2014 too much rust for front end alignment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by geoff w, Nov 20, 2021.
  1. Nov 20, 2021 at 3:26 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Another problem nobody mentioned is that given the amount of visible corrosion, I'm willing to bet the alignment cam bolts in the lower control arms are rusted / seized up too. That means in order to align it, you'll need both LCAs plus all new alignment cam bolts.
    TegoTaco, blu92in99 and whatstcp like this.
  2. Nov 20, 2021 at 6:30 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    If the rest of the frame is good, I would consider new LCAs, tie rod ends, sway bar ends, etc. It will cost you some $ but would refresh the front end.
    Taco 422 likes this.
  3. Nov 20, 2021 at 7:18 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’m betting the shop had an idea they would be seized and they didn’t want to fool with it.
    In a way, I can’t blame them for not wanting to do it. At least they were honest?
    I think if the frame is ok. It’s worth spending money on it.
    But it’s hard to believe the frame is “ok” with the pics I’m seeing so far?
  4. Nov 20, 2021 at 9:06 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    The bits & pieces of the frame that I can see in those pics do not look ok. Maybe OP can provide some pics of the frame and hopefully prove me wrong.
    eherlihy likes this.
  5. Nov 20, 2021 at 9:15 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    To answer one of your questions, yes it is highly unusual to have that amount of rust. Especially for the year and it being a CA truck. There are 1996 Tacomas out there with minimal rust. Something isn't right here. Maybe where you go for car washes has been the culprit. Something is to blame for all that rust.
    tcjacado and wi_taco like this.
  6. Nov 20, 2021 at 9:31 PM
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    My first truck was a 2001 Ford Ranger that was sitting in Carlsbad next to the coast. I bought it when it was 10 years old and the rust in the undercarriage was pretty bad but still not to this extent. Weird how the frame is unscathed and just the front end components are majorly effected. There has to be something more to the story here
  7. Nov 20, 2021 at 9:49 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Hopefully not the black tar from Death Stranding? I kid.
  8. Nov 21, 2021 at 7:00 AM
    Williston
    Williston Unknown Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    I can contribute as I have a 2014 w/107k on it and has spent all of its time in southern New England. My front end components are pretty good for a seven year old vehicle. The sway bar, tie-rods and control arms all look good except for the welds. Just minor surface rust here and there which I have painted and fluid-filmed. I'm amazed at how bad yours is.
  9. Nov 21, 2021 at 7:08 AM
    parel
    parel Well-Known Member
    Kin
    Calgary, AB
    (ex. 2014 Black Tacoma TRD)
    OEM FJ TRIBUTE EDITION (REPLICA)
    The tire monkeys couldn’t align mine but the red wrench beats all. Also I found liquid wrench to do fuck all.
    IvanhoeTaco[QUOTED] likes this.
  10. Nov 21, 2021 at 7:35 AM
    eon_blue
    Azusa, CA
    That's pretty bad but it's not uncommon for vehicles in CA to get rusty when they spend their lives near the ocean. That salty air gets to them over the years.
    blu92in99 likes this.
  11. Nov 21, 2021 at 7:45 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    I’m shocked that your truck wasn’t previously owned in a road salt state or used frequently on the beach. That’s an unusual amount of rust for street use in Cali, unless you live basically on the beach and there’s salt spray exposure daily. It’s amazing how much salt gets in the air within a block or two of the beach.
  12. Nov 21, 2021 at 7:58 AM
    dleithaus
    dleithaus Well-Known Member
    Washington State
    2024 TRD OR iForce Max
    Thanks for posting those contrasting pictures.
    In another life I sometimes played a corrosion inspector for industrial customers (for equipment using products which was supposed to reduce corrosion).
    I looked at @geoff w 's pictures and immediately thought that is a LOT of rust for 8 years of service, regardless of the environment.
    Your own pictures indicate what I would consider normal (no significant corrosion).
    I would defer to a Toyota service agent with an elevation to a national Toyota agent for evaluation.
    geoff w[OP] likes this.
  13. Nov 22, 2021 at 4:24 PM
    geoff w
    geoff w [OP] Well-Known Member
    malibu
    '14 Tacoma 4x2 SR5
    Just to get the ball rolling in case others have similar issues on newer Tacomas not in the designated states for frame recalls, I filed a report with NHTSA regarding a potential safety concern. Based on some of the other posts I've seen here on Tacoma World for earlier models and Toyota dealers tagging the cars as unsafe to drive, I figure this has the potential to fail at some point, given the amount of corrosion present. More to follow...
    dleithaus likes this.
  14. Nov 22, 2021 at 6:35 PM
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    You need to rinse your undercarriage. The humidity and latent salt in the air in the area (Malibu) will rust the hell out of anything. Hit up a boat shop and get the miracle grow like sprayer of salt neutralizer spray for PWC's - learned this trick from the state lifeguards.
  15. Nov 22, 2021 at 6:37 PM
    #35
    Taco 422
    USA
    Also the fitting on your power steering line looks ready to fail.
    You need a few new components but it's salvageable.
  16. Nov 22, 2021 at 6:40 PM
    #36
    Taco 422
    USA
    Y'all need to understand he's in a spot where the wind always blows over the ocean onto the land, and there's latent salt everywhere. The sand and "dust" and "road grime" he incurs on a run to Safeway is going to be like driving on the beach. The beach blows onto the highway and residential streets.
    This is the result of fog/moisture and the salt on the roads from living in Malibu.... so everyone should move to Temecula and life would be good. For the tacos.
    geoff w[OP] and parel like this.
