2013 Tundra questions
Discussion in 'Tundras' started by greengo, Jun 4, 2013.
  1. Jun 4, 2013 at 7:21 AM
    greengo
    greengo [OP] Member
    Justin
    Northern AZ
    2012 double cab
    I thinking of getting a new Rock warrior. Can I run 315 tires on the stock fake lockes with a 2 or 2.5 lift? I have a double cab tacoma and the bed space and towing weight is killing me. I am not sure if I want the extra cab or crew cab. Is the extra cab interior size close to the interior of a double cab tacoma? Thanks
  2. Jun 4, 2013 at 9:41 AM
    TruckyTruck
    TruckyTruck Well-Known Member
    Tundra Crewmax TSS Off-Road 4x4, sr5/leather
    Not sure on the lift question other than you should read about the tundra and its vsc befor you lift. I had a double cab tacoma, yes the double cab is a whole lot bigger and you get the longer bed with it. I have the crewmax and there is a ton of room.
  3. Jun 10, 2013 at 12:12 PM
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    You can run that tire size, but you will need to trim the skid plate and a few other little areas. Ive seen guys rocking 35's with just a spacer / or Bilstein 5100 lift.
