2014 Non JBL w/ navigation retrofit DIY w/ info & part numbers
Discussion in 'Audio & Video' started by steveo27, Mar 3, 2014.
  1. Aug 6, 2014 at 11:30 AM
    #121
    JustinL
    JustinL Well-Known Member
    Justin
    Newington, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    I just left mine and buried it behind the radio after plugging in the adapter. No need to touch it
  2. Aug 6, 2014 at 12:07 PM
    #122
    tarheeler
    tarheeler Well-Known Member
    Newport News, Va
    06 PreRunner TRD offroad
    3" lift
    Thank you, that's what I was thinking. Just received invoice from fltrucks to get one from him. Just trying to get all my ducks in a row before it gets here
  3. Aug 6, 2014 at 1:34 PM
    #123
    JustinL
    Justin
    Newington, CT
    2012 Conversion
    He should include the head unit; the satellite GPS antenna, and the radio surround.
  4. Aug 6, 2014 at 6:40 PM
    #124
    tarheeler
    Newport News, Va
    3" lift
    Do you have to pay a subscription fee or have a special type of phone for the entune apps to work. The only one I really want is Pandora
  5. Aug 6, 2014 at 11:44 PM
    #125
    JustinL
    Justin
    Newington, CT
    2012 Conversion
    Just have to create an Entune account for a 2014 Tacoma. They'll need a valid VIN as well.
  6. Aug 7, 2014 at 5:07 AM
    #126
    tarheeler
    Newport News, Va
    3" lift
    But don't you have to have some type of Internet connection
  7. Aug 7, 2014 at 6:32 AM
    #127
    JustinL
    Justin
    Newington, CT
    2012 Conversion
    No, the data update for your Nav, weather and other apps comes from HD signal I believe. If you're pairing your phone to use something like Pandora, you have to bring up the Entune app on your phone then use the head unit to control Pandora. In that case, the head unit is just acting as a pass-through for the data coming in from your phone's signal.
  8. Aug 13, 2014 at 12:43 PM
    #128
    tarheeler
    Newport News, Va
    3" lift
    Got my radio today and the nav antenna is mounted to what I guess is a bracket. It doesn't look that way in the picture op posted. Is this supposed to be mounted somewhere, I know several have said they just tucked it behind the radio
  9. Aug 13, 2014 at 12:45 PM
    #129
    JustinL
    Justin
    Newington, CT
    2012 Conversion
    I haven't seen a bracket for mounting but who knows, that could be the actual way to mount it!
    Personally I have not mounted my GPS antenna to anything, I've tucked behind the radio and upwards.
  10. Aug 13, 2014 at 1:05 PM
    #130
    tarheeler
    Newport News, Va
    3" lift
    Would you take it off the bracket, looks to me like it wll rattle more on that metal bracket
  11. Aug 13, 2014 at 4:51 PM
    #131
    tarheeler
    Newport News, Va
    3" lift
    Another stupid question, does it matter which side of nav antenna is facing up, the number 125 or the other side with the round silver thing
  12. Aug 13, 2014 at 11:39 PM
    #132
    JustinL
    Justin
    Newington, CT
    2012 Conversion
    Shouldn't matter which side is up. I don't remember what side is up or down on mine
  13. Aug 15, 2014 at 1:16 PM
    #133
    tarheeler
    Newport News, Va
    3" lift
    Put this in my 2006 Tacoma, I had the plain Jane radio in it, the antenna needed the adapter, the plugs for the front speaker and back speakers, power, ground all fit in back of the new radio but the plug that I was told is for the steering wheel control does not fit anywhere. I don't have steering wheel control so don't know what it's for. Everything seems to work but the map does not move. It finds my position but never moves. I read where several people have said they had this problem but it healed itself after driving a while, we'll see. But, the plug that won't fit, is that supposed to go in that 20/28 pin adapter. Also the side buttons are not backlit, saw others with same problem but no answers.
    http://youtu.be/RwbuB1fVj8s
    This is a good video on removing old stereo, at end it shows the steering wheel control plug I'm talking about
  14. Aug 15, 2014 at 7:04 PM
    #134
    Tacoma4AU
    Tacoma4AU Member
    Chase
    Kansas City
    05 Crew Cab Tacoma
    Has anyone had problem with the Weather app not working after you install it? Installed a 2104 in my 06 everything works other than the traffic and the weather apps. Any thoughts?
  15. Aug 15, 2014 at 7:24 PM
    #135
    tarheeler
    Newport News, Va
    3" lift
    Did you have the same radio in the video pic above your post. If so did all your plugs fit in back of new radio except am/fm antenna. If you look at short video it shows the plug that won't fit in mine, it's the one he says is for steering wheel controls, but I don't have them on my wheel
  16. Aug 15, 2014 at 8:03 PM
    #136
    Tacoma4AU
    Tacoma4AU Member
    Chase
    Kansas City
    05 Crew Cab Tacoma
    Yes I did, everything plugged in fine with the 28 pin harness and antenna adaptor. I am going to remove the plate from my HD wire tomorrow and see it that fixes it.
  17. Aug 15, 2014 at 8:21 PM
    #137
    TRDh4vok
    TRDh4vok Well-Known Member
    Gil
    Palm Beach County
    '09 TRD PreRunner Sport
    -4" MaxTrac Spindle lift -5100 RCD Bilstein's -1/2" Strut Spacer driver's side (Taco Lean fix) -1/4" Strut Spacer passenger side (Taco Lean fix) -4" Tapered Blocks -Extended length U bolts -Front Skid Plate -Exhaust Tip -Tube Steps - Silver -Bed Extender -LEER Tonneau Cover -Rampage Roof Cab Lights -Rampage Tailgate Light Bar Six Function SUPERBRITE with Reverse Lights, Running Lights, Brake lights, Emergency Hazard and L & R turn signals -exLED Toyota Tacoma Custom interior LED Light Kit -PIAA Xtreme White Plus head lights and fog lights -NITTO Terra Grapplers 285-70-17 -30" Avec CR-Series Led Light Bar in bumper grill -Two 6.5" Led light bar's attached to the A pillars -Hood hinge bracket mounts from Famous Fabrications -Exhaust muffler Aero Turbine AT2525XL -OEM Roof Racks -OTTRAW Rocker switch -Stant locking gas cap -Large T emblem and mid mount bracket from Diaz Fabrications
  18. Aug 16, 2014 at 6:11 PM
    #138
    tarheeler
    Newport News, Va
    3" lift
    Where do y'all mount the Bluetooth mic and how
  19. Aug 16, 2014 at 7:05 PM
    #139
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    If you get the iq one it comes with double sided tape and mines up stuck right next to the temp/sun glass holder.
  20. Aug 16, 2014 at 11:43 PM
    #140
    Armcphail
    Armcphail Member
    Aaron
    Chatham,Ontario
    4 cyl sr5
    Looking to purchase the 24 pin back up camera plug, could you tell me where you go it?
