2015 audio upgrade
Discussion in 'Audio & Video' started by Brent.Bower, Mar 13, 2016.
  1. Mar 13, 2016 at 7:40 PM
    Brent.Bower
    Brent.Bower [OP] Active Member
    Calgary, Alberta, Canada
    2015 Tacoma TRD sport Doublecab
    Hello.
    New to posting, but have been nosing around for about 6 months now.
    To day I placed an order for what I think is everything I need to do a basic/advanced rework of my 2015 tancoma stereo.
    Sound Ordnance B-8PTD
    Sound Ordnance™ M-4050
    Sound Ordnance™ P-67C( front and rear)
    Metra 71-035LC Speaker Wiring Harnesses (front and rear)
    Scosche SAT69 Speaker Mounting Brackets
    Metra 82-8148 Speaker Mounting Brackets
    Scosche SLC4 Line Output Converter
    EFX PA10BX Wiring Kit (one for amp and one for sub)
    Arista 16-Gauge Speaker Wire
    I am at a loss as for a wiring harness so I don't have to cut factory wires. My goal is to upgrade with out any modification to factory wiring. I hope my order will come this week so I can start installing next weekend. If anyone can give me part numbers or links for a wiring harness that would be great.
    I will update as I install. I didn't find a lot of info on system upgrades less then major advancement . All I want is better sound and not having to have the volume at 40 just to hear over road noise.
  2. Mar 14, 2016 at 4:32 AM
    Brent.Bower
  3. Mar 14, 2016 at 4:39 AM
    cmoekim
    cmoekim Member
  4. Mar 14, 2016 at 4:44 AM
    Brent.Bower
    I looked at the "best kits" and I could only find the BHA 1761. The ones I found should arrive by Friday and the total for both and shipping was only 23$ canadian.
  5. Mar 14, 2016 at 8:26 AM
    UBYBC
    UBYBC Well-Known Member
    2014 Tacoma TRD OR
    i just finished this project, and it can be done and sound great!
  6. Mar 14, 2016 at 12:05 PM
    proven21
    proven21 Well-Known Member
    Sterling, VA ( Loudoun County)
    2016 Taco DCSBOR 4x4 - Super White
    OME 90021 Front Strut 2887 Coils & OME N182 Rear Shocks, Wheelers Progressive AAL Pack, TC UCA's, BFG TA KO2 285/70r17 w/ 17" Method Wheels, AVS Window Visors, CoverKing NeoSupreme Seat Covers (charcoal/black), Mobtown Offroad Sliders, Relentless Fab. Bed Rack.
    how do those work, I plug them into each other and then how and where do I connect them to my stock 2016 Tacoma Entune HU (Non JBL) i have to cut into the wiring somewhere and get this in correct? I have no clue what I am doing.
  7. Mar 14, 2016 at 12:53 PM
    UBYBC
    2014 Tacoma TRD OR
    Sounds like you should go visit the car audio shop, if you keep saying "I have no clue what I am doing."
    And this thread is titled "2015" audio upgrade.
  8. Mar 14, 2016 at 12:54 PM
    proven21
    and pay thousands, no chance, I know a little about what I am doing maybe I should be clear I have never hooked up a system to a stock HU only aftermarket. Also, 2015 entune HU apparently is quite similar to the 2016 so that is why I am searching high and low for answers.
  9. Mar 14, 2016 at 1:02 PM
    UBYBC
    2014 Tacoma TRD OR
    I searched high and low also and once i had all the parts it made sense. I just posted a long thread on doing the entire truck sound system. You're basically disconnecting the factory wiring from the HU... Your male harness/s plug into the deck then run to your amp. Your amp runs back to the female harness/s (reverse wiring) that plug into the factory wiring spine that feeds the speakers.
  10. Mar 14, 2016 at 1:03 PM
    Brent.Bower
    Wire the ends together and plug into the radio and the old harness. Just adding wire so I don't cut factory wires.
  11. Mar 14, 2016 at 1:04 PM
    proven21
    none of the harness plug into the back of the 2016 Entune stock Non JBL HU.
  12. Mar 14, 2016 at 1:05 PM
    UBYBC
    2014 Tacoma TRD OR
    Then like i said before you do not have the correct harness.
  13. Mar 14, 2016 at 1:09 PM
    proven21
    right i have established that clearly. what I was looking for was perhaps someone on this forum somewhere would either have a work around or a solution for a different harness.
  14. Mar 14, 2016 at 1:12 PM
    UBYBC
    2014 Tacoma TRD OR
  15. Mar 14, 2016 at 1:12 PM
    proven21
  16. Mar 14, 2016 at 1:15 PM
    UBYBC
    2014 Tacoma TRD OR
    Dude, you just posted "Also, 2015 entune HU apparently is quite similar to the 2016"
    so maybe you should start a thread for a 3rd gen 2016 and ask if anyone knows which harness/s are required.
  17. Mar 14, 2016 at 1:17 PM
    proven21
    Right they are similar but that doesnt mean identical, maybe you need to crack open a beer or something and chill out with the intense criticism just cuz someone isnt wording things exactly how you would like them worded so that you understand them. I dont believe searching in a 2015 thread for answers to a 2016 is a such a bad idea in fact much answers for the 2016 have been found this way. Lighten up homeboy.
  18. Mar 14, 2016 at 1:21 PM
    UBYBC
    2014 Tacoma TRD OR
    intense? whatever you say, looks like you're doing great.... good luck
  19. Mar 14, 2016 at 4:04 PM
    Brent.Bower
    Anyone have any input on the hardware I selected ? I know is not "high end" gear. Anyone used any of it in there install ? Any heads up notes to watch out for ?
  20. Mar 14, 2016 at 4:08 PM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Just an aftermarket radio properly tuned will make a world of difference using stock speakers. As for a sub thats when it gets more costly
