2015 stock radio amp input harness?
Discussion in 'Audio & Video' started by sy272004, Sep 17, 2017.
  1. Sep 17, 2017 at 6:56 PM
    sy272004
    sy272004 [OP] Well-Known Member
    West Chester
    15 TRD V6 4x4 DC
    3" lift. 33" tires. Headlight Retro, intake, exhaust
    I searched crutchfield and googled but can't seem to find harness to have inputs for amp. I thought there would be Y harness so I don't have to cut my oem harness to get inputs to amp speaker level inputs (pioneer 5 Chanel amp 9605). Is there such a thing?
    All harnesses I found was for oem to aftermarket head unit
  2. Sep 20, 2017 at 8:16 AM
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
  3. Sep 20, 2017 at 8:19 AM
    sy272004
    West Chester
    15 TRD V6 4x4 DC
    Ok thank you. Amp has speaker level inputs so i guess ill cut the wires and solder wires to run to amp
  4. Sep 22, 2017 at 6:10 PM
    MikeHaskins
    MikeHaskins Member
    Hagerstown MD
    2012 Pyrite Mica 4x4 DC
    I installed one of these in my 2012 dbl cab. . http://www.ebay.com/itm/Factory-Rad...rness-Cable-/361326435262?hash=item5420bbdbbe
    It's kinda like a jumper between the factory plugs. I was able to splice into this thing and run it to my 5 channel amp with speaker level inputs. I didn't have to touch the factory wires. I didn't need the RCA input so I just cut it out. Works great, and when I want to remove it, I just unplug it and connect the factory harness directly back into the radio.
    sy272004[OP] likes this.
  5. Sep 22, 2017 at 6:20 PM
    MikeHaskins
    MikeHaskins Member
    Hagerstown MD
    I'm not sure of compatibility with 3rd gen. Worked great in my 2012 non JBL DC. If it helps, the factory wiring harness (2 plugs) looked like this: Tacoma Stereo Wiring.jpg Tacoma Stereo Wiring 2.jpg
    It made it so much easier to do all my splicing at my kitchen table instead of pulling out the wires as far as they would go and splicing in the truck. Hope that helps.
  6. Sep 22, 2017 at 7:14 PM
    sy272004
    West Chester
    15 TRD V6 4x4 DC
    This does help. Thats what i was looking for but could not find reference to 2015 tacoma and only till 2011. I will check to make sure my connectors look like rhat first before orderingg
  7. Sep 27, 2017 at 7:48 PM
    MikeHaskins
    MikeHaskins Member
    Hagerstown MD
    Yeah, I saw that when I was ordering and wasn't sure (mine is a 2012 and not listed either) Thankfully it worked. Good luck!!!
