2014 Entune Rear camera/ After market replacement?
Discussion in 'Audio & Video' started by Ole Shawn, Nov 21, 2013.
  1. May 19, 2014 at 4:52 AM
    #41
    shawusmc04
    shawusmc04 Well-Known Member
    Georgia
    2014 Trd sport dc 4X4
    Tint 20% front and back. Plasti dip badges. Removed Toyota and V6 badge from tailgate. All my badges are only TACOMA. Door sill protectors. Rubber bed mat. Future mods= audio: Alpine ine-z928hd with perfect fit, 2 jl audio 12tw3 with jl hd750/1 under passenger seat. Fatmat sound deadener back wall and inner doors. Not sure on door speakers yet. Suspension= 3 inch spacer lift with 2 inch rear blocks. New bump stops, rear shocks. toyo open country at2 xtreme 285/65/18 on xd monster.
    I have a 2014 dc with an Alpine 8 inch head unit. I have the factory reverse camera working this is how. Contact ebay user ckremernimrod1 He cant sell anything on ebay right now he got into trouble. I bought a plug and play harness from him. $25 includes shipping. It plugs in my factory reverse camera plug. It goes from factory plug to yellow RCA plug to work in after market units. You have to splice 2 wires. 1 in main 28 plug factory adapter, its the second wire Red with silver strip. Its in the top row second wire. Put a test light on it with the ignition on it wont work then put in reverse the test light will come on. Double check to make sure it the correct wire. This tells the head unit to turn on the camera when you put truck in reverse. I used the quick splice adapters from advance auto parts. You have to cut nothing. Then you have to splice the other wire to a ground. You can use the black wire on aftermarket harness. It works great and comes with instructions. You pay the guy through paypal. I was worried because he is suspended from ebay but he is good. Takes a day or so for him to email. I think he is a computer guy that makes stuff on the side. If you dont wont to cut anything on your truck this is the way to do it. Hope this helps and good luck!!
    #41
  2. May 19, 2014 at 5:13 AM
    #42
    je3169
    je3169 Well-Known Member
    Cincinnati OH
    2014 Access Cab TRD Sport
    2" Front, 2" Back, Opti-Coat Pro, Toyo Running Boards, Kenwood DNX891HD
    Sounds Good thanks for the help.
  3. May 19, 2014 at 2:14 PM
    #43
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    Ok so I bought an aftermarket camera from alpine. It fits very tight in oem hole but does mount like the oem. No lines in camera but I have a working camera. Tapped into the oem wiring and connected the other end to the back of my radio and now I have a working camera. This was definetely an interesting project. Also the alpine camera can adjust to te oem camera and I believe that is why yours worked. I didn't have that option with my kenwood double din.
    Just happy to finally have a camera that works. I backed into a bush on my brand new not even a week old truck and put a nice scratch on my tailgate because I didn't see how far as was back. Stupid camera issue. Fixed now though.
  4. Jul 23, 2014 at 10:43 AM
    #44
    double dee
    double dee Well-Known Member
    Arizona
    I haven't had a back up camera for 2 days since i upgraded my head unit. Never resized how convenient it was until now. I found a ebay user "cellchubz" who said he makes an adapter but is out of them right now. hope that helps someone. I will be un-patiently waiting for them
    #44
  5. Jul 24, 2014 at 7:54 PM
    #45
    double dee
    Arizona
  6. Jul 24, 2014 at 8:26 PM
    #46
    DunkinDal
    DunkinDal Active Member
    South of Boston
    2015 TRD Off Road
    2014radio.pdf
    2014 radio wire diagram
  7. Jul 24, 2014 at 8:28 PM
    #47
    DaBigDogg
    DaBigDogg "Say when..."
    Jay
    Mid-Suffolk, LINY
    '22 MGM DCLB TRD OR
    Funny you say that...my taco is the first vehicle I've owned with a camera and I purposely try not to use it as I don't want to rely on it as no other car I operate has one.
    #47
  8. Jul 30, 2014 at 3:42 PM
    #48
    double dee
    Arizona
    dude... I have no idea what I was looking at there ha
  9. Dec 6, 2014 at 4:46 PM
    #49
    naishsr
    naishsr Well-Known Member
    Naish
    Exton, PA
    2019 Tacoma Pro, Dbl Cab, 4X4 Auto, Black
    I know this is an old post but I have been looking for a connector assembly to maintian the use of the factory installed back up camera in my 2014 TRD. "cellchubz" has a harness/connector assembly to maintain the use of the factory installed backup camera in aftermarket head units. Appears that there is enough demand for this solution now.
  10. Jun 8, 2015 at 9:00 AM
    #50
    ravenmad
    ravenmad Member
    Florida
    2015 DC 4x4 Taco
    5100's Soon... Pockets full of cobwebs atm.
    #50
