2013 Toyota Tacoma 4x4 V6 6,400 lbs towing capacity?
Discussion in 'Towing' started by sunflower2013, Jan 21, 2013.
  1. Jan 21, 2013 at 11:14 AM
    sunflower2013
    sunflower2013 [OP] New Member
    We are looking at buying a 2013 Taco 4x4 V6 because it is listing a 6,400 lb towing capacity. When I read reviews online I hear that we should spend our money on a larger truck for stability. The trailer we are looking at towing is around 3800 lbs empty so we're thinking it won't be over 5,000 lbs.
    Is there anyone that would highly recommend the 4x4 V6 for towing safely across country, hills, mountains, etc?
  2. Jan 21, 2013 at 11:18 AM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    Should be fine, make sure your truck has the tow package, and welcome to TW.
    BC Hunter and hoodboogie like this.
  3. Jan 21, 2013 at 11:20 AM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
    X2 towing package and you'll be good to go.
    BC Hunter likes this.
  4. Jan 21, 2013 at 11:22 AM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    If the truck's primary duty was towing long distances, I'd go full-size, but that's me. Your weight will be within the limits, but you'll definitely feel the weight behind it. Your gas mileage will be horrendous and I do think you will get blown around. IMO, these trucks are good for light and occasional tow duty, but you might get by OK with a trailer that size.
    That being said, if you do get a Tacoma, definitely put a brake controller on it. That will help a lot.
  5. Jan 21, 2013 at 11:22 AM
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    + weight distributing hitch, towing bible is a sticky under tutorials, read it!!! It has some valuable info
  6. Jan 21, 2013 at 11:26 AM
    mick478
    Bott
    Stockton, CACA
    X2!!!
    My mileage is around 11-13 when I tow my enclosed 6x12 v-nose, loaded its around 3000-3500 lbs, however it tows like a dream, i dont get blown around at all, btw I tow it without brakes on my trailer, I know I need to install em, but getting along fine w/out for now
  7. Jan 21, 2013 at 11:53 AM
    Rich1790
    Rich1790 Well-Known Member
    Rich
    Clearwater, FL
    13 TRD SPORT
    Rims, Tints, Weather Techs
    Same here, never been blown around and I towed a little over 5k lbs (including trailer) from NJ to FL, no issues and it was my first time towing anything. Gas mileage does get pretty bad. If you plan on towing heavy loads a lot I would get a full size. I rarely tow anything and don't need a huge truck.
  8. Jan 21, 2013 at 11:59 AM
    TexAggie
    Eric
    Houston, TX
    OME Lift
    You can also get a 5.7l tundra right now for about the same price as a taco. Just a thought.
  9. Apr 20, 2013 at 9:42 AM
    Dccustoms6
    Dccustoms6 New Member
    plymouth
    2013 tacoma Quad cab sport
    I bought a 13 tacoma quad cab with the tow package in jan 13. I tow a 5000lb camper. First trip was ny to mass. I have a weight distribution hitch. Get 9mpg on the hills, and about 11 highway driving at 65-70. Tows well. Anything more than 5000 i would buy a tundra with the 5.7.
  10. Apr 20, 2013 at 12:50 PM
    taco206
    taco206 Well-Known Member
    Pushing it for cross country and big hills. I assume you're looking at a travel trailer. Most difficult thing to tow. Not only because they are so tall, long and top heavy. But they usually have small wheels. Like 13 and 14 inch. Which isnt a good combo when the wind starts pushing it around and that gets transferred to you in the truck. Completely different feeling if you were for example towing a 10k gvw flat bed trailer with a low slung car on top of it. It may equal out to the same weight (or more even) but you have the weight low and more compact and you are rolling on 225-75-15 inch tires which are pretty meaty compared to travel trailer tires.
    A couple Sundays ago I was hauling back a new (old) tractor from Boise to Seattle using said 10k gvw trailer with my dads 2005 GMC Sierra 2500hd crew cab. Probably 6500 pounds trailer weight and thats a 7000 pound truck. It was very windy and stormy in Oregon and the Blue mountains, I was really feeling being pushed around (and this is just with a tractor, not a giant box). Then it would get alot better and then another strong gust hits. I couldnt imagine towing a big tall travel trailer in those kinds of conditions using a compact truck.
    For cross country towing, hills, mountains look into a bigger truck.
  11. Apr 30, 2013 at 8:59 PM
    jeffwesley
    jeffwesley New Member
    Jeff
    Louisiana
    2012 Tacoma TSS
    I've got a 2012 quad 6 cylinder. It is not a tow package. I added a hitch and will be adding brake controller. I have a couple of questions. First, what does the tow package have that the other doesn't? I am looking at a 19 ft. toy hauler that has a wt. of 5300 lbs. dry. Loaded will probably around 6500 lbs.
    I'm looking for comments from anyone who has experience with this type set up, as well as any opinion as to if it would be worth the investment in the trailer.
  12. May 1, 2013 at 7:35 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    You'll be fine with a Tacoma.
    Most people will likely tow their campers ~5000 miles throughout the life of their truck and drive around empty for the other 195,000 miles.
    BC Hunter and TacoManOne like this.
  13. Jun 2, 2013 at 12:07 PM
    bdemick
    bdemick Member
    Federal Way, WA
    2006 Tacoma Dbl.Cab 4x4 TRD
    I have a 2006 Tacoma Double Cab 4x4 Short Bed, automatic V6 with Tow Package and with two adults I tow a Keystone Passport 2650BH 26ft travel trailer. The trailer weighs 4960lbs unloaded and between 5600 & 5800 lbs loaded. I use an Equal-I-zer Brand 4 point weight distribution hitch with built in sway control and a Prodigy P2 brake controller. While this is quite a load for the Tacoma at no time does it feel unsafe, sway or bounce. I tow in 4th gear and at 60 mph I'm turning 2500 rpm. At inclines I drop into 3rd gear and turn 3500 rpm. My fuel mileage takes a big hit and I get between 10.5 and 11.75 mpg depending on inclines and road conditions. Not the ideal tow vehicle for a trailer this size, but it does an OK job. Just take your time and don't be in a hurry! The Tacoma is a beast!
    Attached Thumbnails [​IMG]
  14. Jun 3, 2013 at 5:45 PM
    ttubb
    ttubb Member
    Terry
    Tucson/Crested Butte
    Tacoma TRD Off Road 4WD
    For sure install the transmission cooler. The non-tow package coolers is just a loop in the radiator. The tow package has a stand alone cooler. I have a scan gauge and I can read trans temps and for sure you want a cooler. Also use an equalizer hitch with this rig. T
  15. Jun 20, 2013 at 10:01 PM
    CampGuy
    CampGuy Well-Known Member
    Dmitry
    California
    2013 4x4 TRD-Sport
    Wow, man!
    It's very impressive.. I hope it's not going to were-out the vehicle..
  16. Jun 21, 2013 at 4:18 PM
    bdemick
    bdemick Member
    Federal Way, WA
    The Tacoma doesn't feel stressed at all. It brakes with ease, accelerates nicely, and I don't let the transmission hunt between gears at all. There are a few times I wish I had a bit more power and I watch my weight, taking with me only what's nessesary. All in all pretty good performance for a truck this size hauling this much of a load. :)
  17. Jun 21, 2013 at 7:31 PM
    campthewestcoast
    campthewestcoast Oceanfisherman
    Napa, CA
    Power extend/retract towing mirrors,brake controller,30amp charging system for TT,snug top camper
    Look at Hi-lo Towlite 3800lbs 22ft long I get 14mpg! Pictures of my rig in my gallery. Hydralics rise the top section when I get to the campsite. No problem towing this rig.
  18. Jun 22, 2013 at 10:26 AM
    bdemick
    bdemick Member
    Federal Way, WA
    I love the Tacoma for everyday travel & use and tow with it 6 or 7 times a year. Is it the ideal tow vehicle for a large travel trailer? No, but it does a good job and I would hate to move up to a full size pickup to drive around the 345 days a year that I'm not towing.
    I have a 2006 Tacoma Double Cab 4x4 Short Bed, automatic V6 with Tow Package and with two adults I tow a Keystone Passport 2650BH 26ft travel trailer. The trailer weighs 4960lbs unloaded and between 5600 & 5800 lbs loaded. I use an Equal-I-zer Brand 4 point weight distribution hitch with built in sway control and a Prodigy P2 brake controller. While this is quite a load for the Tacoma at no time does it feel unsafe, sway or bounce. I tow in 4th gear and at 60 mph I'm turning 2500 rpm. At inclines I drop into 3rd gear and turn 3500 rpm. My fuel mileage takes a big hit and I get between 10.5 and 12 mpg depending on inclines and road conditions. Not the ideal tow vehicle for a trailer this size, but it does an OK job. Just take your time and don't be in a hurry! The Tacoma is a beast!
    By the way, the Passport Trailer has a spread-axel design where the front axel is 10" further forward than most other trailers to better distribute weight and control sway. There are times when I would like a bit more power, but than again I have passed full size pickups on inclines towing trailers much smaller than mine.
    When I retire in a couple years I just might move up to a full size because I will be towing the trailer much more often.
    I did notice that Toyota lowered the towing capacity on the new Tacomas from 6500 to 6400 lbs; only 100 lbs, but makes me wonder why.
    Just an update. As I am approaching retirement and will be towing this trailer more often & for much longer distances, I upgraded to a 2013 RAM 1500 4x4 with 5.7 liter Hemi and it tows this trailer effortlessly and I'm carrying about 800 lbs. more weight. If not for retirement though, I probably would still be towing with the Tacoma.
  19. Jun 23, 2013 at 6:29 PM
    jeffwesley
    Jeff
    Louisiana
    2012 Tacoma TSS
    This week I purchased a 25RL Avenger with a dry wt. of 4951 lbs. I am pulling it with a 2012 TSS double cab without a tow package. I do plan to install a transmission cooler and maybe an oil cooler. After buying the TT I towed it from the dealership to a campground about 5 miles away. While the Tacoma seemed to have plenty of power and the transmission wasn't hunting, the stability at 55 MPH on the interstate was frightening. The next morning the guy camping next to me helped adjust the wt. distribution tow hitch before I made the 1 1/2 hr. trip home. With the fix I was able to comfortably travel at 65 without feeling the serious sway that I experienced the day before. While I acknowledge that a full size pickup is better suited to towing a travel trailer, I feel like the taco meets the challenge. Of course, I live in S, Louisiana where our topography is mostly flat. I'm not sure what my opinion will be when we take our first trip to the mountains.
    BTW: that 75 mile trip home used about a half tank of fuel.
  20. Jun 23, 2013 at 9:57 PM
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    For towing long distances I would say a diesel or ecoboost ford. I tow a 4500lb Centurion every week, and with gear and combined 60 gallons of fuel plus pasengers, its nice and heavy. Using a TRD 4x4 DCLB with tow package. Tugs it along well, but gets horrible mileage, like 150/tank
