2014 prerunner wheels fit 2003 prerunner?
Discussion in 'Wheels & Tires' started by Shortcut, Jul 29, 2014.
  1. Jul 29, 2014 at 5:11 AM
    Shortcut
    Shortcut [OP] New Member
    Mark
    Ball Ground, GA
    2003 Toyota Prerunner 4cyl
    Hi folks,
    Just got the Tacoma last night. I found a set of 2014 prerunner wheels and tires and I was wondering if they would fit my 2003 prerunner. It's a 2.7l.
  2. Jul 30, 2014 at 1:36 PM
    Mr. Biscuits
    Mr. Biscuits gentleman, scholar, part-time delinquent
    Brennen J
    Bakersfield
    2000 PreRunner TRD V6
    -Bilstein 5100/ Eibach 3" lift -Custom 2" lift rear leaf pack -Crystal clear headlight housings -updated (01-04) rear tail lights -custom front tube bumper -custom rear tube bumper -Deckplate mod -Aero Turbine 2525 exhaust -Kenwood Headunit -Pioneer Speakers -black door handles -Debadged, rebadged black -Ultraguage
    they'll fit the lug pattern but you'll probably be rubbing the UCA or fender without wheel spacers. they newer Tacomas come with more backspacing and different offset making them "tuck in" more on 1st gens.
  3. Aug 6, 2014 at 6:59 PM
    NM Lance
    NM Lance Well-Known Member
    2014 TRD 4X4 6 spd
    I bought some newer TRD rims for my 2003 4X4. I believe the rims came off a 2008, but I cannot hang my hat to it... they appear to be identical to those on my 2014. They fit nicely, although I had to purchase hub-centric lug nuts at $5 apiece, but that's another story. I have 265/75 Duratracs on the TRD rims, the tires rub lightly on the frame if I make a hard turn in either direction. I imagine '14 rims on a '03 should not be a problem assuming your tires do not have gnarly side lugs.
  4. Aug 6, 2014 at 7:10 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2000 Prerunner TRD
    bilsteins, 2010 Tacoma 17" alloys w/265's, driveshaft mods, 1.25" hubcentric spacers.
    they will work, 265's will rub very slightly at full lock, 3/4" Bora hubcentric spacers will correct the rub, and it gives the older truck a slightly wider stance...;)
