2014 Non JBL w/ navigation retrofit DIY w/ info & part numbers
Discussion in 'Audio & Video' started by steveo27, Mar 3, 2014.
  1. Sep 24, 2014 at 10:05 PM
    #161
    06yoda
    06yoda Well-Known Member
    Tanner
    Clovis, CA/ Emmett, ID
    1996 Landcruiser FZJ80
    Go into the nav settings and you can adjust it in whichever direction it's off on.
  2. Sep 24, 2014 at 10:06 PM
    #162
    06yoda
    Tanner
    Is anyone else's nav choppy. Mine works but isn't that smooth
  3. Sep 25, 2014 at 5:30 AM
    #163
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    Choppy as in not updating quickly? I think when I first installed mine it wasn't that fluid but that lasted about a day.
  4. Sep 25, 2014 at 7:45 AM
    #164
    crazyhorse90210
    crazyhorse90210 Active Member
    Southern California
    06 Prerunner
    what year is your truck? before a certain year the VSS (vehicle speed sensor) was not in the harness and in order to be accurate the NAV needs this input taken from the ECU down under the glove box. It's a pink wire. I can dig up pics if you think that is it.
    You can also check if your harness has it, it's the pink wire going into the 28 pin connector. I can't remember the pin (maybe 2?) but it's at one end. If you think this is the problem I will take a picture and tell you what pin.
    wes
  5. Sep 25, 2014 at 11:00 AM
    #165
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    Tanner I have an 09 with the 14 nav
  6. Sep 25, 2014 at 3:17 PM
    #166
    06yoda
    Tanner
    Thanks gents I'll have to look. Mine is an 06 and I mounted it with 3m double sided tape to the top underside of the dash. I don't think there is any interference.
  7. Oct 8, 2014 at 6:32 PM
    #167
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    Had anyone successfully connected an iPhone 6 to Bluetooth? My wife has one, won't find the Nav. I still have my iPhone 4s with iOS 8 so I may rule iOS 8 but again this is a different device.
  8. Oct 8, 2014 at 7:04 PM
    #168
    steveo27
    steveo27 [OP] Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    My GF's iPhone 5 has iOS 8 and connects fine to mine.
  9. Oct 8, 2014 at 7:13 PM
    #169
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    My wife had a 5 but had to get the latest and "greatest" :eek:
    If anything, this may require a new version firmware update from Toyota to the headunit and if that's the case, it may be a while.
  10. Oct 8, 2014 at 9:00 PM
    #170
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    Got it to work. Had to go into Bluetooth settings on the head unit and hit "Add" then on her phone it found the head unit. Messaging works like older iPhones where it displays on screen.
  11. Oct 9, 2014 at 9:50 AM
    #171
    coastalreb
    coastalreb Well-Known Member
    Mississippi Gulf Coast
    2012 TRD Sport
    I've never been able to get messaging to work. Wish I could with my iPhone 6. Honestly I havent really tried to make it work other than just hoping it would automatically set up. I'll tinker with it tonight.
  12. Oct 9, 2014 at 10:35 AM
    #172
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    On the phone go to Settings>Bluetooth and hit the (i) next to Tacoma you should get a menu. In that menu toggle on "Show Notifcations"
  13. Nov 3, 2014 at 7:27 PM
    #173
    Yota64
    Yota64 Professional Threadjacker
    This may have already been asked... But could you avoid the trimming of the surround by buying a 12+ surround, or would that not fit perfectly with the dash?
  14. Nov 4, 2014 at 6:00 AM
    #174
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    I thought about that initially but I have a 4WD so I would also need to buy the new 2012 4wd switch and hope the plugs in back were the same. Since you have a pre-runner you might be able to get away with the 2012 surround for cheaper.
    An even cheaper option would be to call junk yards and get an extra radio surround so you're not hacking up your original. I spent $50 on a spare surround to cut up and paint before installing it in my dash.
  15. Nov 4, 2014 at 8:17 AM
    #175
    Jones
    Jones Well-Known Member
    Texas DFW
    06 SSM Prerunner TRD-OFFROAD
    Front: 5100@1.75 with SR5 coils; Rear: 5100 and 1.5 Toytec aal; Tires: Hankook 265/75R16 RF08 ATM; Wheels: powdercoated off-road wheels with FJ TRD center caps
    It will fit perfectly. I bought a 12+ surround in black, used the vents and the little yellow clips from the old one and it worked.
    Here is the other thread with the part number.
    http://www.tacomaworld.com/forum/2n...retrofit-w-info-part-numbers.html#post9256923
    Silver color should be part number 5541204070 (check before buying, I have not bought it), it is should be around $202.10. The black one was $134. If you are good at painting save the $68.00 and spray paint it silver.
  16. Nov 21, 2014 at 11:16 AM
    #176
    phand00
    phand00 Well-Known Member
    Danny
    Canada
    11 DCLB 4WD TRD
    2.5 ICONS Extended Resi ICON 3 Add-a-leaf packs LR UCA 305/70R16 on IS TRD 16x8 CBI Front bumper Custom sliders Toyota slim toolbox
    Hi,
    does any 86860 antenna work with this unit? I mean, I found that the 86860-0C010 antenna online is about 150$ to 200$ If I look to other 86860-xxxxx from Prius or Lexus. They are a lot cheaper, maybe around 50$ - 70$
  17. Nov 23, 2014 at 5:44 PM
    #177
    steveo27
    Pittsburgh
    Yep, but like said, if you have a 4wd, youll need the switch too.
    I bought spare bezel to modify for mine.
    Speaking of which... I do have a spare '05-'11 bezel for sell right now if you're interested ;)
  18. Dec 1, 2014 at 10:52 PM
    #178
    gonz281
    gonz281 Active Member
    Edgar Gonzalez
    Houston, TX
    2010 Tacoma
    I bought the ac controls from a 2013 to match the radio and the bezel. I have a 2010. I didn't realize one of the plugs isn't just plug and play. Is there an adapter for it to be able to work?
  19. Dec 5, 2014 at 7:40 AM
    #179
    pkt1213
    pkt1213 New Member
    Can anyone give me the dimensions of this unit. Height, width and depth? I am thinking about trying a retrofit in to my 05 sequoia. I can fab whatever mounting bracket I need, just can't enlarge the factory opening much without getting in to the air vent.
    Thanks
  20. Dec 5, 2014 at 6:28 PM
    #180
    mesohungry
    mesohungry Active Member
    southern cali
    2010 DC TRD Sport LB
    Looks like you modified a 2011- bezel?. What if I bought a 2012-1014 bezel wouldn't it just pop right in, flush?
