2015 getting awful mpg...help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by House Forsaken, Jan 28, 2016.
  1. Jan 30, 2016 at 8:22 PM
    #81
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Article that explains why idling isn't good for your engine. This really has been known for a long time.
    http://www.sciencealert.com/the-big...nter-is-doing-your-engine-more-harm-than-good
    We spoke with mechanical engineer and former drag-racer Stephen Ciatti about the pervasive myth that you need to warm up your car in the winter.
    For the last 26 years, Ciatti has worked on combustion engines – engines that generate power from burning fuel, like gasoline – and currently oversees all of the combustion engine work at Argonne National Laboratory in Illinois.
    To get straight to the point, Ciatti said that idling your car in the cold not only wastes fuel, but it’s also stripping oil from critical components that help your engine run, namely the cylinders and pistons.
  2. Feb 1, 2016 at 5:48 AM
    #82
    mferguson
    mferguson Well-Known Member
    Marc
    2011 Tacoma TRD Sport
    we can all agree a larger gas tank would be good :D
  3. Feb 1, 2016 at 6:05 AM
    #83
    House Forsaken
    House Forsaken [OP] Well-Known Member
    Paul
    2015 Tacoma TRD Off Road (Traded) 2017 TRD Off-Road (Traded) 2018 TRD Off-Road
    I wasn't expecting amazing mileage, but being in 2 wheel drive and not gunning it, I did expect higher than 14.6. I'm sure quite a few people don't recall lower prices. Hell, I remember when people freaked out when it went from $1/gal to $1.25! (way back when)
  4. Feb 1, 2016 at 6:07 AM
    #84
    TacomaArto
    TacomaArto Well-Known Member
    Wisconsin
    2015 White DCSB SR5
    Premium under $2?
    #awesome
  5. Feb 1, 2016 at 6:10 AM
    #85
    House Forsaken
    Paul
    Thanks! I did some research as well this weekend and found similar info. Looks my warm up time is probably the culprit. I'm going to change that routine and see what happens.
  6. Feb 1, 2016 at 6:11 AM
    #86
    TacomaArto
    Wisconsin
    2015 White DCSB SR5
    Isnt almost all gas ethanol blended regardless of "winter gas"? There is like 1 or 2 stations near me that have gas w/o ethanol and thats only if u buy premium....
    #iowacaucus
  7. Feb 1, 2016 at 6:15 AM
    #87
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    I don't think I'm going to give much thought to an article that has a dude with his hand in his pocket "pushing" a car as a pictorial.
  8. Feb 1, 2016 at 6:28 AM
    #88
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Depends entirely on what part of the country you live. In the north east ALL gas is ethonal, it's a state standard. Most other places in the us have both, except maybe california?
  9. Feb 1, 2016 at 6:56 AM
    #89
    Pigpen
    Dan
    Northwest Montana
    Around here, mpg drop happens in late October when it's often still pretty warm out. I see a significant decrease before I start doing longer warm ups due to weather.
  10. Feb 1, 2016 at 6:57 AM
    #90
    TacomaArto
    Wisconsin
    2015 White DCSB SR5
    Right. And if any state has non-ethanol gas its usually premium, correct?
    Thats why im confused on the winter gas sucks, run non-ethanol thing.
    Its not like June hits and all the gas stations have non-ethanol gas. Its always there regardless of season if U wanna pay for premium.
  11. Feb 1, 2016 at 6:59 AM
    #91
    TacomaArto
    Wisconsin
    2015 White DCSB SR5
    I am going to agree that your 14.6mpg, if legit, is bad.
    Did u do your own calculation not including the "dealer fill-up"?
  12. Feb 1, 2016 at 7:08 AM
    #92
    Dilleytech
    Dilleytech Well-Known Member
    Jakob
    White salmon, Washington
    07 AC SR5 4x4
    Front ARB bumper, LR UCA's, OME 885/90021 struts, Ome shocks rear, general springs HD leaf pack.
    In Washington we have non ethanol fuel in regular and premium. I run non ethonal when I can and get better mileage when I do. I have done the math before and the increased price for non e fuel pencils out to be a better deal considering the increased mileage and they say it's better for everything in you engine.
  13. Feb 1, 2016 at 7:47 AM
    #93
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    NOT TRUE - take a look at www.pure-gas.org - stations in CT ME NH NY NJ MD VA PA RI - looks like every state in the North East except Delaware. Not a state standard as you stated. Some may be marinas and airports, but if you look, it is available. Now, whether it's worth the price difference is a different discussion.
  14. Feb 1, 2016 at 7:54 AM
    #94
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    I didn't say it's NOT available, but I've never once seen non-ethanol anywhere, ever. For the entire state of MA there are only 17 "pure gas" stations.
    Here's a link that explains in a picture what I was trying to say: https://www.afpm.org/uploadedFiles/Content/Our_Members/What_We_Make/Fuels/US-Gasoline-Map(1).pdf
  15. Feb 1, 2016 at 8:01 AM
    #95
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    This is partly because people see different results depending on where they live. I get 18 mpg pretty much year round and have never seen much difference at all between the seasons.
  16. Feb 1, 2016 at 8:07 AM
    #96
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    The benefit is your truck isn't cold as fuck when you get in. But yes, waste of gas. Just depends how long you like to be in a freezing cold truck.
  17. Feb 1, 2016 at 8:09 AM
    #97
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Someone posted a link around here not too long ago to an article explaining why letting an engine sit idle is actually detrimental to engine longevity.
  18. Feb 1, 2016 at 8:11 AM
    #98
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    @House Forsaken don't know if its been mentioned to you yet or not. Switch to 89 octane.
    My truck runs like garbage on 87. Especially winter blend 87.
    The 4.0 is actually tuned for 89 octane, though most people never notice it.
    I picked up mileage and throttle response as soon as i got all the 87 out of the fuel system. Might help your case too.
  19. Feb 1, 2016 at 10:14 AM
    #99
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Nope, non-ethanol is usually low octane. Just priced like premium or higher. Refiners use ethanol as an octane boost. Boat requires premium and when I find non-ethanol it is only in regular and I have to buy separate octane boost. In Texas ethanol requirements vary by county. It is mandated by EPA in "clean air counties" just like tougher inspections are. It is all of the larger metro areas. There is about a 6 county area around DFW where ethanol is mandated. I have to drive outside that area to find non-ethanol.
  20. Feb 1, 2016 at 12:25 PM
    #100
    Foozer
    Foozer Well-Known Member
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Just throwing in my 2 cents, I have a 2012 trd sport, no lift, supercharger, and bfg kos and I get 14-15 as well :/ Always been like that even before the supercharger so I've just excepted it.
