2013 Tacoma cranks won't start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gatorfan77, Oct 7, 2022.
  1. Oct 9, 2022 at 6:13 PM
    Gatorfan77
    Gatorfan77 [OP] Active Member
    2013 Gray Tacoma Prerunner SR5 V6
    I have a funky test light by Kobalt; tests ac and dc, has little lights at 6v, 12v, etc up to 240v. When I check the battery it reads 6v, 12v is dimly lit. hooked it up to position 1, light connected to positive battery post, other lead connected to position 1. It's reading 6v (12v) with ignition on and when cranking. I noticed it stays on for a few seconds after i turn off the ignition switch until there's a faint click and it goes out.
  2. Oct 9, 2022 at 6:18 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yea you need a standard incandecent test light.
    Just for grins have you tried swapping the C/OPN and Fuel Pump relays with known good ones?
  3. Oct 9, 2022 at 6:25 PM
    Gatorfan77
    Yea, I have 2 new ones that I put in the C/OPN and Fuel Pump slots and no change. Do you think its the signal from the PCM?
  4. Oct 9, 2022 at 6:56 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Will the pump run if you jump pins 3 and 5?
  5. Oct 9, 2022 at 7:09 PM
    Gatorfan77
    Just tried and it didn't work, had my vm on the black/red wire and still not showing 12v. Also couldn't hear anything from the fuel pump area
  6. Oct 9, 2022 at 7:11 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    This was with the key on?
  7. Oct 9, 2022 at 7:12 PM
    Gatorfan77
    yes, key on and cranking
  8. Oct 9, 2022 at 7:16 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ok check the voltage at pins 3 and 5 when you jump them.
  9. Oct 9, 2022 at 7:25 PM
    Gatorfan77
    Holy sh--! When I did that it just tried to fire and start!! there was no voltage reading on the vm though(?)
  10. Oct 9, 2022 at 7:27 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Are you sure your meter ground is good and your meter is working properly?
  11. Oct 9, 2022 at 7:31 PM
    Gatorfan77
    Okay, ground was not good, repeated and got 12v at ON and Cranking, tries to run then dies. At least it seems to be getting gas now
  12. Oct 9, 2022 at 7:40 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Are you hearing the pump run when you jump it?
  13. Oct 9, 2022 at 7:44 PM
    Gatorfan77
    No, I can't hear the pump at all.
  14. Oct 9, 2022 at 7:49 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ok check your voltage on the Black/ed wire at the resistor again with it jumped, if you have 12v at pins 3 and 5 with it jumped but not at the resistor you have a bad connection between the relay and there.
  15. Oct 9, 2022 at 7:51 PM
    #35
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’m rooting for you! C’mon baby!
    TnShooter, Gatorfan77[OP] and Dm93 like this.
  16. Oct 9, 2022 at 7:53 PM
    #36
    Gatorfan77
    Do I leave the jumper in 3 and 5 when I check the resistor?
  17. Oct 9, 2022 at 7:55 PM
    #37
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes, we are trying to determine where the voltage drop is.
  18. Oct 9, 2022 at 8:02 PM
    #38
    Gatorfan77
    No voltage reading at the resistor, tries to start but can't, I think I hear the fuel pump running for a few seconds after I turn the ignition off.
  19. Oct 9, 2022 at 8:06 PM
    #39
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    but you have voltage at the relay socket with it jumped?
    That's probably the secondary air pump your hearing.
  20. Oct 9, 2022 at 8:11 PM
    #40
    Gatorfan77
    Yep, voltage at relay with resistor jumped, on and cranking, still trying to start, the sound is coming from the fuel pump. Haven't heard it before, you can't miss the noise from my secondary air pump!! Way different!
