2014 Ring and Pinion help...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fireman9027, Apr 18, 2015.
  1. Apr 18, 2015 at 7:06 AM
    fireman9027
    fireman9027 [OP] Active Member
    2014 Double Can TRD Offroad
    Hey folks,
    I need to do a gear swap on my 2014. It's 4x4, automatic with e-locker. The shops and vendors that I've contacted don't have any idea if they have gear sets for my truck, they say there was a diff change in 2013. So my question is, has anyone done a R&P swap on a 2013-2015 4x4 auto with the e-locker? Did you run into the same issue? What did you do?
    Thanks for looking
  2. Apr 18, 2015 at 9:38 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    the elocker diff has been the same for a LONG time.
    Call east coast gear supply, they will know exactly what you need.
  3. Apr 18, 2015 at 10:20 AM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    I was told something similar from a local builder/fabricator. I was able to confirm that at least the carrier is the same. As in an ARB RD129 will work on all Tacoma and Tundra 8.4 axles. Not sure why the gears wouldn't work.
    I 2nd the suggestion of calling ECGS. I confirmed w/ Toytec when I was inquiring. They made a call to the local ARB dist. and confirmed it will indeed fit a 2014.
  4. Apr 18, 2015 at 9:10 PM
    fireman9027
    Thanks I'll all monday
