2014 6 SPD TX Baja - custom gearing... help please!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by corycalabrese, Oct 22, 2015.
  1. Oct 22, 2015 at 3:32 PM
    corycalabrese
    corycalabrese [OP] Member
    Cory
    NJ
    2014 Supercharged TRD Baja 6spd Manual
    TRD Supercharger Kit
    The gas mileage thing I mentioned for the many others with my setup that have mentioned the lack of a good OD gear... I could care less, I have the truck for nearly 2 years and have 8000 miles on it... not a huge deal... its the drone of the motor w/ trd exhaust at over 3000 rpms for hours on a long trip that I'd like to change... because aside from that... and the clutch pressure plate being overpowered by the s/c here and there, I LOVE THIS TRUCK!!
  2. Oct 22, 2015 at 3:33 PM
    Yota64
    Yota64 Professional Threadjacker
    OP look at my post right before yours. Yes, .6517 was the gear ratio.. BUT those are still based on my example. Need to know your actual RPMs which it looks like someone already stated.
    Yes the only real option is IF you can, have a custom gear made, but I'm interested in that FJ swap...
  3. Oct 22, 2015 at 3:39 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    URD has some nice clutch set ups. I have the stage 3+, and it's like an on/off button. http://urdusa.com/store/Clutch-and-Flywheels-Clutches-by-URD/c178_197/index.html
  4. Oct 22, 2015 at 3:42 PM
    corycalabrese
    Cory
    NJ
    Thank you all for your insight so far. At 80 mph I am just over 3100 rpm... for the sake of the percentage, I think we're close enough... a .65 to .73 gear or anything in between would be a great improvement. Now... iiiiiiif the 6th gear combo from the FJ was interchangeable with my trans... that would be ideal... all toyo parts and all is good. This I don't know....
  5. Oct 22, 2015 at 8:22 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    everythign discussed in this thread is completely moot point.
    The price you are going to pay to get cruising rpms down is NEVER going to be paid back over the lifetime of the truck by gained mpgs.
    username likes this.
  6. Oct 22, 2015 at 9:50 PM
    Yota64
    I think he is more concerned with not making the engine piss its pants.
  7. Oct 22, 2015 at 9:50 PM
    nd4spdbh
    SoCal
    pff.... the 1gr wouldnt have an issue running 4k rpms all day long.... 3k is a cake walk.
  8. Oct 22, 2015 at 10:14 PM
    Yota64
    Do you think being blown would hurt reliability at those RPMs? I am unsure of how the S/C works. Is it engaged at top speeds? Or only when you hit it for acceleration?
  9. Oct 23, 2015 at 7:36 AM
    nd4spdbh
    SoCal
    supercharger is always spinning and dependent on engine RPMS.
    with nose cone oil change intervals of 100k miles.... i wouldnt worry one bit about its longevity.
  10. Oct 23, 2015 at 8:03 AM
    Yota64
    Nose cone oil change? 100k miles? WAT
  11. Oct 23, 2015 at 9:19 AM
    nd4spdbh
    SoCal
    yeah the small gear train in the nose of the super charger and bearings are bathed in a little oil with 100k mi oil change intervals as far as i know.
  12. Oct 23, 2015 at 9:20 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    The supercharger is sealed and the bearings have their own oil.
  13. Oct 23, 2015 at 1:09 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    The Baja has about the same suspension as the Pro...I've seen posts of a Pro with 285's and no rub issues. You say you don't really wheel the rig, you might be able to run 285's as is...
  14. Oct 23, 2015 at 1:15 PM
    nd4spdbh
    SoCal
    285's will rub if you actually flex the truck.
  15. Oct 23, 2015 at 1:20 PM
    #35
    RKCRUZA
    Bob
    Placerville, Ca
    From what the OP said, he doesn't do any serious wheeling with the truck. There have been a couple of posts from Pro owners who were running 285's on the stock Pro / Baja wheels without any issues. Just figured it would be a cheap way to achieve his goal if the truck is pretty much street driven. He may have to drop his mud flaps but supposedly they clear the UCA's and didn't have any serious rub issues with the stock wheels from the Pro's.
  16. Oct 23, 2015 at 1:39 PM
    #36
    nd4spdbh
    SoCal
    but the amount the OP wants to drop rpms... the 7.3% difference you get from a 285/75R16 vs a 265/70R16 is pretty much nill.
