2013 Taco makes weird sound when turning ignition off!!
Discussion in 'Technical Chat' started by bokshi, Apr 16, 2013.
  1. Apr 16, 2013 at 8:37 AM
    bokshi
    bokshi [OP] Member
    Maryland
    2013 SR5
    I have a 2013 Tacoma and when I turn the ignition off it makes a funny noise. It sounds just like if you turn the ignition on after you start the truck,,, that chocking sound.. One Toyota mechanic told me it is the air pump and nothing can be done about it..I have a hard time agreeing to that..Any Ideas..HELP!!
  2. Apr 16, 2013 at 8:44 AM
    ColoradoTaco
    ColoradoTaco Well-Known Member
    Boulder
    2013 DCSB OFFROAD
    mine makes a noise like a vacum sucking the last bit of air but no grinding noise.
  3. Apr 16, 2013 at 8:58 AM
    bokshi
    bokshi [OP] Member
    Maryland
    2013 SR5
    Yeah I would say it is like that..hard to explain..but why..there should be a fix..no?
  4. Apr 16, 2013 at 9:06 AM
    Joe.erau
    Joe.erau Member
    Jacksonville, FL
    2013 Prerunner 2.7
  5. Apr 16, 2013 at 9:07 AM
    Large
    Large Red
    The vacuum noises are normal from what I've read
  6. Apr 16, 2013 at 9:07 AM
    bokshi
    bokshi [OP] Member
    Maryland
    2013 SR5
    Thank you Joe
  7. Apr 22, 2013 at 11:23 PM
    taco4by4
    taco4by4 Member
    07 Taco Access Cab 4x4 6-spd MT
    Dreaded Throwout Bearing issue
    Do you have the stock air box or aftermarket installed?
  8. Apr 23, 2013 at 9:16 AM
    bokshi
    bokshi [OP] Member
    Maryland
    2013 SR5
    I have nothing after market. So I will assume it is factory...
  9. May 12, 2013 at 6:36 PM
    foamgun
    foamgun New Member
    sw pa.
    2013 tacoma
    my 2013 doing the same thing ,i took it to the dealer and there ordering new parts!
  10. Jun 8, 2013 at 7:14 PM
    bmwtech113
    bmwtech113 Member
    Any update on this? Did the dealer fix the noise?
