2015 Front Brake advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shaun_Geez, Aug 16, 2017.
  1. Aug 16, 2017 at 10:52 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Really ask yourself how aggresive you drive. So many people say they drive like a grandpa when they actually drive like grandpa on crack. Lol
    If you truly do not brake excessively look at the brakes or have someone look at them and see if they are corroded or the brake pad is not seated properly.
    If there is something wrong, simply replacing all pads and rotors won't fix it. It will just pop up again in a few thousand miles.
  2. Aug 16, 2017 at 5:04 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Pads and rotors should be replaced as a set. Better quality pads won't cause the same issue as often. Mine did the same thing around 20k miles. Put entirely different pads and rotors on. Drive the same and no repeated issues at 70k miles.
  3. Aug 16, 2017 at 7:43 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Why are you still insistent on turning your rotors? Try the brake bedding procedure I linked to (follow it exactly as it is written) and then report back.
    Jimmyh likes this.
  4. Aug 16, 2017 at 8:44 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    They are not warped, the pads are fine, the rotors are fine. The problem is the way you drive, the pad material is irregularly coated to the rotor. Do the brake bedding procedure as linked by 2015WhiteOR and you will be OK.
