2014 Tacoma lube at service???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by imatacomaowner, Nov 16, 2024.
  1. Nov 19, 2024 at 12:22 PM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    ^ This. There are 2 u-joints on the front driveshaft. Unless they have been changed (and likely even if they were changed), each u-joint will have a zerk.
  2. Nov 22, 2024 at 8:38 AM
    imatacomaowner
    imatacomaowner [OP] Well-Known Member
    cali
    tacoma 6 cyl 4wd
    We looked all along the driveshaft and only saw 3. There was one forward, one forward, middle and one in the rear.
  3. Nov 22, 2024 at 8:41 AM
    XSplicer62
    Jefferson State
    OK, that makes sense for the rear driveshaft. Specifically, what about the front driveshaft?
  4. Nov 26, 2024 at 7:21 AM
    imatacomaowner
    cali
    tacoma 6 cyl 4wd
    I’m not driveshaft familiar enough to be certain, but aren’t they connected? How far forward is it?
  5. Nov 26, 2024 at 8:31 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Think about it this way: the rear driveshaft drives the rear wheels, and the front driveshaft drives the front wheels. It should be pretty visible between the front axle and transfer case (attached to the transmission).
    Does your truck happen to have a full set of skid plates? That would cover the front driveshaft back to the transfer case, and would explain some of the confusion.
  6. Nov 26, 2024 at 9:10 AM
    XSplicer62
    Jefferson State
