2014 Cold Air Intake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mossTRD, Jan 6, 2014.
  1. Jan 6, 2014 at 7:00 PM
    mossTRD
    mossTRD [OP] New Member
    Adam
    North, Ga.
    2014 TRD Sport Double Cab
    Does anyone know if a 2012 or 2013 intake will fit on a 2014 4L? I cant find anything online.
  2. Jan 6, 2014 at 7:11 PM
    AZ hunter
    AZ hunter Well-Known Member
    Kade
    Tucson
    '14 DCSB TRD OR
    Engine Mods: URD Cold Air Intake Interior Mods: Weathertech Floor Liners Exterior Mods: Plastidiped Emblems
    You shouldn't have any issues installing a '12 or '13 on a '14.
    I just installed a URD a couple week ago on my '14 and I'm thrilled with it. It works on '05 plus.
  3. Jan 7, 2014 at 6:29 PM
    mossTRD
    Adam
    North, Ga.
    Thank you very much. Is it a fairly simple install?
  4. Jan 7, 2014 at 6:37 PM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    Are you wanting a short ram intake or a true cold air intake? Here's a couple things: A short ram intake, even with the shroud, still sucks in warm engine bay, causing you to lose power air compared to the stock airbox. A true cold air intake will give you the most power increase, at a cost. Since the pipe bends and dips around everything and ends up somewhere near your wheel well, you have a chance of sucking in water into your engine if you go through a puddle, or even just a bad rainy day. I would just pop in an aftermarket hi-flow filter and be done with it. I hear good things about the AFE dry ones.
  5. Jan 7, 2014 at 6:38 PM
    Silence9
    Alberta, Canada
    Yes they are one of the more simple upgrades to install. ;)
  6. Jan 7, 2014 at 7:36 PM
    AZ hunter
    Kade
    Tucson
    '14 DCSB TRD OR
    It was slightly intimidating because you have to cut a hole in the radiator support for the pipe to pass through. It's really no big deal though. Other than that it is a very simple install and URD has excellent customer support. It is a true cold air intake so the filter sits in front of the radiator. URD offers water shields and pre-filters if you are worried about water like mentioned above.
