2014 No 12v from 7 pin battery lead pin 4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cargoaa, Feb 12, 2020.
  1. Feb 12, 2020 at 7:24 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  2. Feb 12, 2020 at 7:25 PM
    Cargoaa
    Cargoaa [OP] Well-Known Member
    2014 Super White Tacoma TRD
    We
    Thanks that will be my next steps when I have time to next weekend. I appreciate all the help!
    TnShooter[QUOTED] likes this.
  3. Feb 12, 2020 at 7:27 PM
    Cargoaa
    nd4spdbh likes this.
  4. Feb 12, 2020 at 7:27 PM
    TnShooter
    Deogee
    STOCK
    No problem man.
    Hope you get it fixed.
  5. Feb 12, 2020 at 7:38 PM
    Cargoaa
    If I cant I will just run a new fused wire from the battery to the plug located in the back. I don't need it really until this summer when we travel and need to charge the battery.
  6. Feb 12, 2020 at 7:40 PM
    TnShooter
    Deogee
    STOCK
  7. Feb 12, 2020 at 8:17 PM
    Muddinfun
    Muddinfun Well-Known Member
    There’s a wire harness connector about a foot or so left of the 7 way trailer connector. It’s on the bottom of the left frame rail. I would unplug it there and check for power. There’s a good possibility that the problem is corrosion in the 7 way. The wire colors back there are kind of a mixed up mess and they changed at some point in the 2nd gen run, so I can’t help you with colors. Make sure the engine is running and the taillights are off.
    TnShooter likes this.
  8. Feb 12, 2020 at 8:42 PM
    Muddinfun
    Yeah, like I mentioned, wire colors are kinda screwed up back there.
  9. Feb 12, 2020 at 8:44 PM
    TnShooter
    Deogee
    STOCK
  10. Feb 12, 2020 at 8:58 PM
    Cargoaa
  11. Feb 12, 2020 at 8:59 PM
    TnShooter
    Deogee
    STOCK
    No problem man.
    Hope you get it fixed soon
  12. Feb 12, 2020 at 9:06 PM
    Cargoaa
    This is pointing in a much better direction than I was yesterday. I will do some tracing and see where the power stops. I do have it on the hot side of the relay. I jumpered the relay connection and still nothing at the plug. Now to work from the engine backward.
    Muddinfun and TnShooter[QUOTED] like this.
