2014 Navigation Unit in 2013
Discussion in 'Audio & Video' started by yogster, Nov 22, 2013.
  1. Mar 7, 2014 at 8:49 PM
    #181
    robotninjasrule
    robotninjasrule Well-Known Member
    peter
    edmonton alberta
    2013 trd sport
    N25 according to the diagram posted a little while back
  2. Mar 7, 2014 at 9:00 PM
    #182
    smgcon
    smgcon Well-Known Member
    Geoff
    Vernon, BC
    2013 DBC
    :eek: Oops. I see it now.
    Thanks!
  3. Mar 7, 2014 at 9:22 PM
    #183
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    N25 I believe. Could be wrong...
    Got my wires all soldered up and ready to install. i hope im using the correct connectors... i robbed them from my 2013 controls.
  4. Mar 7, 2014 at 10:46 PM
    #184
    smgcon
    Geoff
    Vernon, BC
    2013 DBC
    sr5vic. How long did you make the harness?
  5. Mar 7, 2014 at 11:01 PM
    #185
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    Its 44" long. I just guessed and made it a bit longer than needed.
  6. Mar 7, 2014 at 11:06 PM
    #186
    smgcon
    Geoff
    Vernon, BC
    2013 DBC
    Nice work. I have to put one together this weekend. Got the pins so I will pretty much do he same so you did.
  7. Mar 8, 2014 at 12:42 AM
    #187
    fbconvert
    fbconvert Well-Known Member
    Brian
    Seacoast, NH
    2005 Tacoma Double Cab TRD Sport
    It depends on the year. In 2013 I believe its name is R15 but in 2014 it's N25. Still the same connector just a different name.
  8. Mar 8, 2014 at 9:05 AM
    #188
    robotninjasrule
    peter
    edmonton alberta
    2013 trd sport
    Nope just turn your wheel
    Unless your are replacing your spiral cable for the 16 pin version
  9. Mar 8, 2014 at 9:06 AM
    #189
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    sorry. just went out to the truck and figured that out :p
    thanks!
  10. Mar 8, 2014 at 9:21 AM
    #190
    yogster
    yogster [OP] merkwürdigliebe
    Tom
    Massachusetts
    13 Black DCLB SR5
    DCLB Black 4WD Illumination dial from 4runner, Flyzeyes LED. Hardwire GPS and Valentine1 with BlendMount mirror mount, TRD shift knob, tube steps, swapped out for signal lamp mirrors. Garmin Eco-Route HD for Bluetooth ODBII Diagnostics, 2014 Entune Plus w Navigation, Leer 100XL dome light wired to dome circuit, pop&lock tailgate and cap locks.
    I've complete my installation and all is well. 2014 Steering Wheel Controls in 2013 DCLB.
    1. Pin 9 on the S8 connector needs to be grounded. I chose to tap into the connection I already created for the Flyzeye design LEDs above the HVAC. I cut the connections and resoldered with the additional wire and put heat shrink tube. The Flyzeye design website will tell you which wire colors are for what years, I'll post here later.
    2. Pin 3 brought this back to Pin 24 on my HU 28Pin R15 connector.
    And I'll confirm here:
    Buttons are illuminated
    Left/Right/Return/Home buttons now work - though don't get too excited, more functionality was achieved by just adding Voice Control.... They mostly apply to Audio only. Meh.
    Voice Control works (that required no changes)
    All other controls continue to work as normal....
  11. Mar 8, 2014 at 9:23 AM
    #191
    robotninjasrule
    peter
    edmonton alberta
    2013 trd sport
    I noticed that too. The left right enter and return seem to only be useful in the phone menu. One huge improvement is the volume rocker location and the mute/ pause.
  12. Mar 8, 2014 at 9:26 AM
    #192
    yogster
    Tom
    Massachusetts
    13 Black DCLB SR5
    The video will not display gridlines on the monitor. They are "in" the mirror.
    This would imply that in a 2014, the grid lines come from the camera.
    Or, cannot confirm but I think I read this elsewhere, I don't think there are grid lines on the 2014, even if you had a 2014 camera. Maybe somebody with a 2014 can chime in.
  13. Mar 8, 2014 at 9:27 AM
    #193
    robotninjasrule
    peter
    edmonton alberta
    2013 trd sport
    Thanks yogster, that's the only thing holding me back from moving the camera view to the head unit!
  14. Mar 8, 2014 at 10:25 AM
    #194
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    well mine was a failure... wrong connectors... mine had the tab on the left side instead of the right. :p
    just had to order 50 1674311-1 connectors. :p
  15. Mar 8, 2014 at 12:45 PM
    #195
    yogster
    Tom
    Massachusetts
    13 Black DCLB SR5
    Right, they are useful in the phone menu, and when an iPhone is connected. It does make moving through playlists and tracks, etc, easier. Have not tried iPhone over blue-tooth. Probably similar.
    Not much use in Navigation accept for the "return" Silly me, I though one would be able to move the cursor around or stuff like that. It would be nice to be able to move through setup screens and options. Doesn't seem that's possible.
    Does move through "stations" in Pandora, something you would have had to touch screen for before. What was lacking it seems, is functionality in OpenTable or MovieTickets - don't use those much, but I have made a reservation a few times with Open Table. Even when stopped these apps, well, suck as far as moving around through the menus.
    Voice Control is good though, once you figure out key words and such. Again not so great with Pandora and other entune apps. Like Pandora, you can create a station, but it just gives you a list to choose from, then you have to go to the screen to select. Dumb. But you can create a station while moving something that could not be done without VC.
    Overall I'm happy with the swap.
    The radio cost me $200 net after I sold my 2013
    The controls were around $100.
    Misc parts and pins - $20
    $320? Not too bad, considering Toyota wants what $3500 for this as a replacement part? An as an option at purchase time, it was part of an expensive package, right?
    Feature I like the most - HD radio, Pandora, iHeart Radio. Navigation is just "OK". I find myself still using my Garmin 3590 - it also has voice control. The Garmin is just a whole lot smoother. And like I said, I have used OpenTable and MovieTickets.
    Maybe somebody might be interested in my 2013 controls - the ones Toyota wants $300 for. That would make the swap even cheaper.
    I'm not a audiophile, so this is fine for me.
    I'm done taking my dash apart, I hope. It seems no matter how hard I tried I always ended up with a few little scratches below the HVAC. I used the hair-dryer method to make them "disappear". If this radio dies, I think I'll have to kill myself before taking dash apart again. I know I won't get warranty service for the radio, so at that point, I think I'd just swap in an aftermarket.
  16. Mar 8, 2014 at 1:00 PM
    #196
    yogster
    Tom
    Massachusetts
    13 Black DCLB SR5
    I've run into that before. I just filed the little tab off. The connector still locked in firmly.
  17. Mar 10, 2014 at 8:42 PM
    #197
    tacotacoburrito
    tacotacoburrito Well-Known Member
    Handy cut sheet. Point of clarification. Is the view of the connectors and associated position numbers as viewed from where you insert the terminals into the connector?
  18. Mar 11, 2014 at 4:33 AM
    #198
    yogster
    Tom
    Massachusetts
    13 Black DCLB SR5
    The view is from the "front" of the connector, that is the side that plugs into he receptacle. Or NOT the "harness-side".
    So
    1. Front
    2. Locking tab/mechanism "UP"
    3. pins are numbered left to right, top row, then bottom row.
    There maybe exceptions, but for all connectors involved in this mod, this is true
  19. Mar 11, 2014 at 6:48 PM
    #199
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    IT WORKS FLAWLESS!!!! thanks guys!
    btw i have about 20-30 of the connectors left if anybodys been looking for any.
  20. Mar 11, 2014 at 10:35 PM
    #200
    tacotacoburrito
    OK just wired this all up. What you say is true for the stereo connection. However it isn't for s8, once you look for the vacant positions its pretty clear what goes where. Yogster and fbconvert, you guys rock. Thanks for figuring all of this out.
