2013 Tacoma Cold Air Intake Availability
Discussion in 'Performance and Tuning' started by BajaColorado, Mar 3, 2013.
  1. Jun 2, 2013 at 6:48 AM
    #81
    NiceTaco
    NiceTaco Canadian Redneck
    Ontario, Canada
    2012 TRD Sport
    Aero Turbine 2525, Front bilstein 5100's @1.75, rear 5100's, 1" Toytec rear block, Devil Horns, BGF AT's, 18" Moto Metal 962's
    Let us know... I wanna pull the trigger on this or forget about one cause I am not spending the money AFE wants..
  2. Jun 3, 2013 at 5:29 AM
    #82
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    Do you need to cut into the OE wire loom to hook the volant up or is it plug and play?
  3. Jun 3, 2013 at 5:42 PM
    #83
    MagneticTaco
    MagneticTaco Well-Known Member
    Kiel
    Louisiana
    2013 DCSB Magnetic
    3" toytech lift, front spacers, AAL in the rear, 285/75r16 goodyear duratrac, blacked out emblems and taillights, pained grill
    Its plug and play. Here is a youtube video on the install.
    http://www.youtube.com/watch?v=mN73VKyU4xU
  4. Jun 3, 2013 at 5:54 PM
    #84
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    I have seen that vid.. I just noticed AFE says they supply the wiring specifically so it makes it seem as though some may not..
  5. Jun 3, 2013 at 8:54 PM
    #85
    elsenordave
    elsenordave HaoleBilt
    Dave Smith
    Blown 2013 NBM DCSB Sport
    AFE CAI TRD Exhaust TRD Supercharger 3" Cornfed Spacer 2" Toytec AAL
    They provide a pigtail pretty easy set up.
  6. Jun 8, 2013 at 4:16 PM
    #86
    MagneticTaco
    Kiel
    Louisiana
    2013 DCSB Magnetic
    Ok so just installed my '13 Volant CAI. Didn't take too long at all, install was easy if you know a little about cars. The MAF sensor mounted up fine and all the hardware needed was included. Didn't have to drill or anything. The only problem I had was with the routing of the hose to the new air pump spot. The elbow connectors and hose extensions they give you make it to where you have to route the hose which pinches it a little bit. Also broke on of the rubber things that holds the pump to the intake box. Seems as though the pump doesn't sit quite far enough down for them all to fit flush. Had to trim a little bit and will get a new gasket thing on Monday from Toyota. All in all it went fairly smooth. The sound on the outside isn't much different from stock but on the inside when you give it some it sounds amazing. Waaaay better than before. No CEL so far although have only had it on a few hours. Will keep updating on any gas mileage changes or anything else I notice. It looks great when installed and overall I am happy with it.
  7. Jun 11, 2013 at 9:03 AM
    #87
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    Sound clips? How are you liking it now? Still CEL free? MPG worse or better or same?
  8. Jun 11, 2013 at 5:48 PM
    #88
    MagneticTaco
    Kiel
    Louisiana
    2013 DCSB Magnetic
    Ill try and get some sound clips tomorrow. I love it, sounds lower and more aggressive. Still no CEL. Only had it on for about 100 miles so far so I cant tell an MPG changes yet. Will average it out over the next few tanks to see.
  9. Jun 12, 2013 at 5:58 PM
    #89
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Keep us updated. I want to see the results including the sound clip if possible.
  10. Jun 14, 2013 at 8:25 PM
    #90
    MagneticTaco
    Kiel
    Louisiana
    2013 DCSB Magnetic
  11. Jun 15, 2013 at 5:02 AM
    #91
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    Thanks man.. Sounds good. What vendor on eBay did u get that from for that price?
    #91
  12. Jun 15, 2013 at 12:12 PM
    #92
    MagneticTaco
    Kiel
    Louisiana
    2013 DCSB Magnetic
    Got it from newlevelmotorsports for 264 with free shipping. I'm gonna look into the ram air scoop next
  13. Jun 15, 2013 at 12:37 PM
    #93
    elsenordave
    Dave Smith
    Sounds good...I can't hear mine though...Supercharger is too loud :D
  14. Jun 15, 2013 at 1:12 PM
    #94
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Add more boost. You'll hear it better. ;)
  15. Jun 15, 2013 at 1:38 PM
    #95
    GuyWithCamera
    GuyWithCamera Well-Known Member
    Alan
    Tracy,CA
    Nissan 370Z
  16. Jun 15, 2013 at 1:47 PM
    #96
    elsenordave
    Dave Smith
  17. Jun 17, 2013 at 5:39 PM
    #97
    Lord Helmet
    Nick
    '24 X3 M40i
  18. Jun 17, 2013 at 6:40 PM
    #98
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    Trigger pulled Intake on its way... Thanks for the help man.
  19. Jun 17, 2013 at 8:31 PM
    #99
    MagneticTaco
    Kiel
    Louisiana
    2013 DCSB Magnetic
    Which one did you get?
  20. Jun 18, 2013 at 3:09 AM
    #100
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    Oops, Volant with the powercore filter..
