2014 Rock Therapy - Official Thread
Discussion in 'Moab' started by NYCO, Dec 16, 2013.
  1. May 22, 2014 at 4:27 PM
    #4161
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    dont have one
    its a stand alone circuit with a relay. i dont have the factory computer controlling it
  2. May 22, 2014 at 4:29 PM
    #4162
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    oh boy:confused:
    that makes much different.... how does it know when to stop the motor?
  3. May 22, 2014 at 4:32 PM
    #4163
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i ran into an issue with this last year...the motor kinda just...does a full movement. so last year the rack wasnt aligned correctly so it didnt engage all the way. I ripped it apart less than 2 hours before the hells run and figured out the rack just had to be aligned to what a factor locker would have set it to (compared to a different truck's rack position with factory locker). So after aligning it it worked fine.
    now it doesent make its full movement so it cant slide the rack enough to lock it in fully
  4. May 22, 2014 at 4:40 PM
    #4164
    lotsoftoys
    Jace
    Denver
    bunch of crap
    hmmmmmm....id try it with no load, take it out and move it rom max to min and watch it sweep.
  5. May 22, 2014 at 4:43 PM
    #4165
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i guess ill compare em. but with a load it sounds like a dying cat. i know if i use it with the motor i wont have any faith with it on hard trails.
    i had it out wheeling and engaged it with the button, and it made, to me, the exact same noise it did when it was mis aligned. and I know it was aligned because we set it a few days prior.
  6. May 22, 2014 at 4:56 PM
    #4166
    lotsoftoys
    Jace
    Denver
    bunch of crap
    huh, i guess it could wear out, it is a motor.....
  7. May 22, 2014 at 5:14 PM
    #4167
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Just use the machine in the hallway, fresh free ice everyday... Oh wait...:p
  8. May 22, 2014 at 5:17 PM
    #4168
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    well i know its burnt out...because we took the whole thing apart and looked at it. like, i know for a fact a coil is burnt out haha. im not guessing at that part. and im almost positive it shorted out when an exposed metal prong on the relay hit a part of the metal cab that was tubbed and maybe got missed when i was painting it
  9. May 22, 2014 at 5:21 PM
    #4169
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Pre-cool your cooler. Helps alot. Fill it up with ice the night before or whatever and then get rid of the water and fill up with frozen water bottles like suggested, also the bigger the mass of ice you can pack the better and still fit ur food, like gallon jugs if you have that kind of room...
  10. May 22, 2014 at 8:44 PM
    #4170
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    Ripped out my sway bars, dropped the rims and tires off for a swap of valve stems, beads and balance of the rim only, of course mounting of the 37s
    240s install
    Oem hand throttle,
    Tomorrow clean and pack
  11. May 22, 2014 at 8:48 PM
    #4171
    timmyedge
    timmyedge Well-Known Member
    Timmy
    Layton, UT
    TRD OR DCSB
    Magnaflow cat back exhaust with down pipe, Volant CAI, BHLM w/new bulbs, 3000K replacement fog lights,Debadged/Painted/Re-badged to say TACO/ New JVC Dbl Din Nav in dash/ Fosgate 400W amp/ Fosgate 10" sub/Tacotunes box/ Order OME complete lift w/Daker springs and LR UCA's/Ordered SCS Stealth 6 Matte Gun Metal -265/70R17 Goodyear Duratracks, BAMF behind gril light bar, Custom Trial Ridge Sliders , bed mat, weathertechs, Wet Okles, All Pro Front IFS skid Plate, Plasti Dir rear bumper Future MODS-Skids IFS/Fuel tank, transfer, rear dif
    Anyone gonna be in Moab early in the week wanna go MTBing if there any cyclists going?? Ill be in Moab Sunday night or Monday.wanted to get a few trails in??
    Oh I'm super stoked as well :)
  12. May 22, 2014 at 9:51 PM
    #4172
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    stocked up on some Colorado micro brew. gear all over our down stairs. early start tomo to pack the truck and head west :D
    see everyone next week :cheers:
  13. May 22, 2014 at 10:27 PM
    #4173
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    I finally get to start on my mod list! Wooohooo! Welp, new uca ball joints here i come!!! At least i'm not on spacers this year!!!
  14. May 22, 2014 at 11:28 PM
    #4174
    rocktoy
    rocktoy Well that escalated quickly! But it was fun.
    Rocky
    poky
    sased 2nd gen 3.4runner
    sas, 4.88, 3.4swap, rear spool, front arb, cheap led light bars, tg front bumper, self built slider and rear bumper, pg octane r 12 subs, vision x rock pods
    I've got 12 hours before I hit highway
  15. May 22, 2014 at 11:30 PM
    #4175
    rocktoy
    Rocky
    poky
    Big ice saving tip. Freeze everything possible. Keep out of your cooler. The wet towel on top works great. As an HVAC tech I could explain why if you care.
  16. May 23, 2014 at 2:40 AM
    #4176
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    Haha!
  17. May 23, 2014 at 3:15 AM
    #4177
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    As did I!! Got some good locals and I'm hitting the road NOW!!
  18. May 23, 2014 at 3:33 AM
    #4178
    mh.meier
    The Doctor
    Commiefornia
    :censored:!!!!!
  19. May 23, 2014 at 6:20 AM
    #4179
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I've got roughly 4200 minutes till i leave
  20. May 23, 2014 at 6:39 AM
    #4180
    wuzzy121
    wuzzy121 Well-Known Member
    Colorado Springs
    05 AC 3" lift
    ARB front bumper w/ Warn M8000 winch and lights, 3" lift, Tire gate tire carrier, All-Pro Expedition leaf springs, weather tech floor mats.
    Does it have to do with evaporation?
    When I was deployed we would put bottles of hot water in a sock then another one, then wet them, then hang them from our mirror while we drove, the evaporation would cool them down more then I expected.
