2014 Non JBL w/ navigation retrofit DIY w/ info & part numbers
Discussion in 'Audio & Video' started by steveo27, Mar 3, 2014.
  1. May 18, 2020 at 11:09 AM
    #441
    seanislegend
    seanislegend Well-Known Member
    Sean
    Port Richey, FL
    2008 Tacoma TRD Sport 4x4
    3" Icon coilover lift with resi. 17x10 pro comp wheels 255/75/17 bfg km1 mud terrains
    Hello all, I have a 2008 and will be installing a 2014 non-JBL non-Nav touchscreen unit. Im going to be installing it with the 20-28 pin adaptor, bluetooth mic, and antenna adapter. No plugs for satellite or Nav so not worried about it. I dont have a backup camera installed at all, can someone recommend a backup camera? Don't care if its aftermarket or factory, as long as it plays on the radio.
  2. May 23, 2020 at 9:55 PM
    #442
    op9nf
    op9nf Well-Known Member
    Nilo
    Bothell,Washington
    2013 Tacoma TRD DCLB 4X4
    Bilstein 5100’s With OME 288. 2inch blocks with freedom off-road extended shocks.
    Sub’d
  3. Sep 10, 2020 at 8:54 AM
    #443
    milescf
    milescf Well-Known Member
    Oklahoma City
    ‘08 DCLB Sport; Sold ‘17 TRDOR MT ; sold ‘02 Black Prerunner
    3rd Gen OR suspension, wheels and tires all 4 corners.
    What did you go with?
    I got a camera source pop and lock kit with interface kit to match the 2017 head unit I’m installing. Damndest thing, the head unit will not pick up the camera when I go to reverse. I’ve confirmed w/ camera source I’m doing all correct, even have hooked up power to head unit, but sent video to a tv to confirm the camera is powered and working. I just hard wired the reverse trigger to the #2 pin in the 24 pin harness, but damn HU will not switch over. Everything else in my install has been perfect, but this.
  4. Nov 30, 2020 at 4:19 PM
    #444
    Stxxx
    Stxxx Well-Known Member
    2009 Tacoma TRD
    Subd. Trying to get everything to work in my 09 JBL. Thanks for the write up.
  5. Nov 28, 2021 at 12:02 AM
    #445
    Ventenueve
    Ventenueve Active Member
    David
    Ral, NC
    2006 Access cab 2.7 5spd 4x4 blue
    Camper build in progress…new build mods to come 2006 V8 4Runner SR5 Previous trucks 97 3.4 5spd 4x4 ext cab 98 2.4 SR5 ext cab 98 limited 4 Runner 98 SR5 4 Runner
    Great thread Sub’d almost done with this conversion 2006 base to 2015 non nav HU THANKS for all the part #s making this possible ! Cheers !
    super_white likes this.
  6. Nov 28, 2021 at 12:06 PM
    #446
    Ventenueve
    David
    Ral, NC
    After market 12 volt camera works when powered to a tv but not on head unit used the factory harness to aftermarket camera adaptor thought this was gonna work pretty easy but out of ideas using a 2015
    HU non nav in a base 2006 manual
  7. Dec 8, 2022 at 8:25 PM
    #447
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Ahhhh, this was the thread I was hoping to find. Just starting my journey. So nice to have all this in one spot.
    I’m sure it has been answered but I’m tempted to try a 2012-2015 bezel if it fits better. I don’t like the silver anyway.
    steveo27[OP] likes this.
  8. Dec 9, 2022 at 6:21 AM
    #448
    daveeasa
    David
    PNW
    @JustinL and @steveh_2007, if I’m capable of reading, you both went to 2012-2015 outer radio bezels? If so, did either of you have the key switch to disable the passenger airbag? And if one of you did, what did you do for that guy?
    I think others have suggested stuffing it in the dash which is my plan. I hate my silver bezel and want to go black but stalled on an old style one w shaving like OP vs a new style one and ditch the airbag disable mounting spot.
  9. Dec 9, 2022 at 9:04 AM
    #449
    steveo27
    steveo27 [OP] Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    The HVAC vent surround panel?
    it’ll fit.
  10. Dec 9, 2022 at 9:06 AM
    #450
    daveeasa
    David
    PNW
