2014 Non JBL w/ navigation retrofit DIY w/ info & part numbers
Discussion in 'Audio & Video' started by steveo27, Mar 3, 2014.
  1. May 5, 2015 at 6:39 AM
    #261
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
  2. May 6, 2015 at 9:52 PM
    #262
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
  3. May 7, 2015 at 5:32 AM
    #263
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    Pretty much yes. My radio surround never sat flush up top either. (Yes I'm fishing for excuses)
  4. May 7, 2015 at 11:21 AM
    #264
    steveh_2007
    steveh_2007 Pro Member
    NW Houston, TX
    07 TRD Sport PreRunner
    TRD Baja Suspension, FN Wheels BFD, TRD Cat-back Exhaust, TRD Cold Air Intake, TRD GrillCraft MX Grilles, FX-R 3.0 Bi-Xenon Retrofit with Osram CBI Bulbs, OEM Navigation/Bluetooth/Backup Camera Retrofit, WeatherTech Floorliners, Valentine One, ScanGuage II with custom V1/SGII BlendMount
    I did the same... minus the 4WD switch. lol I'm pretty "OCD" when it comes to fitment so I pulled for the new surround bezel.
    BTW, thank you for posting the links to the eBay seller a few pages back for wiring the back-up camera! I'm placing my order now. That should be the last component to my retrofit.
    Quick question for those that have 05-11 Steering wheel controls. I use my Up/Down buttons to toggle through songs, stations, etc.... However, if I want to select something, is it possible to do it from the controls or have to use the touchscreen?? I know its a small thing, but would definitely be the nice.
  5. May 7, 2015 at 1:16 PM
    #265
    Tunngavik
    Alberta, Canada
    So nobody could get their 2005-2011 surround to fit on top (perfectly flush) with the radio? I tried grinding it down some more but it seemed to help only a little.
  6. May 7, 2015 at 1:17 PM
    #266
    Tunngavik
    Alberta, Canada
    Can you please post pictures when you install? I don't think anyone has with the 4*4 switch
  7. May 7, 2015 at 2:47 PM
    #267
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    Sect something like in what more? FM, CD, or Bluetooth?
    Of course! I'm still waiting for my order confirmation for the 4wd switch and I ordered it Sunday.
  8. May 7, 2015 at 3:33 PM
    #268
    Tunngavik
    Alberta, Canada
    Oh. Do you have to change out your old switch to a 2012-2015 version?
  9. May 7, 2015 at 3:51 PM
    #269
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    I'm thinking yes because of the lip on the newer bezels. When I get my new switch in the mail I'll take pics to compare
  10. May 7, 2015 at 4:27 PM
    #270
    steveh_2007
    NW Houston, TX
    For example, browsing for a song through a Bluetooth connected iPhone... If I could select a song via steering wheel controls, that would be awesome. My 14 4Runner has an arrow key pad, and in the middle is the select button.
    I was thinking maybe a double tap, or holding down a button would do it but hasn't worked
  11. May 7, 2015 at 7:05 PM
    #271
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    Oh like browsing different songs - let me find the manual. There's some interesting stuff in there.
  12. May 7, 2015 at 7:12 PM
    #272
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
  13. May 7, 2015 at 7:21 PM
    #273
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    Page 106 shows the newer model steering wheel has an 'Enter' button. Something we're missing with pre-2012 models
  14. May 7, 2015 at 8:45 PM
    #274
    steveh_2007
    NW Houston, TX
    Thanks for looking that up Justin. It was worth a try.
  15. May 13, 2015 at 8:13 AM
    #275
    Ktm350JH
    Ktm350JH Well-Known Member
    So I have a non jbl 2008 with no Steering wheel controls. Will Bluetooth work with the scion/Toyota mic and the 20-28 pin adapter ? Or am I waisting my time. I have read previous post and didn't see it. I read where with steering wheel controls you where adding Bluetooth controls .
  16. May 13, 2015 at 10:17 AM
    #276
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    I'm honestly not sure if bluetooth works without steering wheel controls. I do know that the phone option wouldn't "turn on" or become available without the mic plugged in because that happened to me. If you're looking to connect bluetooth with your phone to use for music/podcasts I would imagine it will work because there's headunits with no nav and bluetooth capability.
  17. May 13, 2015 at 9:43 PM
    #277
    steveo27
    steveo27 [OP] Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Mine fits perfect
  18. May 19, 2015 at 9:53 PM
    #278
    Tunngavik
    Alberta, Canada
    Steve do you have any other photos you could provide of the top?
    Also, did you get the multiple USB port to work (so a USB for a flash drive with songs and a separate USB connector for charging)?
  19. May 20, 2015 at 9:24 AM
    #279
    steveh_2007
    NW Houston, TX
    I used the multiple USB port for my Nav retrofit, and it works seamlessly. One is used for my USB port in the lower dash, and the other is routed to my glovebox for my iPod. BOTH connectors charge, play music, and allows to be controlled through the touchscreen.
  20. May 20, 2015 at 10:38 AM
    #280
    Tunngavik
    Alberta, Canada
    Thanks for the quick reply. Does that mean that you can have something plugged into both drives at the same time and still be able to play music in them? For example a flash drive in one of the USB ports and a Ipod in the second.
