2013 Toyota Tacoma double cab rim questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by geekhouse23, Aug 22, 2013.
  1. Aug 22, 2013 at 9:08 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    5-lug runs 15". Different calipers (completely different suspension).
    Stock for 6-lug is 16", but some aftermarket 16" wheels won't clear either!
  2. Sep 4, 2014 at 5:38 PM
    longfellow1984
    longfellow1984 Member
    2014 Toyota Tacoma Off-Road Pkg
    3" suspension lift with 285/75/16 BF Goodrich All Terrain Tires
    I have the same setup as you Beavis0076 and I was just wondering after u put the wheel spacers on did you have to trim the wheel well at all or was it fine? I am getting a little rub on the upper control arm without the spacers and was wondering if its worth it to get the spacers and if other things will need trimmed.
