2014 Navigation Unit in 2013
Discussion in 'Audio & Video' started by yogster, Nov 22, 2013.
  1. Feb 24, 2014 at 4:29 PM
    #81
    metal4130
    metal4130 Well-Known Member
    Eric
    Central IL
    13 DCSB PreRunner
    Partial success today! I installed the steering wheel controls and they worked just like they should. The voice control button works perfectly!
    To remove the old controls and install the new is a very easy job which took me less than 30 minutes. First thing you need to do is unplug the negative terminal from the battery. The power needs to be removed for at least 90 seconds before messing with the airbag. Next, remove the 2 plastic trim pieces on the left and right side of the steering wheel. Once removed you will use a T30 Torx bit to unscrew the airbag. There is one screw per side. Once unscrewed the airbag will pull right out. Remove the ground plug from the airbag and then the black and orange connectors. To remove the connectors you need a tiny flat head screw driver to pry up the yellow portion of the tab. Once that is done use the small screwdriver to pry the whole connector loose. Search Tacoma steering wheel removal on Youtube to see a video. After that you just remove the 4 phillips head screws holding the controls with a #2 screwdriver and then unplug the controls. The controls just pull off the steering wheel. Install the new controls by just going in reverse and that is all.
    I have an audio buddy of mine making the extra wire I need and it has not arrived yet. I will post an update and some pictures when I get that installed.
  2. Feb 24, 2014 at 4:32 PM
    #82
    Phil5393
    Phil5393 Well-Known Member
    Phil
    Long Island, New York
    TRD Sport
    How much did the parts run for the steering wheel controlls and where can i get them? Thanks
  3. Feb 24, 2014 at 4:36 PM
    #83
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    interesting..
  4. Feb 24, 2014 at 4:39 PM
    #84
    metal4130
    Eric
    Central IL
    13 DCSB PreRunner
    The controls were $96 and change plus shipping. The part number is listed earlier in the thread (post 96) and I'd buy them from Camelback Toyota.
  5. Feb 24, 2014 at 4:41 PM
    #85
    ramonortiz55
    Ramon
    Texas
    stock
    Im curious to know who and how will that last fourth wire be routed/installed and iron out any fuzzy details.
  6. Feb 24, 2014 at 4:42 PM
    #86
    ramonortiz55
    Ramon
    Texas
    stock
    I have no idea.
    But you can fix it by going to your album and click on each individual picture.. at the bottom you will see an edit option. Once you get there, youll be able to rotate your pictures.
  7. Feb 24, 2014 at 5:42 PM
    #87
    jptx65
    jptx65 Member
    Jeff
    The Woodlands, Texas
    2013 PreRunner SR5
    Bilstein 5100's Front and Rear Hellwig Rear Sway Bar ImMrYo Rear-View Mirror Lift Bracket Katzkin Leather Seats
    So, what controls are not working without the extra wire? And where will the extra wire go?
  8. Feb 24, 2014 at 5:44 PM
    #88
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    I want that new steering wheel...just looks better than the old.
  9. Feb 24, 2014 at 7:13 PM
    #89
    smgcon
    smgcon Well-Known Member
    Geoff
    Vernon, BC
    2013 DBC
    Just ordered the switches myself. Metal4130 - waiting for the info on the missing wire. I look forward to hearing about your luck adding the extra circuit. Thank you for all of your hard work and help. I really appreciate the help with the steering wheel disassembly!
  10. Feb 25, 2014 at 10:48 AM
    #90
    yogster
    yogster [OP] merkwürdigliebe
    Tom
    Massachusetts
    13 Black DCLB SR5
    DCLB Black 4WD Illumination dial from 4runner, Flyzeyes LED. Hardwire GPS and Valentine1 with BlendMount mirror mount, TRD shift knob, tube steps, swapped out for signal lamp mirrors. Garmin Eco-Route HD for Bluetooth ODBII Diagnostics, 2014 Entune Plus w Navigation, Leer 100XL dome light wired to dome circuit, pop&lock tailgate and cap locks.
    Don't think there are any fuzzy details. This has already been figured out. It's in one of the other thread/replies in this thread. The fourth wire is for the left/right and return/ok buttons. It runs from Pin 3 on the S8 connector to Pin 24 on the R15 connector. This information was direct from the TIS wiring diagrams. As Metal4130 confirmed the Voice Control button just "works" as its signal is carried by the existing wires, which was also derived from vieiwing the TIS wiring diagrams.
    I made the 4th wire connection when I replaced my head unit. Just waiting for my new controls to arrive. The unknown (because I have not pulled my steering wheel apart yet) is if all pins are present on the steering wheel connector spiral cable itself, AND the spiral cable provides a connection for all pins from this connector to the S8 connector on the steering column. It should. Metal4130 can probably speak to the connector behind the air bag having all pins, and he'll know the remainder soon enough.
    For those of you unfamiliar with the spiral cable, it is a flat ribbon cable inside a circular housing. It provides electrical connections for the horn, steering wheel controls, air bag. It allows the wheel to turn x amount of times stop-to-stop, and winds/unwinds like a clock-spring, while maintaining that electrical connection. I believe there are 2 types of spiral cable assembly, from what I could discern. One that contained connections for just the horn and airbag, and one that had all connections present, used or not.
  11. Feb 25, 2014 at 3:59 PM
    #91
    smgcon
    Geoff
    Vernon, BC
    2013 DBC
    Hopefully I can purchase a wire of the appropriate length along with the pins installed from one of you guys (yogster or metal4130) as I have not had much luck up here with the dealer with respect to the small parts. They always want a VIN and have no sense of adventure. So far I have ordered all parts from the US.
  12. Feb 25, 2014 at 4:02 PM
    #92
    robotninjasrule
    robotninjasrule Well-Known Member
    peter
    edmonton alberta
    2013 trd sport
    Once I get my controls(should be another week), I'll tear it all apart and find out if I have the right size pins. If not I'll order a bunch and send some your way!
  13. Feb 25, 2014 at 4:39 PM
    #93
    yogster
    Tom
    Massachusetts
    13 Black DCLB SR5
    Attached are diagrams for a 2014 and 2013 Tacoma
    2014 is the non-JBL Nav unit
    2013 is the non-jbl, non-nav base audio touch screen
    They are in PDF format. Page breaks from right to left, this is how they are extracted from TIS. Without the SVG viewer and online access this is the best way to extract.
    On the bottom of each doc are all associated connectors. Pin numbering is looking at the connector side (not harness side) head on.
  14. Feb 25, 2014 at 4:46 PM
    #94
    yogster
    Tom
    Massachusetts
    13 Black DCLB SR5
    I could not figure out the pins, and I was probably going to spend more dollars trying to figure out the right ones, then just ordering appropriate repair leads. The pins (actually the harness has the female portion) were the same as the ones that came with the 4wd illumination 4runner "kit", so I knew they would work...
    82998-12420
    This is about $5 from Camelback. Best to order with something else, or the shipping makes it not worth it...
    So I ordered two of these and used an appropriate length of 20 AWG wire. Well I think it was 20. Maybe 18. Cannot use wire bigger than 18, though as the pins are small. It think when I wire tied it along main harness and routed up through dash to steering column it was maybe 4-5'. I soldered the "repair leads" to either end of this wire, used heat shrink tube to insulate, unlocked the connectors (careful, you don't want all pins to come out, else you be putting a puzzle back together!), inserted the pin and locked back up.
    Including dash removal, maybe about 30 minute job.
  15. Feb 25, 2014 at 4:51 PM
    #95
    robotninjasrule
    peter
    edmonton alberta
    2013 trd sport
    If its the terminal leads I think they are these will work as well.
    Sumitomo TS Sealed 025 Female Terminal 0.22-0.5 mm2 [Brass/Tin] (6874)*
    I won't know for sure until I take it apart
  16. Feb 25, 2014 at 5:04 PM
    #96
    yogster
    Tom
    Massachusetts
    13 Black DCLB SR5
    For future reference, what is a good site for components like this?
    I was looking at some of the robotics hobby sites. Some stuff looked "about right", but not being sure, I just went with what I knew.
    Also tried finding by connector type via sites that sold Molex connectors. But did not get very far there.
  17. Feb 25, 2014 at 5:06 PM
    #97
    robotninjasrule
    peter
    edmonton alberta
    2013 trd sport
  18. Feb 25, 2014 at 5:11 PM
    #98
    hoenah808
    hoenah808 Well-Known Member
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    so on the 2014 which connector is for the rear camera? looking at that pdf is making my eyes go crazy lol
    edit: so t22 on the 2014 is at the camera end? which harness does it go to into the back of the headunit?
  19. Feb 25, 2014 at 5:17 PM
    #99
    yogster
    Tom
    Massachusetts
    13 Black DCLB SR5
    N26, Pins 11/12 and 23/24
    It's a 24 pin jack.
    If you bought one of those ebay pre-made kits, it will work, even though the connector is 16 pins. You just need to shave tabs off connector and ensure you plug in all the way to the left. This is because the pins used are the left-most pins on the either the 16 pin or 24 pin jack. Or you can buy the correct connector
    90980-12554
    and take the pins out of the supplied one and insert into the correct slots in the new one.
    #99
  20. Feb 25, 2014 at 5:52 PM
    #100
    smgcon
    Geoff
    Vernon, BC
    2013 DBC
    Thank you guys. I am waiting for my controls to ship and with the correct part number, I can try my local Toyota dealer. Failing that I will purchase some pins off of the forum from one of the members who posted above. I appreciate the freely sharing of your information!
