2014 Non JBL w/ navigation retrofit DIY w/ info & part numbers
Discussion in 'Audio & Video' started by steveo27, Mar 3, 2014.
  1. Aug 17, 2014 at 7:18 PM
    #141
    steveo27
    steveo27 [OP] Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Glad to see my thread is still helping out.
    I still havent gotten around to wiring the back up camera to the new radio yet. I'm changing my cigarette lighters soon, so I have to pull the dash apart. If I remember, I'll update all the camera wiring.
    :beer:
    Tyco Electronics
    I mounted mine on the steering wheel clam shell right below the cluster
  2. Aug 17, 2014 at 7:34 PM
    #142
    tarheeler
    tarheeler Well-Known Member
    Newport News, Va
    06 PreRunner TRD offroad
    3" lift
    That's where I was thinking, did you mount with double tape, any pics. Also, thanks for your step by steps steveo27. I wouldn't have ever tried doing this without your post
  3. Aug 20, 2014 at 4:25 PM
    #143
    manthony67
    manthony67 Member
    Looking for suggestions
    Hey guys, Finally got most of my parts, still not enough $ for the nav antenna. But how do you remove the hazard and click unit from the old 07 radio/bezel to mount on the new bezel? Appreciate your help here.
  4. Aug 20, 2014 at 6:28 PM
    #144
    tarheeler
    Newport News, Va
    3" lift
    There's some small plastic tabs, I used a small screwdriver to pry in between and pull out the back, it's a pain in the but, once you get it started it comes right out
  5. Aug 21, 2014 at 4:37 AM
    #145
    manthony67
    manthony67 Member
    So there are no screws holding it in or I do not have to remove the radio from the bezel? Just some tabs on the back side of the hazard/clock unit?
  6. Aug 21, 2014 at 6:47 AM
    #146
    tarheeler
    Newport News, Va
    3" lift
    No screws, just tabs
  7. Aug 21, 2014 at 4:33 PM
    #147
    ZenkaiTaco
    ZenkaiTaco Well-Known Member
    Utah
    11 DCSB TRD OR
    Does anyone have any information on how I would go about doing this swap on my 2011 with JBL to a 2014 JBL Nav unit?
    Seems like people only swap the non JBL's in. I'm guessing the JBL stuff isn't as simple?
  8. Aug 22, 2014 at 7:56 PM
    #148
    coastalreb
    coastalreb Well-Known Member
    Mississippi Gulf Coast
    2012 TRD Sport
    Just did the full install on a 2012 non jbl TRD Sport. I have full functionality including the USB port. Loving this system! However, I'm having trouble viewing the apps on my system. I found a vin and registered entune on my phone, but it doesn't seem to be connecting to the system. Maybe I'm missing something.. I'll probably figure it out.
    EDIT UPDATE: I had entune with a legit vin on my phone, phone was connecting to the HU via bluetooth, but no entune apps. I re-started my phone (completely turned on/off) and opened entune. Went to "apps" on HU and it told me I needed an update. This took about ten minutes. Then, my apps all worked! Hope someone reading this with the same issue gets theirs working by doing a full reset on their phone. This makes your phone fully disconnect and reconnect from the entune system.
    Ventenueve likes this.
  9. Aug 22, 2014 at 9:32 PM
    #149
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    What kind of phone? Need the entune app on while connected to the head unit to use apps like IHeartRadio and Pandora.
  10. Aug 22, 2014 at 9:57 PM
    #150
    crazyhorse90210
    crazyhorse90210 Active Member
    Southern California
    06 Prerunner
    i wanted to note the first parts list of OP's post lists the backup camera plug as a 28 pin plug, when in fact it is a 24 pin plug (as is correctly identified further down with the picture). the confusion led me to purchase the incorrect plug at first but no worry, i'll get the 24 pin now.
    the 28 pin is part of the 20/28 harness of course.
    wes
  11. Aug 31, 2014 at 9:30 AM
    #151
    tarheeler
    Newport News, Va
    3" lift
    How do you get speed to show on GPS. I have clicked it on the options menu but it doesn't show on map. Is there another place to click it on
  12. Sep 1, 2014 at 12:56 AM
    #152
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
  13. Sep 1, 2014 at 7:30 PM
    #153
    tarheeler
    Newport News, Va
    3" lift
    I've read that manual several times and don't see anything about the speed setting. The only place I can find anything on the radio is on the nav screen, select options and then information and click speed setting to on. But nothing shows on screen when driving
  14. Sep 2, 2014 at 3:26 AM
    #154
    manthony67
    manthony67 Member
    I have purchased a radio for my '07 Tacoma. And it looks like an Etune Audio Plus. Does this radio have GPS? It seems to have a location for a GPS atenna on the back ( as shown on your diagram) But I do not see a GPS App when the radio is on.
  15. Sep 2, 2014 at 3:00 PM
    #155
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    I'll screw with mine tonight and report back. I know for getting the "arrival time" to display on the map it was simple as hitting the "i" icon on the lower right of the map display. Could be somewhere in there.
  16. Sep 3, 2014 at 1:29 PM
    #156
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    I can get it to show the speed limit just not speed
  17. Sep 3, 2014 at 1:33 PM
    #157
    tarheeler
    Newport News, Va
    3" lift
    Yep, don't make sense, never seen a GPS that didn't show speed. There's a place on the option page to click to show it but mine don't show up. Was wondering if it was just my unit or if all are like that
  18. Sep 3, 2014 at 2:40 PM
    #158
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    I wonder if it's because we have a pre-2012 model and there's some wiring / harness not installed on our trucks from the factory. I have my speedo and ScanGauge showing me the mph so I'm all set with that.
  19. Sep 3, 2014 at 2:45 PM
    #159
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    I don't even think there's an option to speed...this line from page 184 of the manual:
  20. Sep 23, 2014 at 6:02 PM
    #160
    3rdtoy
    3rdtoy Active Member
    fl
    09 base excess sr5
    My navigation is off between 50 and 100 feet ,does anyyone know if it can be adjusted ? It works very well in all other aspects. ( 14 nav hu in 09 access cab.)
