2014 Tacoma lifted, tire & wheel help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Drogen, Mar 30, 2015.
  1. Apr 1, 2015 at 5:53 PM
    #41
    tacozx6r
    tacozx6r Well-Known Member
    I was able to work a deal with a local shop I have done business with who takes good care of me. $1750 for the kit and $550 for install. No coilovers though. Just the spacer for now. The wheels came through America's Tire (discount tire). They matched the net. The tires sound about right in price although you could maybe talk them down 20 or 30 a tire.
  2. Apr 1, 2015 at 6:02 PM
    #42
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    You do know you can run the rcd full length front shock f4-be5-e122-to and then can elimate that top hat space on your lift.
  3. Apr 1, 2015 at 6:18 PM
    #43
    tacozx6r
    I had the 5100s from my 3" lift before otherwise I'd have skipped the spacer in short order. The fox coilovers are on my radar but if I can get a good working coilover for a little less, I'd not be opposed. Tell me about your experience with the RCD shock you recommended. Mine have the RCD stamp too btw.
  4. Apr 1, 2015 at 6:29 PM
    #44
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    I plan on getting a 3 inch leveling kit with bilsteins all the way around my truck is my baby and still new bit seen it's fair share of dirt on a calm basis not trying to kill my truck . Is this a decent lift? Sorry can't figure out how to post my own. It's only going to cost me 575 and I already got bigger mudders and rims
  5. Apr 1, 2015 at 6:38 PM
    #45
    BORNWILDGUY
    Rich
    Florida
    The rcd full length shock is basically a non adjustable 5100 that you can run and not have to run the top hat with the basic db lifts. With the stock spring it will give you 5" of lift. On my set up I ran a 1/2 wheelers on top plate spacer and longer studs to yield the 5 3/4 - 6" lift. Radtaco914 also used this set up with the ebiach springs which give and additional 1.5 lift and I believe he had a small 1/4 spacer as well. If using a coil spring for the additional gain I would probably recommend using an ome 883 since the spring rate is a lil less than the ebiach which should give you a lil better ride. This is a good alternative to spending the extra coin on coilovers. You can use this front shock on the procomp, zone, bds, fabtech db lift kits.
    Looks like this is the best price so far on them. Price is for 1 shock not a set.
    http://www.dieselstuff.com/rcdf4be5e122t0.html
  6. Apr 1, 2015 at 9:15 PM
    #46
    jck1978
    jck1978 Member
    MKW can you pm me the details of your dons setup? That looks like the way I want to go with my Tacoma. Thanks
  7. May 28, 2015 at 10:54 AM
    #47
    eazzzley
    eazzzley Active Member
    New Mexico
    TRD Off Road
    My Current Mods Tacoma Floor Mats (Weather Tech) TRD Seat Covers (Red and Black) TRD Shift Knob Blacked Out All Emblems TRD Sport Black Painted Matched Grill BFG TA KO2 265/70r17 Tires TRD Pro Black 17" x 7 Wheels W Black Lugs Blacked-Out Inner Headlight Housing "Tacoma" Bed Mat W Bolt Down (Next) Powder Coated Rear Bumper (Future) Toytec Adjustable Coilovers Set at 1.5" To Level (Future) No Rear Lift Color Match Bushwacker Pocket Flares/Rivets (Future) Smoked tail lights (Future)
    Just out of curiosity what is the 5100?
  8. May 28, 2015 at 11:11 AM
    #48
    BORNWILDGUY
    Rich
    Florida
    Bilstein shock
    F4-BE5-E122-T0
  9. May 28, 2015 at 2:53 PM
    #49
    toy 2
    toy 2 Well-Known Member
    Dave
    Reno, NV
    Little more info on the 5100 for the front is they have adjustments so you can lift the front of your truck is you want
