2014 Navigation Unit in 2013
Discussion in 'Audio & Video' started by yogster, Nov 22, 2013.
  1. Apr 25, 2014 at 8:02 AM
    #221
    tacotacoburrito
    tacotacoburrito Well-Known Member
    TE.com
    1717106-2
    1674311-2
    First PN is the plug, second is the terminals. They'll send them to you for free.
  2. Apr 26, 2014 at 4:30 AM
    #222
    notinparadise
    notinparadise Well-Known Member
    Pat
    Hampton, VA
    13 PreRunner
    Rancho Quicklift, AAL, SPC UCAs, N-Fab Bars, Intmnt Wiper, Back-up Camera, Hitch, Temp Rear view Mirror, Tint, Husky Floor Liners, 33's, bed lights, cockpit lighting, Clazzio seat covers, Bakflip G2, OEM NAV/control upgrade, heated seats
    Thank you for the information, these controls are driving me crazy!!
  3. Apr 27, 2014 at 5:32 PM
    #223
    tam
    tam Well-Known Member
    tam
    East Bay, CA
    Reasons to steal my truck...
    Icon Ext. Travel C/O, TC UCA, Spidertrax 1.25" spacers, CF hood, Glass bedsides, Doug Thorley cat-back, Goodyear Wrangler Duratrac 265/75/16
    I asked this in FLtrucks thread and got no response. Do you guys think this mod would work in a first gen? Is the stereo size a standard double din? I would think that running the steering wheel controls into some sort or center console arm rest wouldn't be too hard either, just run the wires directly to a connector that is plugged into the rear of the HU. Thoughts? Comments?
    BTW, excellent thread full of information!
  4. Apr 30, 2014 at 7:38 AM
    #224
    tacotacoburrito
    Do I think it is technically possible? Yes. Would it be a major pain in the ass? Yes.
  5. May 15, 2014 at 2:59 PM
    #225
    notinparadise
    Pat
    Hampton, VA
    13 PreRunner
    Thank you for the info, works like a charm, I got lights & left and right to work today. I still cannot get the back up camera to work. I will have to dig into that issue another time. Nothing like taking out my HU for the 100th time...
  6. May 17, 2014 at 6:36 PM
    #226
    NWI DON
    NWI DON Member
    Highland,Indiana
    '14 reg. cab
    Hi guys. Newbie with a question... I have a '14 with NO steering wheel controls,but the HU has voice recognition set up. What are the odds its already wired up for the new controls? Or is there way to tell with the least chance of me breaking something?
  7. May 17, 2014 at 6:43 PM
    #227
    robotninjasrule
    robotninjasrule Well-Known Member
    peter
    edmonton alberta
    2013 trd sport
    If you look at my post on page 18 it shows pictures of the steering coloum shroud off. From there you will be able to see the s8 plug. If it has similar amount of wires as he one I posted you have a good chance
  8. May 17, 2014 at 6:45 PM
    #228
    robotninjasrule
    peter
    edmonton alberta
    2013 trd sport
    Grr. . fat fingers hit the enter button. Once you determine if you are wired to the steering wheel next the airbag as to come off and check if you have the right clockspring/spiral cable.
  9. May 17, 2014 at 9:27 PM
    #229
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    I'm pretty sure you need the clock spring then the new controls and it should work
  10. May 17, 2014 at 11:45 PM
    #230
    NWI DON
    NWI DON Member
    Highland,Indiana
    '14 reg. cab
    Ok. Removing shroud not a problem,finding s8 should be easy (if not,come take my tools from me) Similar amount of wires,looks like 6 before - 8 after mod?
  11. May 18, 2014 at 9:33 PM
    #231
    NWI DON
    NWI DON Member
    Highland,Indiana
    '14 reg. cab
    Alright,clock spring/spiral cable between steering wheel and column, right? What determines the wrong or right one?
  12. May 20, 2014 at 9:25 AM
    #232
    NWI DON
    NWI DON Member
    Highland,Indiana
    '14 reg. cab
    Thanks for the help guys. Not even close to pre-wired. Just 1 wire. HU may not even be compatible. Only had the truck,not ready to tear into it that far yet. Thanks again.
  13. May 24, 2014 at 10:46 AM
    #233
    NWI DON
    NWI DON Member
    Highland,Indiana
    '14 reg. cab
    Me again. Reconsidering this job. Sorry being stupid,but I would greatly appreciate your guidance. From what I think I've figured out, clock spring/spiral cable is one unit (or 2 part sold separately?) that mounts behind steering wheel with the sockets on top front with air bag plugs and steering wheel controls, and bottom for the output of same connections.? Right now I only have 1 green wire coming out of s8. If I'm understanding you guys, gonna need CS/S cable and a new s8 harness from wheel to HU.?
  14. May 24, 2014 at 8:04 PM
    #234
    metal4130
    metal4130 Well-Known Member
    Eric
    Central IL
    13 DCSB PreRunner
    I know the clock spring comes in 2 different varieties on the Tacoma. There is the cheaper one, which you have, and the more expensive one. The difference between the two is the amount of wires that run within the clock spring from one connector to the other.
    I can say for sure your radio is set up for voice controls, steering wheel controls etc. I believe you would need to buy the upgraded clock spring as well as the steering wheel controls. Without looking at your wiring diagram I can't say for sure how you are wired from the steering column to the radio.
  15. May 24, 2014 at 8:10 PM
    #235
    metal4130
    Eric
    Central IL
    13 DCSB PreRunner
    Pulled from earlier in the thread...
    A note on the spiral cable assembly. this is the black plastic circular housing that you see beneath the airbag. It allows for connection between z1 and s8. There is a flat ribbon cable in that housing that winds and unwinds like a clock spring as the steering wheel is turned. There only 2 flavors - a "7-way", ie, 7-conductor, for trucks NOT equipped with steering wheel controls. And a "16-way", ie 16-conductor for trucks equipped with steering wheel controls. If your truck was NOT equipped with steering wheel controls from the factory, the spiral cable assembly would need to be replaced (in addition to acquiring the steering wheel controls). The spiral cable assembly is not difficult to replace. There is another thread on that. Someone in this thread or another asked about trucks WITHOUT factory steering wheel controls.
  16. May 24, 2014 at 9:05 PM
    #236
    NWI DON
    NWI DON Member
    Highland,Indiana
    '14 reg. cab
    Not sure how to get you a wiring diagram.... I could remove the shroud and take a picture of whats there if that would help. Or would I need to take the air bag off too?
  17. May 26, 2014 at 5:51 AM
    #237
    notinparadise
    Pat
    Hampton, VA
    13 PreRunner
    Got the correct 2014 plug plugged it into the radio checked all my connections and nothing. Everything works fine on the 2014 unit & controls, I just cannot get the backup camera to work. The original kit was from checkermod1(Ebay) and worked perfect on the 2013 radio. Can anyone that has the camera working tell me if my wiring is correct? I am not sure if the red wire is required any longer and if my pins are in the correct position?
  18. May 26, 2014 at 9:46 PM
    #238
    DunkinDal
    DunkinDal Active Member
    South of Boston
    2015 TRD Off Road
    Capture123.JPG I think 11,12,23,24 are on the other side of connector with the tang up and the connector facing
  19. May 27, 2014 at 9:24 AM
    #239
    NWI DON
    NWI DON Member
    Highland,Indiana
    '14 reg. cab
    Anybody know if there is a s8 r15(?) OEM harness part# ?
  20. May 27, 2014 at 4:36 PM
    #240
    whiting1977
    whiting1977 Well-Known Member
    Sacramento CA
    2014 SR5 PreRunner
    I have read most but not all of this thread in hopes of finding answers to a couple of my questions. I have a 2014 and recently purchased the Nav unit from FLTrucks. I have not yet installed it but have the following questions. Given that my truck did not come with the Nav unit (Entune Plus) will the 28 pin connecter still have the speed sensor hooked up? And I understand that the shark fin is for both GPS and Sat Radio. Even thought my truck did not come with Nav should I expect to find an unused GPS connection hanging behind the radio ready to plug into the new Nav unit or will I have to use the antenna FLTrucks sent me?
