2014 Tacoma +Pioneer AVH-400nex + stock XM shark Fin antenna
Discussion in 'Audio & Video' started by harley3, Jun 9, 2014.
  1. Jun 9, 2014 at 1:06 PM
    harley3
    harley3 [OP] Well-Known Member
    Scott
    Lexington KY
    2014 DCSB TRD Off-Road 4x4
    Redline Tuning Elite Hood Lifts, Weathertechs, Black Devil Horns (thank you Andres), G-Tek Fab Door Sill Protectors (thank you Greg), interior LED lights, Pioneer AVH-4000NEX, Kenwood 700w amp, Alpine door speakers tweeters and sub, SuperCrewSounds single sub box
    I was wanting to use the stock shark fin antenna with my aftermarket Pioneer 4000nex stereo & SiriusXM SXV200 but I had read on another thread that the Shark Fin Antenna Adapter SFA12M will not work with the 2014 Tacoma stock XM antenna. I have been trying to find a solution but can't find anything. I also called VAIS Tech and got no help what so ever.
    Has anyone done this with a 2014 yet?
  2. Jun 11, 2014 at 8:00 AM
    fergsonfire
    fergsonfire Electrical Guru
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
    I am doing this on a 2013 this weekend. What you need is a female smb to female smb adapter like this:
    http://www.digikey.com/product-detail/en/142245/ACX2158-ND/3868273
    and an xm extension like this:
    http://www.amazon.com/SIRIUS-Universal-Antenna-Extension-SBRGT-5/dp/B004SQ48E6/ref=sr_1_2?ie=UTF8&qid=1402498760&sr=8-2&keywords=5+ft+xm+extension
    Using those 2 together after pulling the xm antenna lead from the blue connector in the drivers kick panel area should work. I will let you know later this weekend.
  3. Jun 11, 2014 at 11:57 AM
    harley3
    Scott
    Lexington KY
    Thanks. Def. let me know if that works for you. I may give it a shot. My concern is that since the Shark Fin Antenna Adapter SFA12M from VAIS Tech works for the 2009-2013 but doesn't work on the 2014, did they change a connector on the 2014?
  4. Jun 11, 2014 at 12:51 PM
    fergsonfire
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
  5. Jun 11, 2014 at 2:34 PM
    harley3
    Scott
    Lexington KY
    Thanks, Kyle. I appreciate it. Yeah at $30, your idea is worth a shot. Not so much at $60
  6. Jun 12, 2014 at 6:27 AM
    double_b
    double_b Well-Known Member
    Red Lion, PA
    '14 DCab Tacoma TRD Off Road
    I am considering the same HU(I keep going back and forth on stock HU with processor vs aftermarket...hence my poll haha)
    I have a question......what are you doing about the back up camera? Is there a solution for that yet? I thought the 2014 camera had a different voltage than previous models.
  7. Jun 12, 2014 at 7:47 AM
    fergsonfire
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
    I have a 2013 and am tapping into the factory signal. Voltage shouldn't make a difference in the image presented, it may skew colors, but I couldn't tell you. I will see if I can find it in TIS if there is indeed a voltage difference
  8. Jun 12, 2014 at 7:57 AM
    fergsonfire
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
    After checking TIS Voltages on both cameras are exactly the same. It appears the only differences are a 6 pin connector (that only uses 4 pins...) on the 2014 and the 2014 going to the head unit not the rear view mirror. Otherwise power, ground, and AC waveforms are all exactly the same
  9. Jun 12, 2014 at 8:16 AM
    double_b
    Red Lion, PA
    So it would just be an issue of finding the correct 6 pin connector that only has 4 wires to go into the HU? I recall seeing a thread on this topic and something about a seller on eBay working on them.
  10. Jun 12, 2014 at 8:18 AM
    fergsonfire
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
    I can get you the pins if you want, regular or navigation?
  11. Jun 12, 2014 at 8:24 AM
    fergsonfire
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
    24 pin connector on the back of the HU pins 12 and 24, wires are red and white, red V+, white V-
  12. Jun 12, 2014 at 9:56 AM
    harley3
    Scott
    Lexington KY
    Double_B, there is a guy on ebay (ckremernimrod1) and he can make a harness for you for $30 shipped. I haven't bought the harness yet cause my buddy wants to research it first before I spend money for a harness. He does this stuff professionally and I just help. (or try to not get in his way)
  13. Jun 12, 2014 at 11:34 AM
    double_b
    Red Lion, PA
    Thanks for the info guys!! Swaying me more toward a new HU....this one!! lol
  14. Sep 7, 2014 at 7:08 AM
    double dee
    double dee Well-Known Member
    Arizona
    Does anyone have more info on getting the oem back up camera to work with a pioneer head unit? I have tried contacting ckremernimrod1 on ebay several times without success. I believe this is the correct plug for the camera. Can I tap into somehow?
  15. Sep 8, 2014 at 9:48 AM
    harley3
    Scott
    Lexington KY
    Sorry that I don't have any detailed info for you. Since my install guy was having trouble getting it hooked up, we just ordered the harness from ckremernimrod1 and it worked great. I think we I first contacted him it took a few days to a week
  16. Sep 8, 2014 at 11:47 AM
    double dee
    Arizona
    Do you have his email or contact info from the paypal receipt?
  17. Sep 8, 2014 at 12:05 PM
    harley3
    Scott
    Lexington KY
    Oh wow...I never even thought to look there for it. I spent about 30 minutes searching my old emails cause I knew I had it somewhere.
    Looking at PayPal only took about 30 seconds. Can't believe I missed that.
    vehicleaccessorysolutions@gmail.com
  18. Sep 8, 2014 at 1:22 PM
    double dee
    Arizona
    Awesome!!! Thanks bud!
