2014 Base Camp Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Base Camp, Feb 19, 2015.
  1. Mar 23, 2016 at 2:29 PM
    #601
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
  2. Mar 23, 2016 at 5:19 PM
    #602
    Base Camp
    Base Camp [OP] Instagram: @willismtc
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    ragincajun35 likes this.
  3. Mar 23, 2016 at 8:12 PM
    #603
    ragincajun35
    ragincajun35 Well-Known Member
    Spencer
    Louisiana
    2015 DCSB MG TRD Offroad
    See Builds....
  4. Mar 24, 2016 at 7:39 AM
    #604
    Base Camp
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    Yeah I like the design of AG's better. It also comes with a 4" greaseable shackle. I had looked into a 5" but I'm concerned about getting my pinion angle off by too much anyways so maybe 4" is a better choice.
    Still think I'm going to run the B110 and flip the ubolts.
    Now for bumps... Are the wheelers worth it in the rear? Definitely not looking at the timbrens. Also, how can I estimate how much I will need to raise my stops before cycling it with the new components? Wheelers has 1/4" and 3/8" spacers. It would be nice to get it all dialed in with parts on hand, but sometimes life isn't that easy...
  5. Mar 24, 2016 at 11:08 AM
    #605
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    hey man how do you like those backup lights on your roof? Thinking of getting some cheap ones form Amazon
  6. Mar 24, 2016 at 11:46 AM
    #606
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I like my Wheeler's bumps.
    Once I raise my rear shock upper mount, I intend to move the bumpstop to the frame above the axle, and not use the stand. That way, I can pick up a couple more inches of up-travel (making sure not in invert the spring.)
  7. Mar 24, 2016 at 12:21 PM
    #607
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    How are you gaining up travel from a shock mount relocate and moving the bump stop to the frame?
    Doing custom shenanigans?
  8. Mar 24, 2016 at 1:28 PM
    #608
    Scott B.
    Scott
    Georgia
    Somewhat.
    Moving the upper mount up (while running a longer shock) allows the lower end of the shock to travel farther up. So, as long as the springs can handle the flex, and the tires don't hit the fender, you have increased upward travel.
  9. Mar 24, 2016 at 1:41 PM
    #609
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    What shock length/shock do you have that you're able to move the upper shock mount and not the lower without fear of bottoming he shock out? Better question is how far up are you moving the upper shock mount?
  10. Mar 24, 2016 at 2:06 PM
    #610
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Mind blown
  11. Mar 24, 2016 at 4:11 PM
    #611
    Base Camp
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    Just spent the past hour battling my rear brake lines... :duel:
    I won.
    Bsheriff11 likes this.
  12. Mar 24, 2016 at 4:19 PM
    #612
    Base Camp
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    And the tires dont hit the shock. Theory make sense to me... Im just now trying to learn about all of these custom shenanigans. Troofully, I dont know jack.
    Acerwin likes this.
  13. Mar 24, 2016 at 4:20 PM
    #613
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    I'm in the same boat
  14. Mar 24, 2016 at 4:30 PM
    #614
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Either stay stock brackets or go through the bed. These in the wheel well shock towers are silly.
  15. Mar 24, 2016 at 4:38 PM
    #615
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    Agreed, there's not much more droop gained from it compared to stock location.
    The b110 will do great for you in the stock location Marshall. With 10.94" travel, Add in the shackle flip and you'll be drooping nearly as much as my set up for less money and less work.
    Pirhett likes this.
  16. Mar 24, 2016 at 4:40 PM
    #616
    ckeene9
    Chesterfield, VA
    See Build Thread
    Absolutely! An inch of travel at that point is a waste of time and money.
  17. Mar 24, 2016 at 5:04 PM
    #617
    Base Camp
    Willis
    Roanoke, VA
    '14 Base Model 4x4
    Love and use them all the time. Most people like to have lights down in bumper cut outs. I like them up high. Prinsu made it a no brainer for me as I was able to keep them down below the mounting surface. Just drilled 2 holes in the tracks to run the wire. Quick disconnects inside the cap.
    If you leave yourself enough wire you can even turn them up and down a bit as needed.
    Pirhett[QUOTED] likes this.
  18. Mar 24, 2016 at 6:15 PM
    #618
    Pirhett
    Rhett
    San Diego
    Stock...
    Sweet man! Yeah I'm planning on putting two on my bed bars under my cvt racing back and two facing sides! Also working on 8 of the rock lights!
  19. Mar 24, 2016 at 6:29 PM
    #619
    Base Camp
    Willis
    Roanoke, VA
    '14 Base Model 4x4
  20. Mar 24, 2016 at 6:29 PM
    #620
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
