2014 Tacoma Oil Change & Valve Chatter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ultravista, Aug 7, 2021.
  1. Aug 8, 2021 at 10:19 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If the noise truly showed up AFTER the last oil change maybe try using a different filter, see if that helps
    The chances of a bad oil filter are low but never zero
    Sometimes the new filter will come with plastic over the open end. One time I found a piece of that plastic down in the filter and partially blocking the oil flow
  2. Aug 8, 2021 at 10:31 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Wondering if the chatter started after the oil change with synthetic oil....going back to conventional will yield some additional information. See video
    https://www.youtube.com/watch?v=QSjrIwYpu2w
    Good Luck - keep is posted !
    Go Team TW
  3. Aug 8, 2021 at 2:15 PM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    Sometimes in the winter mine makes so much noise one would think the engine is going to explode when first starting. I first heard this about 8 years ago. I don’t give it a second thought these days on the odd time it happens now. Also I second the high test as it does quiet down a bit. For different reasons of course. I used to think that it quieted down a bit after I changed my oil, or that it ran better but it didnt. Placebo effect.
