2014 [Code ED] "Entune Audio Plus" is not 'Entune'?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pgtr, Nov 1, 2013.
  1. Apr 2, 2014 at 4:48 AM
    hankk
    hankk Active Member
    hank
    Connecticut
    Was 2003 SR5 then 2014 SR5 now 2017 TRD Sport
    Hey folks, along the way I noticed that someone was having issues with text messages appearing on the entune. I too have an issue and hoping that someone can lead me to nirvana.
    I'm a proud owner of my second Taco. the 2014 SR5 came with this fancy entune. My Samsung S3 syncs up no problem and does all the bells and whistles. BUT the text messages do not appear on the head unit. Pairing and re-pairing did not solve the issue. Some folks outside of this forum are blaming 4.3 Samsung updates.
    Any leads out there.
    Thanks folks!
  2. Apr 2, 2014 at 5:08 AM
    AEmedic
    AEmedic Well-Known Member
    Boise, ID
    2014 DCLB 4X4 TRD Sport Supercharged
    TRD Supercharger, Toytec Adj. Coil-Overs, Bilstein 5100's, JL Audio system w/Kenwood DNX9980HD HU
    I'm not sure on your phone, bur on my iPhone I needed to change a setting on the phone that allowed for SMS data or something like that.
  3. Apr 2, 2014 at 5:23 AM
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    My Entune w/nav was like that until I upgraded to Android 4.4 from 4.1; after that I could send.
  4. Apr 3, 2014 at 6:09 AM
    hankk
    hankk Active Member
    hank
    Connecticut
    OK thanks folks,
    So I've got a S3 and the 4.4 roll out is not for a while yet.
    However, I just chatted with Verizon for about 30 min. And they suggested that I limit the number of messages on my phone since the system and not be able to handle the load. I have to admit that I do (read did) have a LOT of threads going on my phone, so I killed almost all of them. As I write this I'm on my Triumph today so won't be able to try it on the truck till tonight. I'll keep you posted.
    What's strange is that if that was the case the system would load what it could and truncate the rest? We'll see. After that I'll have to wait for 4.4.:eek:
  5. Apr 3, 2014 at 6:12 AM
    rickoshay45
    rickoshay45 Well-Known Member
    Rick
    Sanford Florida
    2015 Camry SE
    My S5 works fine but I don't use text a lot and tend to keep old stuff cleared out. I like to free up memory as much as I can.
  6. Apr 3, 2014 at 6:22 AM
    TheMuffinMan
    Coeur d'Alene, ID
    As an IT guy I don't see much basis for that, though it is possible. The honest truth is it's difficult to program for android and all of it's variants.
  7. Apr 3, 2014 at 6:40 AM
    SSG665
    SSG665 Well-Known Member
    Georgia
    18 Tacoma
    So for an extra $680 with the Entune plus you get xm radio capability,HD radio,HD traffic and weather.IMO this is not worth $680?With the SR5 pkg do you have to get the Entune plus?
  8. Apr 3, 2014 at 6:49 AM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    It's an option per the brochure; only the Limited forces a radio upgrade.....but I'll bet for SR5's and similar it's bundled. Bet you'd have to Special order to keep the base unit.
    Update: Just checked internet dealer i work with ALL SR5 and above have the ED option (on the Lot)
  9. Apr 4, 2014 at 8:33 AM
    hankk
    hankk Active Member
    hank
    Connecticut
    OK team here's the scoop.
    I'm throwing in the towel!
    Talked/Chatted with: Verizon, Samsung and Toyota.
    The S3 with 4.3 simply will not read back text on the enTune Aduio Plus system.
    Believe me, I've gone thru every permutation imaginable with them with the phone. pair/re-pair, clearing cache, defaulting, speech to text variants, hands free. No one has been successful in fixing this.
    It's a nice to have but not critical. Will wait for 4.4.......even then it's iffy.
    cheers
    Hank:mad:
  10. Apr 6, 2014 at 4:04 PM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    I have entune plus and I can use my phone.
  11. Apr 7, 2014 at 5:32 PM
    Jason79
    Jason79 Well-Known Member
    PA
    2014 TRD OR DBL Cab SB
    Hankk, I'm in the same boat as you with a 2014 taco with Entune audio plus & a samsung galaxy S3. All seemed to work but having the radio be able to read out my text messages. This is due to (previous versions) of Android not supporting Bluetooth MAP (message access profile) the (now current 4.4 kitkat) version of Android does support Bluetooth MAP. I verified this by rooting my S3 and throwing a early release of Android kitkat (from cyanogenmod) on it. After that everything worked fine (at first.) turns out that the early release version of kitkat is simply not stable enough. My phone battery is much worse & camera constantly locks up. I think I'm going to take the phone back to a stable version & give up the Bluetooth MAP feature. Hope this helps.
  12. Apr 7, 2014 at 9:01 PM
    Eggbert
    Eggbert Well-Known Member
    PA
    '14 dcsb TRD OR Supercharged
    TRD Supercharger, MBRP DualCatback, DT Shortie Headers, Regeared with 4.56 ECGS 3rd and Clamshell, URD 2.55" Stealth pulley, AEM Methanol 5 gallon kit, URD Perf Thermostat, NST Lightweight crank pulley, URD 61lb injectors, Mishimoto Oil Catch Can, URD Fuel Pump upgrade, AEM Boost and Wideband gauges, OEM FPR Mod, RBP Black Exhaust Tips, Icon Stage 6, Fuel Octane wheels, Nitto Terra Grapplers 285/70/r17, Color match rear bumper, Color match hood with skewp, Color match grill, Color match valance, Derped grill emblem, Derped Tuffbar bullbar, OEM Skidplate, AVS Ventvisors, Bodyside Moldings, RBP RX3 nerf bars, Color Match Bushwacker Pocket Flares/Rivets, Undercover LE Tonneau, Katzkin heated leather, Bel Stir-Plus Radar, Sprint Booster, Dynamat/Hushpad, Polk dxi691 - front, Polk dx1651 - rear, Alpine KTP-445U Power Pack, Front tint 35 percent, Weathertech front mats, Smoked tail lights, LED DRLs, Coupe TRD Battery tie-down, Coupe TRD CAI Cover
    I had same issue with IOS. Felt ripped off since I heard cool things about the real Entune
  13. Apr 8, 2014 at 7:17 AM
    hankk
    hankk Active Member
    hank
    Connecticut
    Alleluia! I'm not alone.
    I'm very sorry Jason but misery love company. :eek:
    I had every intension of upgrading but after the whole Verizon/Toyota/Samsung circus (read three ring) I finally gave up simply because I don't have the brass to attempt it on my VERY functional S3. The text to speech dilemma is a "nice-to-have" but certainly not a show stopper for me. Besides Verizon is threatening to release 4.4 KitKat in the near (read 3-4 months) future so I'll wait for something a bit more stable. Fingers crossed, and hope it works.
    Many thanks to everyone that has added to the thread and helped me heal:D
  14. Apr 8, 2014 at 7:19 AM
    TheMuffinMan
    Coeur d'Alene, ID
    Get a google phone and do away with that custom UI bullcrap. :D (I have a Nexus 5)
  15. Apr 8, 2014 at 12:04 PM
    #35
    GreatCanadian
    GreatCanadian Well-Known Member
    Newfoundland
    SR5 4X4 V6
    My 2014 Canadian SR5 has entune plus, and everything seems to work fine.... except email. Sometimes it works, sometimes it doesn't! Also, only one of my email accounts works. Rarely, a second account worked. ONCE, a third account worked. But usually only one - and that isn't all the time. My phone is a BlackBerry Torch 9810.
  16. Apr 9, 2014 at 7:23 AM
    #36
    kc123
    kc123 Member
    Just bought a TRD 2014 Tacoma and my S3 messages won't work either. Looks like KitKat 4.4 will fix it. Seems they are taking their time releasing it for Samsung S3
  17. Apr 10, 2014 at 4:25 AM
    #37
    hankk
    hankk Active Member
    hank
    Connecticut
    One can only hope that KitKat will take care of the issue. Right Verizon won't even own up to a date. Just saying 2-4 months.
  18. Apr 17, 2014 at 8:05 PM
    #38
    cheebo10
    cheebo10 New Member
    mike
    new orleans
    tacoma 2014 access cab
    my satellite traffic map will not change as i travel from city to city..any help
  19. Apr 27, 2014 at 8:34 PM
    #39
    ctoro99
    ctoro99 New Member
    Carlos
    Baltimore, MD.
    Blk. PreRunner SR5
    Hello, I'm Carlos, 1st time poster on this forum as I just got my 2014 Taco last week and became a member. Like Jason79 and hankk, I have the Entune Plus system and can't get the read text function to work - again. Here's what I find to be a tad different, last week when I first got the truck my daughter sent me a text with a few choice words (she's 27) and the system read it to me flawlessly. That was the only text that ever came thru and I have not been able to get it to work since. I have had the Galaxy S4 with T-Mo for about a year running Android v. 4.3 Jellybean. I just find it strange that it did work one time and then - nothing. I can't transfer messages either with an error to the effect of " Messages can not be uploaded", although my directory and recent calls transferred fine. I would like to get this to work since I think the function could be very practical (if it worked), especially here in the great state of Maryland. All else seems to be working fine. Any thoughts, comments or suggestions are very welcome.
  20. Apr 28, 2014 at 5:07 AM
    #40
    SC boy in NE
    SC boy in NE New Member
    Robert
    North Andover, MA
    14 stock 4x4
    Google play does work with my Galaxy S4. I think this is one of the best parts of the entire head unit. I have to press the up arrow to skip to next song. I won't keep the satelitte radio sub since it goes out every time I pass under a bridge so google play is nice to have.
