2015 Picture Challenge Thread
Discussion in 'Photography' started by BradyT88, Jan 28, 2015.
  1. Jul 27, 2015 at 3:59 PM
    #2021
    BradyT88
    BradyT88 [OP] Well-Known Member
    Take luck! Mine leaks here and there. Usually when I have one of my bad driveshafts on...
  2. Jul 28, 2015 at 8:21 AM
    #2022
    Flhighby
    Flhighby Well-Known Member
    Remynator
    Montreal surroundings
    2014 TRD Sport DCLB
    Skid plate (front section) OR FAB, Leer shell 122, CB Cobra WX ST II, Little Wil Antena, BF MudTire 32's, rear diff breather relocation, power lock tailgate, cab outlet/400W park and driving, fog lights on any time, rubber floor, blacked emblems, door ding
    No direct hit, both my rear wheels where against a boulder, gave it some gas, drive shaft turned but not the wheels. As I turn, there's a clocking sound like my LSD is stuck or something, even on a long curb on the highway. Dealer put it on the lift, and turns the drive shaft half a turn, before the wheels start to turn. When removing the drain plug, lots of metal ???
    I didn't rev the motor higher than 2500, 3000 RPMs
    No leaks, looks normal from outside, except the drive shaft moving freely
  3. Jul 28, 2015 at 8:24 AM
    #2023
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Ouch.
    Pumpkin Grenade.
    MatthewMay1 likes this.
  4. Jul 28, 2015 at 9:17 PM
    #2024
    BradyT88
    You're going to have to pull the third member to find out. Sounds like your pinion might be missing some teeth...
    When my ring gear was missing 3 teeth it drove fine but made a horrible clunking sound while driving...
  5. Jul 28, 2015 at 9:31 PM
    #2025
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Well it leaked about 1mm of fluid (measured from the filler hole) and then stopped.....has not started back up again.
    I think i'll just get some synthetic redline for it, a new seal, and just do it.
  6. Jul 28, 2015 at 9:37 PM
    #2026
    BradyT88
    You'll have to be very careful. It's very easy to mess up that crush washer and your gears will be off and they'll grenade on you down the road... If it stopped leaking; I would just monitor it and leave it be.
  7. Jul 28, 2015 at 9:46 PM
    #2027
    AR15xAR10
    This is exactly why i don't trust a shop to do it.
  8. Jul 28, 2015 at 9:47 PM
    #2028
    AR15xAR10
    I'm still going to clean the housing, frame, gas tank, exhaust, etc. so i can track it on the fly.
    But what has me most concerned is things getting in past the seal. Like moisture, water, mud, etc.
  9. Jul 28, 2015 at 10:07 PM
    #2029
    BradyT88
    I don't trust myself to do it.... you have to pull the third and pull the pinion. After that you are basically setting your own gears up again... pretty sure they recommend replacing the crushwasher since they aren't really reusable.
  10. Jul 29, 2015 at 4:53 PM
    #2030
    PinnaclePete
    PinnaclePete I am what I am
    Pete
    Central AR
    '14 Sport DCLB Pyrite, 2015 DCSB Barcelona Limited
    SwitchPros 9100, Flip Pac, Stealth 6 Bronze, Toyo 255/80/17, MTO Tailgate Skin, RCI read diff plate, StopTech slotted disc and pads, OME 885 w/ NitroChargers, OME HD LeafPacks, SOS Rear bumper with swingout, BAMF Bolt-on Sliders, Rear diff breather, OEM roof racks, ECG perforated grill, BAMF behind grill light bar bracket with PIAA 510 4" yellow spots, US OffRoad bumper, Engo 9k winch, WeatherTech window vents and floor mats, Wet Okle seat covers, RedLine hood struts, Anti Dark hood lights, Baja amber light pods, Lamin-X amber flood covers, amber FlyEyes, Jumpers amber LEDs, Salix glovebox and center console organizer, MagLite mounted, shop made bed mount tool boxes, LogRite bed mount bottle opener
    My next Challenge for you guys....Picture of your rig, a giant American/Canadian flag and a Black Hawk helicopter. Bonus if it' 102* outside.
    docloco and MatthewMay1 like this.
  11. Jul 29, 2015 at 6:13 PM
    #2031
    PinnaclePete
    Pete
    Central AR
    That's why they call it a Challenge...
  12. Jul 29, 2015 at 6:15 PM
    #2032
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    It wasn't posted by Brady so it doesn't count. Hahah :p :D
    AR15xAR10 likes this.
  13. Jul 29, 2015 at 7:02 PM
    #2033
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    That's why it won't ever be completed. Haha
    White Horse and SpruceTaco like this.
  14. Jul 29, 2015 at 7:15 PM
    #2034
    PinnaclePete
    Pete
    Central AR
    Brady who.....................?
  15. Jul 29, 2015 at 7:26 PM
    #2035
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    :eek:
  16. Jul 29, 2015 at 7:29 PM
    #2036
    BradyT88
  17. Jul 29, 2015 at 7:29 PM
    #2037
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
  18. Jul 29, 2015 at 7:33 PM
    #2038
    BradyT88
    This is as close as I can get. "My rig", an Apache Helicopter and a giant cannon!
  19. Jul 29, 2015 at 7:41 PM
    #2039
    BradyT88
    Posted!
  20. Jul 29, 2015 at 7:47 PM
    #2040
    because_wumbo-truck
    Jon
    Houston, Texas
    Damn my state flower has been out of season for 2 months and won't be back til April-ish.
    And we had a ton of flooding in my area about a month ago. :annoyed:
