junkyard parts.. I came to the same conclusion.
