2015 engine block heater -unable to install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vijay, Sep 24, 2015.
  1. Sep 24, 2015 at 7:46 PM
    vijay
    vijay [OP] Well-Known Member
    Last night I received the block heater in mail and I mocked it all up before going out to get cool tape to install everything. I go back ready to push the block heater and it will not budge. I then find out that there is some bracket that stops the core from going in straight. There is this youtube video of a 2011 truck where, clearly, that bracket does not exists.
    https://www.youtube.com/watch?v=9UNmmhsyHag
    I tried removing the bracket but it will not budge and angle is so tight that I cannot use breaker bar nor can I go from underneath. What gives? Why do they even design these crappy layout? any 2015 out there with block heater installed?any help? what is that bracket for?
    Both pictures taken from underneath the truck.
  2. Sep 24, 2015 at 11:51 PM
    vijay
    I spent last three hours trying to figure this out. The whole exhaust manifold has to be removed to just remove that bracket. The ratchet will not fit in any angle. I will call the dealer...this is ridiculous.
  3. Sep 25, 2015 at 12:59 PM
    vijay
    Seems like I'm talking to myself but I called Steven Creek Toyota and they said they cannot install or sell block heaters for 2015 Toyota!! Seems like Toyota has screwed up.
    Edit: I have written to Toyota about this. Let's see if they respond.
  4. Sep 25, 2015 at 2:13 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    How did Toyota screw up? By adding a bracket that prevents an aftermarket block heater to be installed?
    Plain Jane Taco and DoorDing like this.
  5. Sep 25, 2015 at 2:26 PM
    vijay
    No, by adding a bracket that prevents any block heater from going in purposefully or not. In other words, they did not state explicitly that block heater cannot be installed where as all models up till 2014 accepted a heater block(factory or aftermarket). If this is a "design" change then it is a limitation and "should" be highlighted as such. As far as I can tell, this is limited to 2015 models only.
  6. Sep 25, 2015 at 2:31 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Maybe a company just needs to make an aftermarket block heater that will fit the 2015 Tacoma.
    Or remove that bracket. What is it attached to? It doesn't appear to be too hard to get to with an extension or two and a universal.
  7. Sep 25, 2015 at 2:38 PM
    vijay
    Looking into it now...no luck so far. I will be calling AK dealers soon. I'm sure they have solved this already.
    I also tried removing the bracket but it is harder than it looks. There is no space to put in a ratchet and move around....the only way is to drop the exhaust and then re try.
    Edit: Called Toyota dealer in Fairbanks, AK and they confirmed that the bracket has to be shaved or removed.
  8. Sep 25, 2015 at 7:44 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    That does in fact suck, but I wouldn't place the blame on Toyota... It isn't possible to design a vehicle to allow any available add on to fit with no issues.
    Best of luck getting it to fit. I have faith in you.
  9. Sep 25, 2015 at 8:10 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Is it part of the 2012+ Air injection smog stuff on the headers?
  10. Sep 26, 2015 at 5:25 AM
    Pigpen
    Northwest Montana
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Backcountrry MT 3 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 24F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, OME 90021 front shocks with 885 coils, SPC LR UCAs, Up2NoGood 2wd low range mod, 4 Wheel Campers Grandby slide in camper
    I had the same problem. There's a thread somewhere where many of us ran into this. I picked up a stubby handled ratchet with a swiveling head and the job took about 10 minutes. Before that, there was about two hours of busted knuckle cursing. It's all about having the right tool.
    Jimmy, the engine is made to accept the heater - OEM, not aftermarket.
    CASHORT and DoorDing like this.
  11. Sep 27, 2015 at 5:04 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Obviously it isn't made to accept the heater.
    So that is a Toyota Block Heater?
    I didn't know Toyota made block heaters.
  12. Sep 27, 2015 at 11:33 AM
    kegman
    kegman Well-Known Member
    Ron
    Regina sask canada
    tacoma trd 4x4 2007
    if this is the case why not install a circulation heater or a magnetic pad heater [oil pan needs to be steel not aluminum or plastic ].im not sure what our oil pans are made of.Zero-start Temro brand makes both types and i believe they are available at )Reillys.
  13. Sep 27, 2015 at 4:55 PM
    vijay
    Hello team, Yes oil pan heater(sticker or magnetic) is the only option now. None of the dealers want to sell or install this heater block. I spent another 4 hours this afternoon trying to come up with some ratchet socket combination that works(tried 3/4,1/2, small extension, big extension, elbow and you name it)...no luck. There is just not enough space to torque it out.
    Hi, can you post a picture of your ratchet? I will swing by HF in now...
  14. Sep 27, 2015 at 5:17 PM
    vijay
    This will not work. The bell housing blocks the wrench from fully connecting. I will try others tomorrow...One last resort is the air ratchet(I will have to find a friendly mechanic now;)).
  15. Sep 28, 2015 at 10:23 PM
    vijay
    I was finally able to install the heater. Thanks DoorDing for pointing the correct HF ratchet. That is exactly what I needed.
    Note: The only way to break the nut loose is from top(factory installation has locktite). So get the ratchet in from the bottom (if top is tight, which it is) and then use extension from top. I ended up using pump handle from my 20 ton jack(the orange pipe)as extension.
    I will find a clean way to put the bracket back on. As of now, it is hung away from the engine block using a metal wire.
    DoorDing likes this.
  16. Sep 28, 2015 at 10:24 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    DoorDing is a good dude.
    landphil and vijay[OP] like this.
  17. Sep 29, 2015 at 2:39 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    block heater on a tacoma, funny.is it diesel
  18. Sep 29, 2015 at 7:04 AM
    Capt Jrod
    Capt Jrod Well-Known Member
    Jarrod
    Northern Ohio
    15 WHITE DCSB 4x4 TRD SPORT
    I have a block heater on my kubota which is a diesel. I live in northern Ohio. It will start without plugging it in no matter how cold it is. However, it is really angry and pissed off about it. Plug it in and it is happy. I am thinking about adding one to the taco. Is it necessary? No. But hearing the anger in the diesel makes me think about it
  19. Sep 29, 2015 at 7:47 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Good call. You're both good dudes!:cheers:
    vijay[OP] likes this.
  20. Sep 29, 2015 at 7:53 AM
    vijay
    Not sure what's funny about it. Where I'm going(DeadHorse, AK), it is absolutely necessary. Temps at -30 to -40 are not uncommon.
    I rather have it and not use it as compared to need-it and not have it.
    Atlas86, mtmudrunner and llamasmurf like this.
