2013 Touch screen Bluetooth Phonebook while driving
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mtnwrks, Oct 22, 2012.
  1. Oct 22, 2012 at 7:06 PM
    mtnwrks
    mtnwrks [OP] Member
    BC
    Tacoma TRD
    Hi There,
    I am very new here, my new truck is 5 days old and there is something bugging the crap out of me.
    There is some sort of Safety Mode the bluetooth phone system goes into while moving. Is there a way of disabling it? I have read about nav systems having the same sort of thing and hidden menus on the head units to disable it.
    What happens in my truck is the phone book is disabled while moving. I am all about safe driving however this also turns off phone book look up of the calling contact. Therefore you only see their phone number, not their name. This is stupid as while driving I only wish to talk to important calls or callers and not memorizing all of thier numbers has created a pain.
    Any help?
    Thanks
  2. Oct 22, 2012 at 7:15 PM
    batchelor22
    batchelor22 Well-Known Member
    Jameel
    BC, Canada
    Hi, I also have a new Tacoma here in BC. I have not noticed what you noted in my truck and numbers that are stored in my phone book do appear on screen with name and number when a call is incoming. Do you have the Nav. Entune system? Mine is a TRD Sport.
  3. Oct 22, 2012 at 7:52 PM
    Spruced UP
    Spruced UP Well-Known Member
    Eric
    Jacksonville, FL
    2013 DCLB PreRunner TRD Sport, Spruce Mica
    Can you just pick up your phone and use a voice dialing app?
  4. Oct 22, 2012 at 9:47 PM
    mtnwrks
    mtnwrks [OP] Member
    BC
    Tacoma TRD
    Mine is also the TRD Sport stereo.
    If I have the phone screen up (the one where you can dial or view contacts on the screen of the stereo) and I and driving the dial buttons and contacts tab black out. once I stop they appear. then, when I start again they go back to black.
  5. Oct 22, 2012 at 9:50 PM
    batchelor22
    Jameel
    BC, Canada
    Odd, mine definitely does not do that. I have dialled using the contact list on my screen while driving often. Don't like it as much as voice dialling but I have gotten used to it. Something is set on yours that should not be.
  6. Oct 23, 2012 at 1:04 AM
    dsrtne1
    dsrtne1 Well-Known Member
    Michael
    Southern CA
    2013 DCLB TRD Sport
    King 2.5" Coilovers, Total Chaos UCAs, Maxtrac Spindles, 2.5" King Rear Shocks with Compression Adjusters, Wheelers 1.5" AAL, 18" Magnaflow muffler, 30" LED Lightbar, Ultragauge, Tinted Windows
    My 2013 does the same thing. I'm not sure if there's a way to disable it but I would just add any contacts that you frequently call into the speed dial since that is still accessible while driving.
  7. Oct 23, 2012 at 6:35 AM
    batchelor22
    Jameel
    BC, Canada
    My bad, I was referring to the speed dial list, not the full contact list, not that I have checked that. Will check it out today and respond again later.
  8. Oct 23, 2012 at 6:57 AM
    rclangelan
    rclangelan Well-Known Member
    Sykesville, MD
    2012 DblCb Baja Ed. (Black)
    TRD Front Skid Plate, Tacoma All-Weather Mats, BFG AT KOs (265/70/16)
    It's a safely feature that Toyota programs into their Nav systems. My 4Runner and my Baja both had the same, annoying feature. If you look in the back of your owners manual, it lists the dealer-editable features. The Nav system unlock is one of them. But then you have to find a dealer willing to tamper with a safety feature on a new car.
    I have found the voice command to be more robust than some I've used. My Hyundai Elantra doesn't have the Nav lock on it, which is nice. But its voice command has a harder time picking up commands than the Toyota. Trade off.
  9. Oct 23, 2012 at 7:46 AM
    mtnwrks
    mtnwrks [OP] Member
    BC
    Tacoma TRD
    Numbers stored in the speed dial do not come up when the phone rings while moving. (Ie. only the number displays. Not the contact name.).
  10. Oct 23, 2012 at 2:47 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2013 Tacoma DCSB 4x4
    DTRL,HID's, Redline Elite Hood Struts,IVD Coilovers and Rear Shocks W/ Ext. Res.,N-FAB Light Bar W/ KC Titanium Lights, Alcan AAL,Wet Okole's, URD T.C.A.I. M/T Classic Lock's BFG AT, Chrome TC UCA'S,TRD Exhaust, Bed Mat,Painted Roof Rack,Access LE,Weathertech's F&R,P&L Lock
    I was looking to get the '13 Taco because of the Nav / BT feature. I like it more because of tr music streaming. The ph rang while on a test drive Nd it only showed the ph no. Not the name o the contact. I will have to research it some more. Thanks for letting me know so that I can look for it.
  11. Oct 27, 2012 at 3:43 PM
    mtnwrks
    mtnwrks [OP] Member
    BC
    Tacoma TRD
  12. Nov 3, 2012 at 3:52 PM
    mtnwrks
    mtnwrks [OP] Member
    BC
    Tacoma TRD
    does anyone know if there are hidden menus on any Toyota head units?
  13. Nov 3, 2012 at 5:57 PM
    rubenc87
    rubenc87 Cobra
    Texas
    I was trying to open the email , pics and such. No luck. The guy at the dealership said that it has limits with the iPhone because of apple security. You might have better luck with the android as far as opening the other menus.
  14. Nov 3, 2012 at 5:58 PM
    rubenc87
    rubenc87 Cobra
    Texas
    I will keep trying, I have only had the Taco for a few days.
  15. Nov 27, 2012 at 2:29 PM
    Gary33031
    Gary33031 New Member
    Homestead, Florida
    Tacoma SR5
    Pop and Lock Tail Gate Lock
    I just got my 2013 Toyota Tacoma last Tuesday. My screen contact list and dial pad also disappears when truck is moving. Only when you are stopped will the contact list and phone number touch screen appear. I can access my speed dial lists while the truck is moving. Never heard of this before and the owners manual doesn't address it. I'd be interested if someone fins a work around.
  16. Nov 28, 2012 at 4:20 AM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    Look into a product called a lockpic from a company called coastal tech. They make nav/phone dial system unlocks as well as video/backup cameras for various makes and models of cars...
  17. Nov 28, 2012 at 5:15 AM
    rubenc87
    rubenc87 Cobra
    Texas
    Do you happen to know if its a PNP? Also is it geared for factory or aftermarket H/U? Thanks for the info.
  18. Nov 28, 2012 at 5:41 AM
    rubenc87
    rubenc87 Cobra
    Texas
  19. Nov 30, 2012 at 6:41 PM
    Jason8224
    Jason8224 New Member
    Campbellton NB
    13 TRD
    i too have a 2013 Taco in NB Canada. Mine does the same thing. When driving I can only access my call history not my main phone page. Would love to find a way around this. Keep us posted!!!
  20. Nov 30, 2012 at 6:43 PM
    Jason8224
    Campbellton NB
    13 TRD
    Kind of glad to hear its not just my Taco doing this!!! My wife drives a 2011 4 Runner and it is voice activated and it is a nice option!!!!
