2014's intermittent wiper switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mattvivsound, Aug 21, 2014.
  1. Aug 21, 2014 at 6:11 AM
    mattvivsound
    mattvivsound [OP] Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
    Truck is a 2014 Access Cab, 4x4 with 2.7 I4.
    Yes I've seen many posts about this and I am confused about which part number I'll need. Now most of the post I am reading are from 2009ish.
    IF I go on to the Online Parts catalog and use a 2013 Tacoma (I couldn't find a 2014 Tacoma parts catalog). It says I need 84652-02710.
    Here the part that throws a curve ball, I've seen a couple people say the 84652-02610 has worked on their '12+. Also its reports that the -02610 possibly has the backwards intermittent speeds but to use "84652-04141" instead for correct intermittent speeds.
    My research has shown:
    84652-02710 works for 2012-2014 Tacoma and 2014 Tundra and 2013-2104 Corolla
    84652-02610 works for 2009-2011 Tacoma (but may work on '12+)
    84652-04141 works for 2005-2008 Tacoma (but may work on 09-12) and 2007-2011 Camry, 2007-2011 Camry Hybrid, 2006-2008 Solara, 2007-2013 Tundra
    Just trying to know which one to order.
  2. Aug 21, 2014 at 7:06 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
  3. Aug 21, 2014 at 1:23 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  4. Aug 21, 2014 at 2:54 PM
    jbcanes
    jbcanes Well-Known Member
    Justin
    Tampa, FL
    14 PreRunner double cab
    backup camera, intermittent wiper, step bars, bug deflector, window vent, console vault,solid fold 2.0, 2016 sport wheels, front camera, anytime rear front camera mod, homelink mirror, dash cam, unifilter,
  5. Aug 21, 2014 at 3:00 PM
    Djg21
    Djg21 Well-Known Member
    Saratoga, NY
    My 2014 has an intermittent wiper. What am I missing?
  6. Aug 21, 2014 at 3:23 PM
    jbcanes
    Justin
    Tampa, FL
    Not all models come with intermittent wipers. Base models or convenience package do not.
  7. Aug 22, 2014 at 6:10 AM
    mattvivsound
    Southern MD
    So what's the difference between the 3 part numbers?
    Also, when I pull back to spray fluid on the windshield, will the wipers move at the same time?
  8. Aug 22, 2014 at 8:25 AM
    B737
    Kevin
    Jersey Shore
    stock
    Yes they will all wipe when u spray.
    I believe the different part numbers have to do w the direction u end up moving the wheel for the longer delay wipe, rolling it forward or backward. There are endless discussions on this.
    I don't know how Toyota puts those base stalks on the truck. Such pieces of garbage. When I asked the dealer about this they said "it would involve rewiring and is impossible" lol they crack me up
  9. Aug 22, 2014 at 11:53 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    yeah that is usually BS. a lot of things are pre-wired and ready to activate
    I got a base Yaris and just by buying the switches I activated cruise, fogs (plus relay and the fogs themselves), rear wiper delay. all I did was get rav4 controls and plugged into the existing Yaris connections and bam, 150 bux in switches for what on a Yaris could cost 1200 if ordered that way !!!!
  10. Aug 23, 2014 at 5:57 AM
    Plain Jane Taco
    USA
    I don't get it either. Even the Yaris comes with 3-speed (fixed delay) wiper. Hell, I'd been happy with that....though I do like my variable delay.
  11. Aug 25, 2014 at 5:50 AM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    We all get a marketing lesson working on toyotas; T has modularized stuff so much they can get you to do a $1-2k upgrade to get another $20.00 worth of switch. It's also how they make serious profit doing upgrades after delivery; most if not all is standard wiring from a standard harness. Seen this on this site for the rearview mirror upgrade, side mirror upgrade, and now the wiper stalk.
    OBTW: My '12 Taco interval wipes (wide line is more wipes-LESS interval) are reverse from all my prior toyotas: Sienna, '02 taco, Corolla, Highlander and Rav4 (wide line is less wipes-more interval). Must be part of the harness. Anyway i timed them - intervals (off time) are about 2.5/5/7.5 and 10 seconds. ymmv
  12. Sep 12, 2014 at 11:10 AM
    22Arggh
    22Arggh Member
    SoCal
    2015 V6 SR LBDC MGM
  13. Mar 17, 2023 at 2:34 PM
    easleycrawler
    easleycrawler Well-Known Member
    Travis
    Easley, South Carolina
    2014 RC Taco 4wd
    I know this thread is old. But I did the intermittent wiper mod about a month ago. Today, there is no intermittent, I've got up for mist, intermittent is constant low, then low and high. Anybody else had this problem? The stalk is a brand new oem.
