2014 Tacoma Outside Temperature Gauge?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ultravista, Oct 13, 2013.
  1. May 19, 2014 at 7:00 AM
    #121
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I think that only works if you have the temp sensor :/
    But i'm :notsure:
  2. May 19, 2014 at 7:18 AM
    #122
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    if you have AC there is a temp sensor
  3. May 19, 2014 at 7:48 AM
    #123
    AR15xAR10
    Not in my 08 base model, its supposed to be on the center radiator support and its not there :(
  4. May 19, 2014 at 8:27 AM
    #124
    spetro
    spetro Active Member
    North GA
    2018 off road
    Nice..but overkill if you just want outside temp. All the other stuff for the most part is handled via the onboard nav system.
  5. May 19, 2014 at 1:57 PM
    #125
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    This situation is somewhat narrow, since the entune and "plus" options aren't present of most trucks:
    So frustrating...if anyone has insight on this, it would be appreciated if you could 'splain the reasoning. If the temperature sensor is present because of the A/C, why would Toyota make the entune get its value from some quasi-nearby weather station instead of the onboard?
    The obvious would be the less integration cost since its just a data value from the over-the-air data feed instead of data connect from the ECU, and that is a stretch considering entune systems keeps track of all kinds of data from the ECU (mileage, etc.)...why no temp too?? Toyota, you disappoint!
  6. May 19, 2014 at 3:00 PM
    #126
    jessandjamie
    jessandjamie Well-Known Member
    Arizona
    I have a 2014 Offroad with Entune Premium with the weather app. So I obviously have AC. I also have a scanguage and tried the Toyota X-Guage code and it doesn't work. I realize I can just get it through intake temperature guage, but that is always atleast 7 degrees or more off (depending on speed)
  7. May 20, 2014 at 8:40 AM
    #127
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    OK
    on my Yaris I pull accurate outside temp from scangauge
    tacoma has mirror
    I must be incorrect in assuming same temp can be pulled from tacoma
  8. May 20, 2014 at 9:06 AM
    #128
    AR15xAR10
    Its alright man. I'm not one to bicker with people about stuff like that. I just wish i had the sensor stuck in my wiring harness somewhere so i could just get the mirror. :eek:
  9. May 24, 2014 at 7:56 AM
    #129
    ultravista
    ultravista [OP] Well-Known Member
    2023 Tacoma
    Is Toyota still offering the $100 for the missing temp gauge?
  10. May 24, 2014 at 2:46 PM
    #130
    PMDclassics
    PMDclassics Well-Known Member
    Todd
    Bismarck
    TRD Sport
    I plan on calling in to find out on Tuesday.
  11. May 25, 2014 at 10:20 AM
    #131
    Mikelu
    Mikelu Well-Known Member
    Cupertino, CA
    14 Tacoma 4x4 TRD
    After 3 months of research and finding parts, I have a working outside temperature gauge back in my 2014 Tacoma! It was a lot of work, but the results have been great. As noted before, the HD signal isn't available where you really need it. Yesterday, the HD radio said that the outside temperature was 68 degrees. My newly installed OHC gauge said it was actually 81 degrees! the HD signal was getting temperature from a town 30 miles away.
    As discussed in other threads, there are two types of OHC consoles available. The 2005-2008 (requires 6 wires) and the 2009-whatever year they stopped making them, which requires 5 wires).
    Only 2 wires are available in the roof lining. The remaining wires need to be routed to two different connectors and to the temperature sensor. If a newer OHC is used, you can probably tap in to the existing sensor.
    The biggest challenge was modifying the OHC so that the microphone could be added. I'm putting together detailed information if anyone is interested.
  12. May 25, 2014 at 10:47 AM
    #132
    Ntricky
    Ntricky Member
    Alberta, Canada
    2014 Spruce TRDSport 4x4
    Hi
    Just joined the forum, have a three week old 4x4 DBL TRD Sport.
    When I picked up my truck up I only noticed when I got home there was no auto dimming mirror or outside temp gauge. I called the dealership and explained and they said they would get back to me, which they did, they said that although it is in the brochure as part of the TRD Sport package it is not longer part of the package. I politely explained that I bought the trucked based on that specification and my expectation is that they would make this right - ie install a auto dimming mirror with temp gauge. Next day the customer relationship manager from the dealer called and say they are trying to source the part and will let me know. Sure enough they agreed to install the auto dimming mirror with temp gauge. It took a week or so for the part to come (OEM Gentex) and they put me in a loaner for a day so they could install it.
    Overall I am happy they put this right, but for sure if I had not been firm with them I doubt they would have done it.
    My advice put some polite pressure on your dealer to make the missing specification right.
    The dealer I bought the truck at was Joe Myers in Houston, there were pleasant to deal with and low pressure sales. ( I previously walked out a different dealership due to high pressure sales)
    As I mentioned to the salesman, I work hard to earn my money and will choose where I spend it!
    Apart from the hiccup with the mirror/ temp gauge I am very happy with my truck, the Spruce Mica color has attracted lots of positive comments.
  13. May 25, 2014 at 3:17 PM
    #133
    PMDclassics
    Todd
    Bismarck
    TRD Sport
    So what brochure does it say the TRD Sport Package comes with the auto dimming mirror and temp gauge? I looked on Toyota's web page and did not see it listed there. Is it a brochure at the dealership? if so is it still at the dealership so one can get some proof before calling the dealership?
    Thanks
  14. May 25, 2014 at 3:22 PM
    #134
    AR15xAR10
    Here: hope you can read it lol
  15. May 25, 2014 at 3:25 PM
    #135
    AR15xAR10
    Another angle [​IMG]
  16. May 25, 2014 at 3:50 PM
    #136
    GuitarGuy91
    GuitarGuy91 Well-Known Member
    Stephen
    Glenville, NY
    16 TRD OffRoad Acc Cab (ordered)
    Found the 2014 eBrochure on Toyota site. Only lists the auto-dimmer and temp gauge on the limited package. They can probably update that though whenever they want.
    I've got to look at my window sticker also, and see if the auto and temp gauge were suppose to be on my truck (2014 TRD OR). Not something I'm gonna get insane about, but if it's on the sticker I'm getting it! The entune display shows weather from my phone, including temp. So it's not super important, but definitely makes the truck a little nicer. Plus if it gives me a compass that's a big plus!
  17. May 25, 2014 at 8:39 PM
    #137
    PMDclassics
    Todd
    Bismarck
    TRD Sport
    Thanks for the scans guys. I just contacted my salesman from the Toyota dealership by email and told him to schedule me in to have the mirror swapped out....we will see what happens.
  18. May 25, 2014 at 8:41 PM
    #138
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Hmm, my 09 Auto Dim works flawlessly .. love it
  19. May 25, 2014 at 8:42 PM
    #139
    AR15xAR10
    I wish i had it :/
  20. May 25, 2014 at 9:13 PM
    #140
    double dee
    double dee Well-Known Member
    Arizona
    Does it say 2014 at the top anywhere?
