2014 Non JBL w/ navigation retrofit DIY w/ info & part numbers
Discussion in 'Audio & Video' started by steveo27, Mar 3, 2014.
  1. May 20, 2015 at 10:51 AM
    #281
    steveh_2007
    steveh_2007 Pro Member
    NW Houston, TX
    07 TRD Sport PreRunner
    TRD Baja Suspension, FN Wheels BFD, TRD Cat-back Exhaust, TRD Cold Air Intake, TRD GrillCraft MX Grilles, FX-R 3.0 Bi-Xenon Retrofit with Osram CBI Bulbs, OEM Navigation/Bluetooth/Backup Camera Retrofit, WeatherTech Floorliners, Valentine One, ScanGuage II with custom V1/SGII BlendMount
    Yes, just switch the "Source".
  2. May 21, 2015 at 8:02 PM
    #282
    Juanito2712
    Juanito2712 New Member
    Juan
    toyota Tacoma 2008
    Cambiar stereo original x uno original 2014
    Puedes hacer una lista de numero de partes que compraste?
  3. May 21, 2015 at 9:31 PM
    #283
    steveo27
    steveo27 [OP] Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Ill snap some when I get a chance.
    Yep, both USBs work for me. I keep an iPod in the glove box with hooked up to the one USB, itll charge the iPod and play from it. The dashboard USB charges a phone no problem, and it will let you play music from it as well.
    Yep
    Yep. you have to select the source. Ill try to get pictures of what comes up on the radio
    This
    "You can make a list of number of parts you bought?"
    The list of all the parts is on the first page.
    Cheers
  4. May 23, 2015 at 12:55 PM
    #284
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    2012 bezel and switch installed.
    Coolerman and steveh_2007 like this.
  5. May 23, 2015 at 1:30 PM
    #285
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    Looks good. So to confirm you had to buy the bezel AND a 2012 - 2015 4*4 switch?
  6. May 23, 2015 at 2:55 PM
    #286
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    Yea Jason the switch from a 2012+ is different than the 2005-11 but the plug is the same (thank god)
  7. May 23, 2015 at 2:57 PM
    #287
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    Here's the part number for the switch
  8. Jul 3, 2015 at 4:29 PM
    #288
    CQB 1911
    CQB 1911 Well-Known Member
    Jesse
    AZ.
    2010 TRD OR AC
    Can someone post a current link to the Flush mount USB Aux 3.5mm headphone jack mounting panel dashboard dock input lead? I see a couple on Ebay, I just want to make sure I get one that fits the dash without needing to cut the dash. Thanks in advance.
  9. Jul 3, 2015 at 4:45 PM
    #289
    CQB 1911
    Jesse
    AZ.
    2010 TRD OR AC
    I got the AUX/USB dash bulkhead from the guy I bought the HU from, so I bought the OEM USB adapter from the first post PN PT546-00120-US but it seems way too short (I used my finger for reference lol ) (I'm returning it).
  10. Jul 3, 2015 at 5:43 PM
    #290
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
  11. Jul 3, 2015 at 7:28 PM
    #291
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    What you got was the USB conversion adapter used on the Scion radios. The foam indicates that this adapter plugs into the Scion's wiring harness.
    This document, pages 2 & 5 explains all of this.
  12. Jul 4, 2015 at 10:48 AM
    #292
    CQB 1911
    Jesse
    AZ.
    2010 TRD OR AC
    That's cool - just used the part number the OP has on the first page.
    Do you happen to have the correct part number to use the with Tacoma?
  13. Jul 4, 2015 at 4:46 PM
    #293
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    The easiest thing to do, is to keep the adapter you got, and get the eBay USB port that would plug into that adapter.
    steveh_2007 likes this.
  14. Jul 6, 2015 at 10:45 AM
    #294
    steveh_2007
    NW Houston, TX
    X2... this is the route I took. Works seamlessly.
  15. Jul 23, 2015 at 8:10 AM
    #295
    CQB 1911
    Jesse
    AZ.
    2010 TRD OR AC
    Do you guys have a seller user name or link? I bought one but it didn't fit the OEM dash openeing.
  16. Jul 24, 2015 at 5:47 PM
    #296
    UssMoGn
    UssMoGn That Vegas dude
    James
    Las Vegas NV
    05&04 Tacoma SR5
    Home Built Front Bumper HID Headlights LED Cab lights 2013 Radio swap MOLLE DC Insert Traffic Cam F&R 6'' Procomp lift Custom Grillie
    Awesome Write up! So I bought all the cables but Im stuck on the AUX side and possible the back up camera. I tryed to look through all the forums but I didnt find the answer or I didnt understand the answer.
    I have a 2013 touch screen Non Navi/ Non XM 86140-04080
    Im trying to retro fit into a 2005 SR5 Tacoma, No Factory AUX, no Streering controls.
    BT works
    CD works
    Radio works
    USB Works (charging my android)
    AUX- Im confused
    Steering controls
    http://www.amazon.com/gp/product/B0064J4LOM?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00
    Aux/USB surface mount
    http://www.amazon.com/gp/product/B00IBDSFAU?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s01
    USB OEM connector
    http://www.amazon.com/gp/product/B00XKUVJQG?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
    20/28 Pin connector
    http://www.amazon.com/gp/product/B00DF7C4O0?psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s00
    Antenna cable
    http://www.amazon.com/gp/product/B00HR5PBNW?psc=1&redirect=true&ref_=oh_aui_detailpage_o05_s00
    My issue is this I bought the Steering controls thinking it had a prewire AUX 3.5mm jack. Well it came with it off some black connector..but also had RCA off the main connector. I can use that with the AUX/USB surface mount I bought. But I ended up with 2 female connectors. But i noticed that the 20/28 pin has those same color cable coming out. Can i just scrap the harness and splice the Red/black/White wire togeather? OR am I missing a cable? 20150724_171728.jpg20150724_171617.jpg
    Also with this radio will IT show a aux source when there is one plugged in? Right now i see nothing on my screen for AUX.
  17. Jul 31, 2015 at 10:44 PM
    #297
    cfrailey
    cfrailey Member
    Phoenix
    TRD Prerunner
    Great writeup. I have a question regarding GPS. I have a '14 Tacoma and added the factory NAV unit from FLtrucks. I installed the included navigation antenna. I'm routinely having no GPS lock and NAV not showing correct position on map. Has anyone else seen these issues? One thing I was wandering is my uint also has the sat radio, for Tacomas with sat radio installed is there already a GPS antenna up top with the sat antenna? If so would connecting the small navigation GPS antenna cause a conflict?
  18. Sep 16, 2015 at 3:04 AM
    #298
    terps2005
    terps2005 Well-Known Member
    Southern MD
    17 Super White DCLB Sport
    TRD Pro Grill w/white letters Inno roof rack Body Armor Hiline Bumper TRD Pro Skid plate Full meso interior chrome delete Bronze AGP T4R replica wheels Falken Wildpeak AT3W tires Homelink Mirror Pioneer DMH-WC6600NEX head unit with Maestro integration A shit ton of crumbs and dirt in the back from my 2 little monsters
    Does anyone know if the oem Bluetooth mic that's built into the mirror will work with this setup? I have a non jbl system but I swapped a Bluetooth rear view mirror in when I accidentally cracked the regular one. I'm not sure if the wiring is there if I don't have the JBL system.
  19. Sep 19, 2015 at 1:02 PM
    #299
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
    This thread is awesome! Thanks to everyone who has contributed and shared photos and experiences so far!
    I'm looking to install a 2012+ JBL radio (with or without navigation) into my 2009 TRD 4x4 Tacoma with JBL radio and Bluetooth. I was hoping someone who has done this could PM me with a comprehensive list of parts (and OEM part numbers) I will need to make it happen? I will post the list I've put together so far below but I know I have to be missing some stuff... I will say that after reading through most of the posts here and looking at the pictures others have posted, I've decided that I definitely want to replace the center console bezel with the 2012+ bezel and the new 4x4 switch. I'm open to replacing my Climate Control unit as well if the newer black version can be had at a decent price. Anyway, here is my list of parts so far:
    1) OEM Toyota 2012+ Touch Screen JBL Radio (with or without Nav)
    2) OEM Toyota 2012+ Center Console and Radio Bezel
    3) OEM Toyota 2012+ Clock/Hazard/Airbag Assembly
    4) OEM Toyota 2012+ Radio Mounting Brackets
    5) OEM Toyota 2012+ Navigation Antenna (depending on the new radio)
    6) OEM Toyota 2012+ 4x4 Switch
    7) OEM Toyota 2012+ Climate Control Module (possibly)
    8) AM/FM Antenna Adapter
    9) 20/28 Pin Harness Adapter
    The real question marks for me involve what it's going to take to hook the OEM 2009 Bluetooth and Steering Wheel control wiring to the 2012+ radio as well as the XM radio functions. My current 2009 JBL radio has an XM module and I'm paying for a subscription to use it so I definitely want to be able to maintain that functionality on the new radio. Does anyone know if I'm going to need an adapter to hook my 2009 XM antenna to the newer style radio? Also, is there anything else I'm missing from my list?
    Thanks in advance for your help!
  20. Sep 20, 2015 at 2:11 PM
    #300
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    There's a ton of info in this thread for you to build your kit on. That said I think the list you have is pretty complete. Start swiping that charge card!
